Question about Krups XP 4050 Espresso Machine
Leak I just bought my first expresso machine, and every time I try to steam milk, the machine leaks water out of the bottom. When I make coffee, it is fine, unless I try to make coffee after having steamed milk, in which case it also leakes...what is going on?? Is this normal??
  • 2039 Answers
SOURCE: coffee out not same as amount of water in/no steam
you have to descalcify the machine not with vinegar .vinegar removr calcium in little pieces and might block the machine descalcifier melt the calcium on the heating element you have lots of calcium that mean less heat you use 1 part descaler 1 part water put in water containerstart the machine for a few second turn off for 10 minute if you never descaled the machine leave it for 15 minute and repeat untill empty rince very good a few water container that stuff is very corosif after a good rinse try the coffee it should be good thank you for using fixya pierre
Posted on Feb 08, 2008
SOURCE: Krups 867 boiler steam leak
Save yourself the trouble, buy a $1.99 frother at Ikea.  Makes the cleaning process easy - that's what I use at home, never used the steam wand on my machine.
To use the frother, just heat up the milk and froth away.  Pretty easy.
Posted on Apr 04, 2008
  • 74 Answers
SOURCE: steam wand is leaking, so
the gaskets are broken in the steamer, you need to change them
Posted on Jul 11, 2008
  • 4 Answers
SOURCE: No steam comes to milk frother
Try this: 1. Pour in vinegar instead of water. 2. Bring vinegar to a boil but do not run it through the machine. 3. Turn off machine for about an hour. 4. Remove sheath from the frother and clean the metal tip. 5. Place tip of frother into large mug of cold water. 6. Turn espresso machine on and allow vinegar to run through frother. 7. You'll know the frother is clear when the water in the mug begins to churn rapidly (and perhaps loudly).
It may take the vinegar a little while to dissolve and loosen the blockage. If the process does not work the first time time, try again later and allow the warm vinegar to sit in the machine longer.
Optional: Before starting the process, unbend a paperclip or thin metal hook (the kind used for hanging holiday ornaments) and use it to clear the steamer orifice.
To keep frother clear: Follow recommended descaling schedule in user manual
Posted on Apr 05, 2009
  • 5 Answers
SOURCE: My xp7240 has also started leaking water from beneath the machine
It seems like a piston sealig is damaged. Not so easy to replace but possible.
Posted on Aug 07, 2009
  • 144 Answers
SOURCE: My milk steamer is no longer steaming
From your message that it is clear that the steam is coming but it is not sufficient to heat the milk, so kindly call the customer care to sort the problem as you can't do it
Thank you.
Posted on May 08, 2010
0 characters
1 Points
Can I repair it myself?
Notice if you can hear the pump when you are opening for steam.If you dont hear it ther is a problem at the switch.If you hear it then the tube is just blocked with milk.
Apr 29, 2014 | Saeco Vienna SuperAutomatica Coffee...
Water shoots out of steam valve and can't make espresso
The steam function and the expresso use the same elements to create the steam but the valves will direct the steam to the expresso unit or the steam arm. Most likely you have a faulty valve. In most cases the valve will not open until the pressure gets to the right level. If you are just getting hot water out of the steam arm instead of steam via the expresso unit it most likely means that the valve is faulty. The valves can be replaced but is not easy. You will need to have the unit serviced or you could try to replace the valves. Make sure the flow meter is working before you replace the valves. You can check the operation of the flow meter by running the hot water cycle and making sure that you get the right amount of hot water. Good luck!
Nov 21, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
I have a expresso cappuccino maker model CC30. It is a Maxim-it is white with a red push button on top.. Does anyone have instructions for this..i don't and need some.. Thank you-gerry
nothing to know, put water in it..plug steam should be coming out, until you push the red lever..put in your milk or cream
stick probe down at bottom of cup. steam until mixture gets thick
Jul 13, 2010 | Salton CC30 Plus Coffee Maker
One side of the expresso machine is not working
Check the nozzle at the end of the steam wand, use a paperclip to clear, if you can get hot coffee then the steam wand is just blocked.
Oct 26, 2009 | Astoria Compact CKXE Espresso Machine
Leaking water from steamer
For the grouphead check the basket there might be a slight bump around the edge that is preventing it from making a good seal when it contacts the gasket in the head. If the Double works fine then the gasket is not the problem.
For the steam wand try flushing wand for 3 seconds just before steaming, if that does not help with the watery milk, then the boiler is not getting hot enough to produce steam.
May 18, 2009 | FrancisFrancis! X1 Espresso Machine
Too much water coming out of steam wand
I worked at StarBucks, what we did was put water into a contaner and steam the water, a lot of the time why the steamer doesn'..t work as well is because it is clogged. Another way to do it is to just run your steamer, also go to a coffee store and buy expresso machine cleaner. It could just need a good cleaning.
Apr 16, 2009 | Breville ESP8XL Espresso Machine
Cant steam milk and brew expresso at the same time.
You are not doing anything wrong.. that's the way this uint works.
Jan 14, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Don't know how to work the steamer.
I have the same Conair Cuisine Ultra expresso maker as you; its an old one. Make sure the coffee grind is in the spoon/filter cup and as the water heats it will brew the expresso. Simply twist the the knob at the top of the silver steam valve stem will let out hot steam for you to frosh the milk.
Nov 24, 2008 | Coffee Makers & Espresso Machines
Briel espresso machine
Try opening the frothing valve by turning the dial and force water through it instead of steam by pressing the middle, coffee button. You may be experiencing vapor lock. Once the water comes through the steamer valve, turn the steamer knob off and release the coffee button. Then try the steamer button with the steamer dial open. This may do the trick.
Dec 02, 2007 | Briel Domus Due Espresso Machine & Coffee...
Coffee Makers & Espresso Machines Logo
43 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Sergio M Perez
Ernest R
Ernest R
Mike Cairns
Mike Cairns
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
