Creative I-trigue L-3800 computer speakers (sub + 2 satellites). Occasional pop from sub. Without any warning the whole thing shuts off. Won't turn back on for a while. Must be turned on by me - doesn't come on by itself again. Sounds to me like it's overheating ( the power block gets very hot). After a while you can turn it back on again and it works fine. Any help would be appreciated. I paid about $175, does it pay to fix it?
Overheating or something else, the unit has to be opened up for a look and see. Primary suspect would be the pigtail/voicecoil of the subwoofer, the amp IC and power supply.This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional. On most comparable systems, replacement parts cost would not be that expensive, it is however the service fess that are rather high. Based on this, you may want to reconsider your options.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
You are in the right place. But to wait for the right tech may take a bit of time. You will have to bear witness to many who would wish to deceive you for your money.
Disregard this message itself, but not the journey here. You will have to refuse many, including me, before you reach your true guide to resolve your problem.
Until the right board tech answers your problem,
Worldvet
It is due to over heating or may be due to some short circuit within the power cord. Did you try replacing the adapter and the power cord alone. It may help. You may also try talking to a service person and aske them for an estimate for the repair of the speakers. There are various service people who do a free estimate. I can provide you with a list of service people contacts if you let me know of the zip code. Or else follow this link http://www.fixya.com/Services.aspx?prdid=471662&zip=87106 and change the area and find service people addresses by yourself.
Thanks.
Try to hard reset the system. Turn off, take power supply cable off and leave it for at lease 60 sec. Restart again....
