The printer is not catching the paper - Office Equipment & Supplies
  • 25 Answers
Clean the tiers with 90 percent alcohol
Posted on Nov 04, 2008
Printer not catching paper
You may have to clean the pick up rollers with alcohol or put a new roller in your printer.
If you have a printer with a tray, make sure it is set correctly for the paper you have installed.
It will try to grab the paper a number of times and will usually give you a paper jam error after a number of tries.
Jul 13, 2010 | Dell 922 All-In-One InkJet Printer
Photo printing errors
This is not the fault of printer. Choose those type of photo paper, whose thickness is equal to executive bond paper. This type of printer do not catch the thick photo quality paper
Apr 09, 2010 | HP PSC 1610 All-In-One InkJet Printer
Several pieces of paper fed in printer and now I have a paper jam and cannot remove the paper
...look at the printer manual to remove jams. Some time you may have to remove the difuser to get rid of them. Depending what type of printer you have. Remember you can go on line to download the manual if you don't have one available. Check if the paper is catching excesive mousture and that the roller that catch the paper have been given proper maintenance. Tks.
Jan 14, 2010 | Kodak ESP 5 Printer
My x2480 is not printing. I can hear it trying but it does not catch the paper.
  • you may have too many pieces of paper in the feeder, try taking some out and printing again
  • push the paper into the into the printer and see if it catches (WARNING: DO NOT SHOVE THE PAPER ONLY APPLY VERY LIGHT PRESSURE)
Oct 09, 2009 | Lexmark 2480 Matrix Printer
Paper isn't catching on the roller - terrible sounds
make sure the paper is not wet and not damp. possible buy a new paper
Jul 14, 2009 | HP PSC 1610 All-In-One InkJet Printer
Printer will not catch paper in tray
The rollers need to be clean or replaced.
Feb 04, 2008 | Dell M5200n Laser Printer
Paper Jams
most likely there is paper or something stuck in that corner
use a flash-light an carefully inspect the area
hope this helps
thanks for rating
Jan 09, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Not taking paper
yes, clean your paper feed roller with rubbing alcohol on a microfiber towel sounds like a traction problem.
Nov 07, 2007 | Dell 922 All-In-One InkJet Printer
Paper doesn't advance through the printer
Hi, Sounds very much like the feed rollers are worn out. If you can get to them without too much trouble you can clean them up with regular rubbing alcohol and a rag which will help the paper feed. You might also want to try unpluging the printer and trying to roll the paper feed buttons by hand and seeing if a piece of paper will feed through without catching anywhere. If it does catch somewhere, then you may very well have a small piece of paper jammed in the paper path causing the jam. Good luck.
Aug 25, 2007 | Lexmark Z31 InkJet Printer
138 people viewed this question
jasbo
jasbo
