Question about Canon PIXMA MP780 All-In-One InkJet Printer
Scanner problem Since changing to my new laptop I cannot get my scanner to work. It shows the scan but there is nothing on it. Or it will scan the paper in quarters - scans 4 times and 1/4 of document on each scan
  • KenBagby1 Dec 12, 2008
    I have used the Canon Pixma 780 on my PC running XP for 3 years but recently jumped, happily, into the Mac world with a iMac running OS 10.5. I reinstalled the software and everything seems to work fine except the scanner which won't operate at all. I went to these websites above and downloaded a driver dated 4/1/07 which appeared to perhaps solve the problem but the result was the same. Any ideas? This doesn't sound right since everything else works.
I presume your new laptop came with Vista and your old one had XP. Either convert your new laptop to XP (complicated but I wish I'd done it when I got my new computer rather than soldiering on with the indescribable rubbish system that is Vista), or install all the latest drivers, and MP Navigator. loads of the other stuff on the canon installation disk just won't work with Vista. If you have Omnipage SE installed, you will have to get an email link from Canon, whose support website leaves a lot to be desired.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=10444
Or go to canon europe whose site is not as good (weird to see Canon not going for the simple idea of global support)
I just bought a new full version of Omnipage, but it does annoy me that so soon after buying the MP780 I had to go to all that trouble.
Posted on Dec 11, 2008
I have scanner hooked up to laptop and i press scan, it says scanning but has nothing showing up for a picture scanned
Is this a new scanner? If so, most scanners come "locked".
Make sure you consult your user manual and remove the lock (usually by turning a knob/handle/switch under the hood somewhere).
If this has scanned before, watch the scanner bed as you try to scan. If the light does not coarse the entire scanner bed, then the lock may have become re-enabled... or the motor could have come off track. Sometimes this can be fixed by manually adjusting things inside (be careful! as this could really damage your scanner).
If the light does move entirely across the bed, try to re-install the software onto your computer. If you dont have the software, you can grab a copy at dell's support site.
Also, check your cables. If you are trying to scan through a network, you might try USB instead, just to make sure the scanner works. and its not a connection problem.
The connection type can be set during installation.
Hope this helps!
Feb 23, 2011 | Dell P703w Printer
Cannot scan documents
go to device manager look for imaging device (scanner) right click and uninstall. / click scan for hardware changes tab, found new hardware must be appeared and click next / select don't search, i will choose the driver to install / click show compatible hardware and choose scanner driver found and click next. and finish.
Feb 11, 2010 | Fujitsu M3091DC Path-Through Scanner
Scan shows 1/2 scan in black
Hardware failure, nothing much can be done just replace the scanner.
Aug 27, 2009 | HP ScanJet 2200C Color USB Scanner
Discoloured bar on scanning from Epson Perfection 1670
It may be caused by driver conflict. Try to reinstalled OS and driver.
Jul 24, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
Fujitsu fi-4120C2 scanner
There are two generally components for a scanner to work, One the Hardware Driver, which connects to the Comp and Two, a program to scan using the hardware connected. Sometimes, both may be available in the same program. For example, after installing the Device Driver, you can use any scanning program, to scan. Hence please check if you have loaded the Device Driver. You may be just using the scanning software, whcih is not able to detect the device!
S. Mohan, Chennai, India
Jan 20, 2009 | Fujitsu ScanPartner fi-4120C2 Path-Through...
Not showing in programs
Make sure the scanner is turned on. There is a power switch on the side of this scanner.
Feb 24, 2008 | Canon CanoScan 8400F Flatbed Scanner
Scanning problem with A940 AIO Dell printer/scanner
    Hi there, just found this solution to work perfectly. i just freaked out for a moment with the same problem. Use this or just type fax and scan in your help function. Hope this helps!
    Before you begin, make sure that you've installed your scanner on the computer and that the scanner is turned on.
  1. Windows Photo Gallery.
  2. Click File, and then click Import from Camera or Scanner.
  3. In the Import Pictures and Videos window, click the scanner that you want to use, and then click Import.
  4. In the New Scan dialog box, click the Profile list, and then click Photo. The default settings for scanning a picture are automatically displayed.
  5. If you're using a scanner with a document feeder, click the Paper size list, and then click the size of the picture that you've placed on the scanner or click the size that most closely matches the picture.
  6. Click the Color format list, and then click the color format that you want the scanned file to display.
  7. Click the File type list, and then click the file type that you want to use to save the scanned file.
  8. Click the Resolution (DPI) list, and then click the resolution, in dots per inch, that you want to use.
  9. Adjust the brightness and contrast settings or type the values that you want to use.
  10. To see how the picture will appear when it is scanned, click Preview. If needed, modify the scan settings, and then preview the picture again. Repeat these steps until you're satisfied with the preview results. Some scanners might require you to place the picture in the document feeder each time that you scan.
  11. Click Scan. When the scan is complete, Windows Photo Gallery prompts you to tag the picture so that it's easier to organize or find later.
  12. In the Tag these pictures (optional) list, type a tag name, and then click Import. Windows Photo Gallery displays the picture so you can view, fix, or organize it.
Feb 01, 2008 | Dell A940 All-In-One InkJet Printer
No picture image when scanning
This looks like a CCD failure. Can the image be corrected in the PC software Which image editor are you using?
Jun 14, 2007 | HP Scanjet 5500c Flatbed Scanner
Canon PIXMA MP780 All-In-One InkJet Printer Logo
96 people viewed this question
old marine
old marine
