Question about Toshiba 42H81 42" Rear Projection Television
Toshiba 42H81 Hyperboard
Hello Premtech,
I have a Toshiba 42" 42H81 TV and have the hyper board problem. It doesn't seem to affect the component inputs, just the RCA inputs and Coaxial cable inputs. It seems to have gotten progressively worse.This is the 2nd or 3rd time, except this time the warranty has run out. I would appreciate it if you would send me a manual or schematic for this set. I am going to pull the card and repair it myself. My email: tominflorida@juno.com
Thanks a bunch,
Tom
  • 2 more comments
  • tomalex Nov 04, 2008
    Bill,
    Thank you for the manual. And the caution. I am doing research on proper soldering techniques. I understand there are 11 caps that will need to be replaced. I am assuming that is all I need to replace.
    Tom
  • tomalex Nov 07, 2008
    Bill,
    I'm looking for a vendor to buy the caps. Based on the manual you sent me, the Toshiba part# for the caps is 24619040. After that it lists the part as: Chip, 10pF, +/-20%, 16V. Notice it says "10pF" (picofarads?), not 10uF. Is this a typo? Or is the 10uF intended to be an upgrade?. I have seen 10uF mentioned on this web site as the caps to order. Could you please clarify? I wanted to make sure before I ordered. Thanks again.
    Tom
  • Anonymous Nov 25, 2008
    I have this same problem (warm up 20 minutes) now I am an electronics assembler, these newer components don't hold a charge like the older through hole capacitors do correct? I will be using smt hot tweezers to remove the capacitors. I noticed you specified 10pf tolerance and voltage but could you tell me the size I might have them at work and not have to order them.
    My second problem is a buzzing/humming coming from the speakers does that have to do with the same problem or is that a completely different issue?
    Thank you for taking the time to help me
    Regards
    Catherine
  • scottgarry Jan 11, 2009
    Could I also get the service manual. I have a guy wanting to charge me 300.00 to do this fix. I am also a CET and can do the work just didn't know what the problem was. I paid him to come tell me what it was, so I need to fix it now
  • 934 Answers
Tom,
I'll send the svc manual directly following this post, but as a word of caution be EXTREMELY careful removing the smd caps. You can easily damage the traces and make the module useless.
Bill
Posted on Nov 04, 2008
  • William Rayburn
    William Rayburn Nov 04, 2008
    That should do it Tom. They're smd cap so once you desolder each pole there will also be a spot of glue to contend with in the center of the cap. Use a tiny jeweler's screw driver to carefully lift each pole while applying heat (if necessary). Don't want to get it too hot and lift the trace as well. Use mini camcorder caps as a replacement, bending and cutting the poles to fit. Place a little spot of solder on each pad of the trace and position the new cap on top. Then just a slight touch of heat on each pole should weld the new cap in place.
    BTW the cap positions you'll be replacing are:
    1. Cx261
    2. Cx270
    3. Cx230
    4. Cx178
    5. Cx221
    6. Cx250
    7. Cx670
    8. Cx241
    9. Cx541
    10. C514
    11. C5030
    Good Luck!
    Bill
  • William Rayburn
    William Rayburn Nov 07, 2008
    Most techs use the mini camcorder caps, for two reasons, and simply bend and cut the leads to fits the board. First they are a more reliable cap and secondly easier to install, especially the two up and near the wall of the module.
    I would order those from Glen at Acme Sales in Florida along with the other bits of stuff you'll need to complete the job. Don't order by part numbers you have in the service manual those are smd caps and I'm fairly sure you don't have a flow station to put them on with...
    Bill
    William Rayburn, CET
    Premium Technologies
    PO Box 442
    Long Beach, WA. 98631
    360-642-4993
Toshiba/ 42H81 / hyper board
You can either yrplace your Hyper board, or replace all the serfice mount capacitors in it. The cap replacement fixes this 90% of the time.
May 09, 2012 | Toshiba 42H81 42" Rear Projection...
Toshiba 57H82 problems
Val,
It's sent via Pando and you should get a link to it in your mail. To open it you'll need Pando, it's a free download if you don't already have it... The hyper module on that has about 10 caps that are common in that failure. If you need anything off board don't hesitate to ask.
Bill
PO Box 442
360-642-4993
premtech@willapabay.org
Jan 07, 2009 | Toshiba 57H82 57" Rear Projection...
Pic bad
Repair the hyper module.... See some of the previous posts for this problem...
Bill
Oct 28, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 50H82 hyperboard caps
Service manual won't help much in the hyper board and that's likely the problem.. Simply remove the hyper board and open the can. Inside you'll see a number of smd caps. There are 11 10mf/16v that need to be replaced...
Bill
Jul 26, 2008 | Toshiba 57H82 57" Rear Projection...
No image on my TV
Bad hyper module = no longer available = have qualified tech
rebuild yours = replace bad caps on board...............T.
Dec 08, 2007 | Toshiba 42H81 42" Rear Projection...
42h81 RPTV
Rebuild hyper board = replace bad caps on board................T.
Nov 04, 2007 | Toshiba 42H81 42" Rear Projection...
Wavy picture on all sources
This is a somewhat common problem having to do with the hyper module, Toshiba p/n#23148024 There are a gouping of 16v/10uf caps in the hyper board that fail causing the distoritions you're describing here. At first, as the module begins to go bad the distoritions are present and usuallly go away or fade significantly as the set warms up - - this gets worse until the distoritions don't go away at all... From what you're saying you're at stage three already. :) You have a few of options: (1) local repair shop pull the board and replace the caps or module; (2) Pull the module yourself and repair or send it in for board level repair; or (3) pull the hyper baord, order a new one and put it in yourself. For 2 or 3 you'll be better off having the service manual and if you need it just email me privately and I'll send it. Make sure in your request to tell me the model number and reference something of this repair so I have a clue of what you need. BTW the hyper board is on the left side of the unit mounted vertical on the signal board inside a metal can. Good Luck Bill
Jun 10, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 42h81
Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
Apr 27, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 42H81 - Constant jumping picture on scren
it needs the hyper module replaced might as well have em do the stk packs too its too old to be a lemon the part that was replaced was not new it was in someone elses tv and had problems there too the trick is to find someone that will fix it so it lasts
Dec 05, 2006 | Toshiba 42H81 42" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
555 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
