Question about Toshiba 52HM95 52" HDTV Projection Television
52hm95 flashing green screen
HI, I have had my toshiba 52hm95 DLP for about 2 and a half years now. I've had to replace the lamp twice, but now I have a new problem. Out of the blue the screen started flashing green (superimposed on the whole screen, over the television show). No matter what input I change the tv to I have the same result. It flashes with the consistency of a police flasher. Its a bright green color. If it is the color wheel, how do I get to it and clean it. Hopefully its that simple and expensive like a light engine. THanks in advance.
  • Lesgrey Dec 06, 2008
    No it just flashes period no matter what input I put it to. Hd, nothing, videogame, it doesn't matter.
  • thielectronick
    thielectronick May 11, 2010
    Does it flash on the Toshiba Menu? It is not likely the colorwheel but maybe the LVDS cable or a video board. Is it on HD too?
  • 375 Answers
SOURCE: Toshiba 46HM84 DLP Black and white pattern..
contact your dealer for service flashfor this symptom.(light tunnel)
Posted on Sep 05, 2007
SOURCE: toshiba 52hm95 no video
color wheel,located in color engine assembly.
Posted on Mar 28, 2008
SOURCE: Toshiba 52HM95 Light Engine
I just had mine replaced and it's basically every moving part in the TV. That includes several fans, light engine, lens, etc all in one component. The person who replaced mine got it from a place that has a newly-engineered model that is supposed to last longer. I can tell you that my replacement is not looking as good as the original and I am currently unable to get it to start up any more. Good thing there is a 6 month warranty, but the labor is no refund.
Posted on Sep 19, 2008
SOURCE: toshiba 46 in dlp will not turn on
It seems you might have a defective ballast, I mean you just replaced the lamp and it's still not working, the best way to go here is replacing the lballast, that must solve the issue, anyways for a second opinion discountdashmerchantdocom
Posted on Jul 24, 2009
SOURCE: I have a Toshiba 56HM66 DLP projection tv. The
My tv has the same exact problem have you figured out what it is ??
Posted on Jan 05, 2011
Toshiba 52hm95 lamp breaks after only weeks of use
It is as far as the set is concerned, it sees the lamp not on.
Most likely cause would be the lamp ballast that drives the lamp.
Dec 20, 2012 | Toshiba 52HM95 52" HDTV Projection...
Toshiba DLP green light flashes 5 times
Inspected lamp?
Does lamp fire even for a second or two?
Any high pitched whine or fan like sounds?
What I usually do if working on a set like this is rule some things out and then Google the model to get to the Toshiba site---see if your model and blink code are listed there.
Apr 11, 2012 | Toshiba 52HM95 52" HDTV Projection...
I have a model 52HM95 installed new bulb worked for awhile 2days when i turned it back on got sound no picture then it kept turning on and off now all i get is the green and red lights flashing on and...
It looks like you have a weak ballast issue this is a common problem with DLP sets, this ballast board starts to wear out with time and use the lamp needs at least 150w 12vdc to turn on and if your ballast board only feeds it 120w or 130w it will not be able to turn on another thing that this ballast due is gather enough energy ( 150w ) to turn on the lamp then get weak again( 120w ) and can't maintain the lamp on and turn back off
Sep 13, 2010 | Toshiba 52HM95 52" HDTV Projection...
My tv was accidentally unplugged while it was still on and when i turned it back on there is audio no video and the green light just flashes next the to the red light and the tv turns on and off by itself...
Hi
Thanks for using FixYa. From what you have described it seems to be a shutdown circuit problem, and a problem in the section of the TV that provides High Voltage to drive the raster creating circuitry. Usually the issue is with the bulb going bad however, as you have already replaced the bulb few months back, so in your case this would also be the DLP related circuitry which includes the light engine (white light bulb/Color wheel drive circuitry or LED array, DLP chip and associated circuitry). If you want to do the repair yourself then it is highly recommended that you should have knowledge of internal circuitry of the TV, if not then it is always better to take assistance from a qualified repair tech. The cost of repair will be around $300 including labor if you get it done by a professional.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 17, 2010 | Toshiba 52HM95 52" HDTV Projection...
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Red and green light flashing and system keeps rebooting itself with no pictures on the screen. what is the problem with my TV?
Have you replaced the lamp since purchasing the unit. If it has been at least two years since you brought the television, then its time for a new one. The lamp door is usually located on the back of this set but some times on the side. Remove the lamp and it may be shattered in its housing, replacing it with Lamp part # D95-LMP lamp.
Nov 07, 2009 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 52" HM95 DLP green and red LED Blink>
If Fan behind Lamp is not running lamp will not come on,also CK blaster board.
Aug 09, 2009 | Toshiba 52HM95 52" HDTV Projection...
Screen dark,wont stay on. 52hm95
Here's the online manual for your TV:
http://www.tacp.toshiba.com/tacpassets-images/models/42HM95/docs/42HM95_om_e.pdf
Read the section about the red/green lights in front. It sounds like the lamp went out. Mine consistently goes out once every year to year and a half. If you plan on keeping the television, purchase two bulbs, so you have one on hand in case your new one goes out.
Good luck.
Apr 19, 2009 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 52hm95 no video
Mar 17, 2008 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 52HM95 52" HDTV Projection Television Logo
142 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
