I am on laptop with vista home prem,have completed backup restore from wd 320 usb 2.0 allof my data is corrupted error codes like 80245003 appear cannot fix my laptop
    Scholar:
  • 195 Answers
Hi Earlbanga, Do you have an original Windows disk? If you do, just insert it and do a fresh Install, not a repair. And if your in windows you need to back up your important files first, because they will be lost. Good Luck.
Posted on Nov 04, 2008
Seagate expansion 2tb
Cause:
This problem is caused by an issue with the Windows 7 Backup and Restore utility when using drives with 4K Logical sector sizes, which are found on WD 2.5 TB and larger external drives. This is different from an "Advanced Format" (AFD) drive which use 4K physical sector sizes. AFD drives should not cause this problem.
Solution:
It is still possible to use a 2.5 TB drive or larger with Windows 7 Backup and Restore, as long as you don't need to use the drive with Windows XP. Using the WD Quick Formatter tool, select the Factory Default configuration to reformat the drive.
Warning: This tool will erase all data on your drive, so take the necessary precautions.
After formatting the drive to Factory Default mode, the drive will be usable in Windows Vista and Windows 7. However, the drive will not be recognized in Windows XP. This is the only way to get Windows 7 Backup and Restore to work correctly.
Jan 30, 2014 | Computers & Internet
Error when recovery with vista
It is an effective solution for repair your damaged or deleted BKF files due to sudden system failure, virus attacks, media malfunction, backup interruption etc. Using this software, you can easily repair your BKF files. If you want to use the demo version of this software, then you can go on official site :- BKF File Recovery Tool
May 05, 2012 | Computers & Internet
Hp pavilion a1102n winxp home. Blue screen after win splash logo, flashes too fast to read. 2x256mb. Dial up modem. Tried: removing modem, removing front usb FireWire media card slots. Removing one or...
Dear,
I saw your video and check the blue screen error. It comes for a friction of second and disappears but i kept my media player in slow motion mode and checked it. This error belongs to a missing registry file.
PERFORM THIS PROCEDURE for recovery.
A Stop 0xc0000218 error message means that a necessary registry hive file could not be loaded. This error message can occur if the file is corrupt or missing. To resolve this issue, you can reinstall the operating system and restore the registry files from a backup. The registry files may have been corrupted because of hard disk corruption or some other hardware problem.
This error message can also occur if the driver has corrupted the registry data while loading into memory, or the memory where the registry is loading has a parity error. In the latter case, turn off the external cache and check the memory chips.
To resolve this issue, follow these steps:
  1. Start your computer by running the Recovery Console, run the chkdsk /p command on the drive, and then restart your computer. Test to determine whether the issue is resolved. If the issue is resolved, do not complete the remaining steps. If the issue is not resolved, go to step 2.
  2. When Windows loads, press SPACE BAR when the "Load Last Known Good" message appears.
  3. Complete a parallel installation, and restore the registry files from a tape backup. To do so:
    • Reinstall Windows in a separate folder.
    • Restore the damaged registry hive from backup. This procedure is specific to the backup application that you used to make a backup. Consult the documentation of your backup application or consult the vendor if you need assistance. Typically, this procedure requires you to restore a system state backup to an alternate location, and then copy the appropriate registry files to the %SYSTEMROOT%\System32\config folder of the damaged operating system.
    • If you do not have a tape backup, include the backup of network servers and production workstations.
    NOTE: If Windows is stored on a FAT partition, you can restore the files by using another computer and by copying the registry hive files to the %SYSTEMROOT%\System32\Config subfolder.
best of luck!
Mar 07, 2012 | HP Computers & Internet
I have an hp dv9925nr laptop running vista home premium 64. I tried to reset to factory settings and now when I try to start up I get a boot manager error. It says \boot\bcd status 0xc000000f error...
Most of the boot up of problem because of hardware problem, registry missing or crashed, file deleted or changed.
You can boot up your Windows with Tenorshare Data Recovery WinPE.It allows users to burn ISO file to CD/DVD/USB flash drive directly.
Step 1: Download Tenorshare Data Recovery WinPE in any available computer (not from PC that can't boot up). Then launch it.
Step 2: Insert CD/DVD/USB flash drive to the computer, choose ISO image file. Here we take USB flash drive for example. Then burn ISO file into flash drive.
Step 3: Insert the burned flash drive to the unbootable PC. Run computer and press "F2", "F10" or "Delete" to enter BIOS setup.
Step 4: Use the arrow keys to select Boot tab, select Boot Device Priority and press Enter. Please choose 1st Boot Device to USB, and then press F10 to save setting. Now,you can boot up your PC.
If you have a backup for your Windows then perform a system restore to fix it.If not,reinstall it.If you have no backups for all your data,you can use Tenorshare to retrieve data under any boot up problem.You can get it from http://www.any-data-recovery.com/product/datarecoverywinpe.htm
Here is tutorial to guide you how to do --How to Recover Data from Computer Won't Boot Up?-Windows Data Recovery.
Sep 19, 2011 | HP Pavilion dv9925nr Notebook
Hello i have a problem with my nokia 3110c whitch is : when i flash my phone with phoenix i got this result : Flashing started Creating product data items list Product data items list created Backup...
Now what is the condition of the phone ? If the phone has still problem, uninstall the previous file you have installed and re-install this one3110c file.Select the product code 0544311 or 0556977.This two files can use universal.Use fully charge battery or insert charger when message prompt.I hope there will be no error.Thanks good luck.
Aug 16, 2011 | Nokia N70 Cellular Phone
Error 320 then 330 while trying to recovery complete system restore for vista home premium
These issues are normally related to registry conflicts and corruptions. What you can do is to try to fix registry entries by running a Microsoft tool called registry booster. You can download this file and run it on your system. Check the link that is posted below and then try to do a system restore again. If it does not work, maybe the issue is with the contents of the disk you are trying to use to do a complete system restore. Try to request another copy from your manufacturer.
Registry Booster
Jul 08, 2011 | Computers & Internet
Restoring files after using the Backup utility.
1. Plug in the USB drive that contains the data.
2. On the XMB go to Settings then System Settings
3. Go to Back Up Utility like before but
4. Choose Restore rather than Back Up
5. The PS3 does the rest
You can have the PS3 delete the data file from the USB drive by choosing Delete Backup Data.
Sep 18, 2009 | Sony Playstation 3 (PS3) Console
Sony VISTA...operating system can't be found
download from the internet..
http://isohunt.com/torrents/?ihq=vista
you need to instal first the Utorrent downloader..
Sep 11, 2009 | Sony VAIO VGN-FZ240E/B Laptop
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
