Question about RCA F31672ET TV
Acutally for f31665 (problems with screen, kinda)
The tv is doing something i just can't figure out. the video doesn't seem to be working. i've tried coax and rca inputs, and the sound works but there is no video. the menu still comes on so i'm assuming the screen still works. if you hadn't guessed i'm a newbie at this. please let me know of any ideas, thanks
  • Ben Stout Oct 06, 2006
    i've tried hooking up a dvd player via rca's and vcr via coax. i've done a little research and apparently my problem has something to do with faulty factory soldering. I kinda know the problem but can't find the bad circuits on the circuit board. Any suggestions????
    Novelist:
    Champion:
  • 275 Answers
What about broadcasts? Are you able to view TV stations? If yes, try checking the RCA cables, and also if they are plugged fully into the sockets.
Posted on Oct 02, 2006
I have a Toshiba 32a33 TV, I have tried to program channels into the TV but it doesn't work. I tried to do it both manually and using the automatic channel tuner but it doesn't work. What should I...
Either the tuner or the video IF stage circuit of your TV is faulty. Tuner has no repair, can be replaced as a unit. If the fault is with video IF stage, it can be repaired. But, both the work is skilled one. You must have through knowledge in electronics, and work experience to do this work.
Jul 21, 2012 | Televison & Video
Re, all i get is a distorted picture of the game screen. I've tried fine tuning the TV around that channel but it doesn't help.
hi sounds like the av sender inside the ps could be getting dodgy, have you tried it on another tv?
Apr 07, 2012 | Sony PlayStation (PS) Console
There was an electrical storm close to our home, we had a flash of lightning. Now we can't get a picture to show. The menu works, but nothing from satellite, Wii and DVD. Is there a way to reset...
Hi, You should have unplugged your set in a storm like that. You should have had a surge protector too. I believe you will be looking at a big repair bill. Good luck.
Jul 19, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
RCA 31" TV pakes high pitched chirping noise
Did you check the Horizontal Output transistor to see if it were shorted, and also check the MOSFET of the switching power supply.
Jul 25, 2008 | Televison & Video
Sony Trinitron 32 tv
1) Could be bad CRT ( picture tube )===no green==purple.
 2) Might be lack of green drive to CRT==bad transistor.
 Recommend analysis by technician--usually worth it if CRT ok.
Oct 22, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
54 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
