Question about Zanussi FJ1254W Front Load Washer
Machine Bleeps when turned on with no lights coming on
When I turn my machine on, the power light comes on but it just bleeps at me. Non of the other lights come on. I thought it may be the level part but the machine is perfectly level. Any ideas PLEASE! Thanks.
  • redfella Feb 02, 2008
    have same symptoms and three dashes showing where the time normall shows
  • 139 Answers
Check the door locks then get back to me
Posted on Oct 10, 2006
SOURCE:
Machine shows an orange light and bleeps but does not come on
This is RAM error. If you have tried to install new RAM module, probably it is incompetible with your motherboard or other RAM modules or BIOS RAM timings. Try to replace that module or restore to defaults BIOS RAM settings.
Nov 27, 2011 | E-Machines Computers & Internet
When i turn my ps3 on the green light comes on turns yellow then turns off which it then has a flashing red light how do i fix this problem?
hello try a reset press and hold the standby button on the front of the ps3, you hear 1 bleep the 2 short bleeps after the short bleeps release the button it should reset good luck
regards
shaun
Oct 01, 2010 | Sony Playstation 3 (PS3) Console
My playstation turns on but nothing happens after that. There is no display or sound output. It will not turn off, gibving two beeps if you try to shut it down. The hard drive light comes on for about...
hello try resetting it turn the ps3 on then press and hold the standby button you should hear 1 bleep then 2 short bleeps after the short bleeps release the button it should reset it self
regards
shaun
Aug 30, 2010 | Sony Playstation 3 (PS3) Console
When I turn my PS3 on it bleeps then doesn't work
This is the yellow light of death. It happens when the system overheats causing the solder to melt on the board. It needs to be reflowed professionally. Contact Sony if it is still under warranty. If not, check out www.wiredextreme.com. We are a game console repair company that is BBB accredited. All of our repairs come with a 90 day warranty. Feel free to call 1-888-389-3038 or e-mail support@wiredextreme.com if you have any questions.
May 04, 2010 | Sony Playstation 3 (PS3) Console
When i turn it on it bleeps and f 37 comes on
u have a fault the operation of the washer.
The machine has a defrost function, pressing the temperature button twice will start this and show a snowflake in the top right hand corner Press the temperature button twice, ( A snowflake will appear in the top left corner) this acts as a defrost button. F37 will probably occur more often if your machine is stored in a outhouse. or try thawing out the water pipe.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Jan 12, 2010 | Bosch Logixx WFR 3267 Front Load Washer
Computer wont turn on
There are over 20 bleep codes, it sounds like morse code with short & long bleeps, these bleeps are for on board memory, remove RAM from slots & re instal one at a time in another compatable machine to check if RAM is OK, check power pack, also check power switch connection on front panel conection block on mobo
Apr 10, 2009 | Dell Dimension E310 PC Desktop
Scooter motor does not operate
are you sure its in gear. I had the same problem and I pushed the nob on top of the motor towards the front of the machine and it worked!!!
Apr 03, 2009 | Health & Beauty
Switches on & bleeps
try to check the cable connection between the monitor and the tower. what is the color of the LED light on the monitor?
Oct 27, 2008 | Dell Dimension 3100 PC Desktop
Matsui dishwasher mf160
I used the solution I found for a slightly different fault, ( this was the same fault but without the bleebs)
switch off mains and turn off water. Then disconnect water pipe and lay machine on it's back. Switch on electrics, and allow water to run out. Switch off electrics and stand machine up .Reconnect everything and hey presto I can hear two good things, the machine gently humming, and my wife telling me what a genius I am !!
Aug 05, 2008 | Electronics - Others
Zanussi FJ1254W Front Load Washer Logo
146 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
