Question about RCA F36650 36" TV
Sound goes down
Sound will not stay up. We've tried the remote and on the tv. It will come on but then turns it's self down.
    Sergeant:
  • 280 Answers
Volume down button on the front of the tv is sticking. Try a little WD40 around the volume buttons then work them to make sure they are not sticking..
Posted on Nov 21, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 12 Answers
The down button on your remote might be stuck down. Try taking the remote out of the room or cover it up with something. Then turn the sound up at the set and see if it stays up. If this doesn't work, the down button on the front of the set may be stuck or have leakage in the button. This would require taking the set to a service shop. Another possibility would be a loose ground on the CRT dag which can cause this. this also would be something a service shop would need to take care of, as you could get a shock if you attempt this repair yourself.
Tv sound will not stay on goes down by itself
The problem is with the ckt that controls the manual keys on the TV.Disconnect it and the rest should work with your remote.
May 10, 2014 | Samsung DLP HL-P5663W 56" TV
HI i have a JMB LCD TV MODEL 42883 today it started turning its self, on and off standby,the standby light is flashing on and off i`ve even tried taking out remote battery but nothing works sometimes...
hi I have a JMB LCD TV MODEL 42883which has only worked for one week b4 the screen was cracked by accident everything else is perfect.would solve one of your problems your having with your tv.will sell it at reasonable price.07719651554 if interestd
Mar 01, 2011 | Televison & Video
I just bought a LG LCD 32 inch tv 2010 and the sound goes down after 20 minutes by it self is there any solution please help
If you are operating with remote I guess the remote is faulty. Try operating it with the remote placed in another room & observe if the sound still decreases, else the button(sound) on your TV is itself faulty. Since you have just bought it, its still under warranty - contact dealer.
If its the remote, then change the remote
Jan 02, 2011 | LG 32LG30 32 in. LCD HDTV
Front panel locked by accident- no original remote, only universal, code unknown. tv has since been turned off by unplugging, now it won't turn on. remote has also been unprogrammed because batteries were...
Hello
Three digit universal remote code for RCA are:-
000/ 003/ 004/ 005/ 007/ 009/ 011/ 048/ 078/ 082/ 083/ 094/ 096/ 098/ 099/ 101/ 102/ 103/ 107/ 113/ 129/ 133/ 167/ 179/ 181/ 187/ 188/ 194
Four digit universal remote code for RCA are:-
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Other ways to unlock RCA tvs
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won
Nov 22, 2010 | RCA 27R410T 27" TV
My sournd sound turns on then turns off can any one help
so is this sound on the tv or a sound system
May 03, 2009 | RCA F32649 32" TV
No sound and sound menu stays muted so cant adjust
Have you totally unplugged the TV?
If not do so for 10 minutes and see if it resets.
Try to find a remote that goes with TV>
Mastersage.
P.s. Make sure you do not have the saftey lock on. You can adjust the control;s from built in adjustments.
Mastersage!
Feb 14, 2009 | JVC AV-48P575 48" Rear Projection...
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
TV CODE
Try 191, 035, 208. No HOLD or SEARCH key? Try holding down the TV button(on/off light will come and stay on). While holding down TV key, press 1 button(key), on/off light goes off, let go of 1 key, and then enter one of the above listed codes. ON/OFF will blink three times if no good, try again with another code. If ON/OFF stays on, is good code. Try to turn off TV. If TV does not turn off try again with another one of the codes for RCA Remote Controls and ORION televisions. Mine worked with 191. Clara
Apr 17, 2008 | RCA RCR450 Remote Control
RCA F36650 36" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
