Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub-zero 650 makes loud gurgling sound
Our fridge has started to make a loud gurgling sound - like a fluid is bubbling through a pipe. This either happens when the compressor is running and you open & close the door OR when the cycle ends.
This cannot be normal and as designed. Any help?
  • pgsanth Nov 04, 2008
    I refuse to believe that sub-zero would design a fridge that, within three years of operation, would start to loudly gurgle at the end of every cycle. This IS unusual.
    President:
  • 1,462 Answers
Gurgling is not unusual and is caused exactly by fluid bubbling thro a pipe.
Posted on Nov 04, 2008
My Bosch Fridge makes a loud gurgling sound every twenty five minutes even after freezer fan &emotion were replaced.
It's a normal noise! When the liquid refrigerant becomes less pressurised, usually when the thermostat clicks off,, it still bubbles through the system until the pressure equalises.
Dec 17, 2014 | Bosch B22CS50SNS Side by Side Refrigerator
Very loud noises
Check the rubber mounts under the compressor and look for any lines touching the sides of the cabinet. The gurgling and clunking are often normal. good luck. Roger
Jan 19, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Fridge runs all the time,temperature seems fine inside,make's a fluid y gurgle sound all the time.only way to stop it is to lower the temperature but comes back on after a while or turn it off.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 27, 2011 | Zanussi Refrigerators
Blowinging cold air most of the time ,will blow hot off and on.tempature gauge goes up very quick on cold start.gurgling sound coming from over flow,behind glove box.
you have a air block in system remove radiator cap let it idle make sure to keep fluid full it will bubble some just watch when bubbles stop watch to see fluid flow is good
Mar 16, 2011 | 2002 Jeep Liberty
Sewer smell in house since installing the new toliet and the toliet gurgles when the washing machine is on. It started with the new toliet now the gurgling and smell is also present in another bathroom.
It sounds like a vent problem.
On top of each house is a vent stack.
There should be a vent stack above each toilet, and above kitchen sink.
Look for pipes sticking out of roof.
These pipes are open to the sewer line.
When you run a column of water down a drain, the vent stack lets air flow in front of and behind the column of water.
This air flow prevents the gurgling sound.
The gurgling sound is the drain water pushing air in front of it because of a clogged vent.
If you have a two story house, there are vents that run between floors to prevent the air flow from gurgling or bubbling sewer air into each drain as water column moves down pipe.
http://www.bradyinspects.com/plumbing-vents.html
http://chestofbooks.com/home-improvement/construction/plumbing/Standard-Practical/Venting-Part-3.html
Look for bird nest over vent pipe on top of house.
Run a snake down into pipe from roof and see if the is a stoppage.
You many need to call plumber to track down each vent and the cause.
For example if there are quick-vents installed inside a wall and the quick vent is no longer working.
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
Dec 25, 2010 | Kohler Bath Highline K-11492-96 Biscuit...
Squeals heard from my fridge compressor
hi there,
what you thought of the sound is correct. the compressor might have gotten a little rusty after running 24hrs. if turning it off helps then do so but make sure you have everything important removed from inside the fridge. solving this problem can only be done by a repairguy as it has to be opened up.
Jun 15, 2010 | Refrigerators
My mothers beko fridge freezer making bubbling sound
Sounds like the evaporator fan is doing its job. Nothing to worry about. Good hearing is a blessing all fridges make different sounds some click loud while others gurgle loud. Some pop and snap. Till I got my hearing aids I didn't know mine ran so loud and clicked.
Dec 15, 2009 | Refrigerators
Whirlpool fridge incessant buzzing
The knocking noise when cuts off , is a compressor internal motor support spring , broken . This does not mean the compressor is bad , only noisy for the rest of the compressor life , but should be covered under the 5 yr warranty . The gurgling sound is the refrigerant being pumped thru the system . The buzzing could be from the compressor also . My suggestion , would be to call a factory warranty company , to see if they can replace the compressor under warranty .
Sep 07, 2009 | Refrigerators
Fridge isn't cold and the alarm light stays on, before it happened the fridge started "gurgling" alot!
Ok, this will confirm a major compressor fault. the main seal has failed. you will need to replace the compressor in order to restore the unit to its original cooling state.
If you can give me the model number and brand of your unit, i can direct you to some reasonably priced compressor kits if you would like.
May 17, 2009 | Refrigerators
Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Feb 28, 2008 | Refrigerators
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
1,806 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
