Question about Abt Television ABT IJETABT01 WIRELESS RF REMOTE FOR IPOD Remote Control
Repairing color television philips
My remot control is lost and it's work only black and whiht how could it work color with manwal.
  • 1 more comment
  • kesete tesfamicael Oct 02, 2006
    it is 24inch. color system is not working so what is the problem
  • DINODONOF Nov 07, 2007
    my tv has no color its only black and white Its was fine when we shut it off turned it on and no color. I tried adjusting the color level nothing ..... how can i fix
  • Anonymous Jan 03, 2008
    I DONT KNOW HOW TO CHANGE THE COLR OF MY PHILIP TV
    Sergeant:
  • 337 Answers
Some tv's let you select menu from the buttons on the tv,on of the buttons will say menu and the volume and channel buttos will have a double function like an arrow to the right and left and arrow up and down,they also have a buttos that says select,press menu and use the others buttos to move thru the menus until you get to the color bar,if it is at minimum adjust it so you get your color back but if it is already in the middle the tv needs to be service.Philips sells universal remote controls that are already program to work your tv being a philips and you dont have to programe it and you can also access the menu.
Posted on Oct 02, 2006
How to program philips universal remote
  • Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control.
  • Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
  • Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
  • Press the "TV" button on the remote to program the Philips remote to your television set.
  • Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television
  • Dec 04, 2010 | Philips Televison & Video
    I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
    I suggest you try these steps..
    1.Turn the television set on by pressing the "Power" button on the set.
    2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
    3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
    4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
    5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
    I hope this helps...
    Jun 10, 2010 | Philips Magnavox Learning Universal Remote
    The colors on our tv are slightly misaligned. I'd
    hello i would order a remote first if the colours do not relign then it could be the convergance chips may be the problem good luck
    shaun
    Aug 06, 2009 | Philips 60PP9352 60" Rear Projection...
    Philips PM435S Universal Remote
    I need the proggraming codes for a JVC TV and a NEXXTECH Dr30G0DVD player
    Jan 21, 2009 | Televison & Video
    Lost remote / convergance problem
    u can not set the convergence without the remote control just look on the web they are between 30 and 60.00 dollars
    Oct 07, 2008 | Philips 55PP9401 55" Rear Projection...
    Color faded
    9p6031c has similar problem. Can we just change out the color tubes??? Who has them and how inexpensive can we get them???
    May 14, 2008 | Philips Magnavox 9P6034C 60" Rear...
    Universal remote control
    does your remote have a code search button?
    Jan 18, 2008 | Philips Universal PH301S Remote Control
    No remote Philips 60P8342
    I checked with my parts distributor = remote sensor no longer available.....Philips part # 932215244687...........................T.
    Dec 19, 2007 | Philips 60P8342 60" Rear Projection...
    Televison & Video Logo
    511 people viewed this question
    Top Abt Television Televison & Video Experts
    Are you an Abt Television Televison and Video Expert? Answer questions, earn points and help others
