Question about Panasonic Televison & Video
What are the best settings for a panasonic py800 42" tv - viewing, sharpness, contract, brightness, colour etc...
techman
  • 3130 Answers
SOURCE: Panasonic TC-78SS71A Television. Brightness fading.
Sounds like the picture tube is going bad or there is a screen voltage capacitor bad in the sweep power supply.
Posted on May 27, 2008
SOURCE: Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Posted on Jun 08, 2008
  • 518 Answers
SOURCE: Hi, I have just purchased the
The problem is that everyone has a different "taste" when it comes to these settings. I like to turn the color all the way down to start with. You should (if the set is factory adjusted correctly) have a black and white picture. If it's not B&W, then there's something inside the set that needs adjusted and you should get a service call. Then I adjust brightness and contrast to get the best B&W picture. Then I turn the color up until I'm happy with the color level, then I adust tint.
Hope that helps
Geno
Posted on Jul 29, 2008
  • 102 Answers
SOURCE: Samsung 42 shaow issues
This brightness irregularity is caused by poor voltage control in the horizontal scanning circuits. Voltage drops of this kind are usually due to aging electrolytic capacitors which lose the ability to maintain high voltage. This problem can be repaired but you cannot do it yourself. This type of TV can have DANGEROUS high voltages present inside even after it has been turned off for WEEKS. I'm talking HEART ATTACK voltages. Call a qualified service technician.
Posted on Oct 10, 2009
phil_frye
  • 295 Answers
SOURCE: I would like know how to reset settings for the
Usually factory defaults are set to the middle settings in your menu structure. If you have values then it would be the middle of the value.
Is there any certain reason why you wish to go into the service menus?
Blessings,
A/V Media Tech Guy
Posted on Dec 20, 2009
What are perfect settings for colour on my Toshiba 22KV500B?
It will depend upon individual viewing taste. Yet, contrast 65%; Brightness 50 to 60% and color 30 to 45% will give a satisfactory picture. https://electronicshelponline.blogspot.com/
Jun 30, 2016 | Toshiba Televison & Video
What is the correct picture setting for a vizio smart tv model E322AR?
Contrast = 60 to 80%.
Brightness = 40 to 55%
Color = according to personal viewing taste.
Sharpness = 15 to 20%
The best way to tune to a perfect picture is, set the color to Zero first. Without any colour, increase the contrast to at about 65%. Adjust the brightness to get a perfect picture in B/W. Then increase the color, according to your viewing taste. Compare the skin tone of a person. That's all.
Oct 07, 2013 | Vizio Televison & Video
I have a grundig GU19WDVD10 tv and the picture mode has got mixed up and the quality is not right. What numbers should the brightness, contast, colour etc be on? Thanks
In most cases, 75% contrast, 40 to 50% brightness and 35 to 45% color will be best. Adjust the picture sharpness control in between 10 and 25%
May 07, 2013 | Televison & Video
What is the proper calibration settings for a panasonic tc-p50s2n. I have used it for over a 100 hours
Do you have access to a test pattern or color bar ? .If you have a THX certified DVD ( some Walt Disney movies ) it will have calibration setup guide in the DVD menu.Or else you have to buy a calibration DVD if you are serious about your TV setup.
First you have to set the contrast and brightness using the Grey-scale pattern. Seven set of vertical bars slowly progressing from white to black. If set right you should be able to make out all the seven bars with out each merging ( or overlapping ) into the other. You will be able to see the line of demarcation between each vertical bars. Then set the color to taste.
If you do not want to purchase the above mentioned DVD disc a close setup figure for your Panasonic TV would be
Picture Mode = Standard ( Normal )
Picture ( Contrast ) ---- 50
Brightness ---------------- 50
Color ------------------------ 33
Sharpness ---------------- 50
Hue ------------------------- In the middle
This setting should give you a decent picture quality assuming your TV is new.
Apr 12, 2011 | Panasonic Televison & Video
Best settings possible for its color contrast brightnesss etc.....Im aware of roomlighting. my caliberations are numbered not percent. help
Find what the low and high numbers are and set them to the middle, e.g. 0-10 set on 5 This is the optimized condition from the engineers. Then you can increase or decrease each parameter to your likings.
Jul 05, 2009 | Hitachi Televison & Video
Making my HD tv look the best it can
If you have the halo 3 bonus disk use the THX optimiser on it, if not then the setting I use are:
Viewing Mode: Dynamic
Contrast: 60
Brightness: 50
Colour: 50
Sharpness: 50
Tint: Middle (need the lenses to set it properly)
Colour balance: Cool
Colour Management: On
P-NR: Off
I got both setup through HDMI atm.
Jan 06, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
What are the best picture settings for the 52" Sharp Aquos LCD
I'm happy with:
backlight +16
contrast +40
brightness +1
colour -13
tint 0
shaprness +2
although I found this setup but haven't tried it yet
backlight +5
contrast +24
brightness -7
colour +50 (review I found didn't say + or -. Try both
tint 0
sharpness -5
Len
Nov 30, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Oct 11, 2008 | Televison & Video
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Fixing picture (colour) setting
If your TV is not too ancient there should be a button that says auto set or return to default or default....try it. Tango....and hope this helps.
Dec 08, 2007 | Computers & Internet
Televison & Video Logo
61 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
