Question about Photography
Aperture not working smoothly [MINOLTA MAXXUM 7]
At full aperture everything works fine but when I try like a F5.6 the camera gets two shots off and stops.I get ERROR message which clears as soon as I turn it Off and On.
  • john Dec 18, 2008
    Yes this was the problem.I was not aware MINOLTA had this probem.I have used another MAXXUM 7 for my work as a photographer absolutely NO PROBLEMS! I even bought a third one on EBAY which was listed broken but in fact works! I have used MAXXUM cameras for more than 10 years they really stand up well to a lot of abuse.
  • 44 Answers
Sounds like the aperture control mechanism is bad (Minolta Maxxums are famous for this problem). I would recommend sending the camera to Sony for repair (Sony now owns Minolta's photographic departments). I've been repairing the Minolta Maxxum cameras for over 15 years and I prefer to send the Maxxum 7 in for this repair do to Minolta's difficult design of this camera.
Posted on Dec 12, 2008
Does not work iris diaphragm drive
Common issue.
Camera needs new Aperture Base.
Jun 26, 2014 | Minolta Maxxum 7 / Dynax 7 35mm SLR Camera
Pictures are dark
First, check if you're taking the lens cap off. If you're taking it off, then check your exposure. See if your light meter responds to changes in illumination. If everything seems fine, then check if the aperture of the lens works as intended. Then, without a lens nor film in bulb mode, check for the mirror and shutter to work properly. If the light meter, aperture, mirror or shutter seem to flaw, then get your camera serviced by an experienced camera repair technician.
Jan 28, 2014 | Minolta Maxxum 5000 35mm SLR Camera
Is it possible to manually control the shutter speed, aperture, AND the focus on the Konica Minolta Maxxum 400si SLR 35mm film camera? I need to be able to manually control these features for a film class...
Yes. You have full control over the shutter speed and aperture in the Manual exposure mode, as described in the "M Mode: Manual Exposure" section in the manual.
You also have full control over the focus, as described in the "Manual Focus" section in the manual.
If you need a manual, you can download it (in two parts) from
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/index.html
Feb 07, 2011 | Minolta Maxxum 400si 35mm SLR Camera
Hi, I have a minolta maxxum xtsi and don't know how to set the aperture/f-stop while shooting in full manual. there is an ISO setting option but that is for the speed of the film righ? or are ISA and...
ISO and aperture are most definitely not the same thing. ISO is the speed of the film. Aperture is the size of the opening in the lens, the larger the opening the more light comes through.
To change the aperture in Manual mode, hold down the exposure compensation button near the lens mount and turn the control dial on the front of the camera.
Jan 10, 2011 | Minolta Maxxum XTsi 35mm SLR Camera
I have a Minolta Maxxum 5D which I really like. I take a lot of pictures outside with my job. I have a telephoto lens and a regular lense as well. I switch lenses a good bit depending on the shot. ...
It can occur if the contacts on the lens where they meet the contacts on the camera body need cleaning. Try a cotton swab lightly dampened with rubbing alcohol.
Aug 11, 2010 | Konica Minolta Dynax 5D / Maxxum 5D Body...
75-250mm F3.8-4.5 tamron lens compatible to a
As long as you can get the correct Tamron Adaptall 2 mounting for it, then it will fit. They're no longer made and not always easy to obtain at reasonable prices.
Adaptall 2 mounts for Minolta autofocus were never made, but the earlier MD mounts were, and they will fit any Minolta or Sony SLR. Obviously, there will be no autofocus but you will also find that you have to focus with the aperture ring wide open and then manually meter and take the shot after you have selected the aperture which you require.
Feb 16, 2010 | Konica Minolta Maxxum 50 QD with 28-100...
Minolta MAXXUM 3xi the view finder is very dark(bought second hand)
I no the older Minolta's had an aperture problem the pictures when zooming out after they were developed were very dark. But inside and wide angel shots always came out nice I had to have the aperture base plate replaced on my Minolta Maxxum 3000i my point and shooter, I wish this helped but it sounds like something different in your case it also maybe the aperture acting different in your camera than it did in 1 of mines.
Jul 27, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Minolta 5000 doesnt open aperture
The camera keeps the lens open if you look at the back of the lens you will see a small lever if you push it it will open the iris and let go it spring back if that ok it the camera that faulty
Jun 05, 2008 | Minolta Maxxum 5000 35mm SLR Camera
Minolta Maxxum 7000 35mm SLR Camera not working
Dear Minolta friends,
I have recently bought a second hand Maxxum 7000 and a AF lens, but found the body not ocntrolling the aperture while shooting. I know 7000 has someting special. Is my problem is due to lens and body compatibility or actually the malfunction of the body. I am sure the AF lens is ok since i have tried it working with another minolta af body.
Can give me an advice?
Aug 02, 2007 | Minolta Maxxum 7000 35mm SLR Camera
My Minolta Maxxum 3Xi has a dark picture in the view finder. It won't focus on anything because everything in the view finder is dark, if not completely black. I was told it might be the aperture ring. ...
The aperture ring is the right diagnosis. The aperture mechanism has a broken piece that can be repaired by a competent repair shop for under $75. There are no parts available for Konica Minolta cameras since Sony bought them - the part can be rebuilt.
Oct 22, 2006 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Photography Logo
188 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Are you a Photography Expert? Answer questions, earn points and help others
