Question about JVC Televison & Video
Jvc gd-v4210pzw screen problems
The display on this unit has a problem. The display is split into two halfs. The split occurs horizontally. Both halves display a complete series of vertical lines that completely cover the screen, however, they do not mirror one another. The colors of the lines change to track the program that is playing. The audio is fine. The unit recently snapped out of it for about about 5 minutes and then returned. I gave it a good slap on the back and the unit corrected itself for a while but has since returned to its problem state. Any suggestions would be greatly appreciated.
    Top Expert:
  • JVC Master
  • 75,599 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. https://youtu.be/wUpnETSm6_k
Posted on May 22, 2017
fire sine
  • 382 Answers
SOURCE: Screen Changes and Comupter freezes
It may be possible that the power supply, display and or logicbpard may be having issues. Apple recommends resetting the pram and nvram. If issue persists reset SMU. YOur machine is 6 months outside of the original warranty, but if you purchased the 3 year extension plan, you may want to take action on it.
http://search.info.apple.com/index.html?q=imac%20g5%20reset%20pram&lr=lang_en&search=Go&type=
http://search.info.apple.com/index.html?q=imac+g5+reset+smu&type=&search=Search&lr=lang_en&search=Go
Keep me posted.
Posted on Nov 11, 2007
  • 1153 Answers
SOURCE: Vertical portion pixelats then forms
Note
In some cases, there are minor defects in some parts of the screen. Points that do not light, points with
brightness different from that of the periphery, or points with color different from that of the periphery.
Some pixels will always be on or always off. Please note that this is not a malfunction. So what this says is that it's not the Plasma Cell problem, its more like a bad board inside. You will need more info like schematic and find out which area the bad part is in.
Posted on Jan 04, 2008
  • 1030 Answers
SOURCE: Thin black horizontal lines on JVC PD-42WV74 EDTV
horizontal line is an idication of a bad board known as a x driver board. Their may be a slight possiblitliy it can be a small ribbion cable that runs from the driver board to the plasma panel. Another possiblility it can be a bad panel... but from the symptoms you describe i would first have to look at that driver board. and the sympton that getting worse makes me lean toward a bad ribbion cable.. if that could be reseated....well that the first thing as a technician i would try. Carefull Television generate dangerous voltages.
SOURCE: solid vertical line on JVC 42WV74
umm trying using it more, i had the same exact problem and we started using it more and more it has recently gone away.Check the wires as well (plug them out and back in)
Posted on Feb 22, 2008
Slinteriors
  • 8617 Answers
SOURCE: No picture, Horizontal line center of screen
you either have a bad solder joint at the yoke plug. Thats the large group of wires coming off the yoke on the picture tube neck, Resolder where that plugs enters the chassis the pins may have a crack in the solder, The other item to check is the solder around the horizontal output which is mounted on the heat sink near the flyback transformer. That Transistor could be open as well and if so it will need replacing. Try the solder first however as that seems most likely.
Posted on Mar 30, 2008
There's a blank bar that runs horizontal in the middle of my TI-84 plus that's about 16 pixels wide(high?). It's the same color as when the device is turned off. I've tried a memory reset and no results....
SPLIT SCREEN.
It sounds as if you might have split screen mode on. I've got a TI-83 as well as a TI-89 Titanium, both offer a split screen mode. The latter allows for choosing which applications are displayed on each half screen. I am presuming that you may have accidentally put your TI-84 in this mode.
So, if it is a split screen deal then all you have to do is go to the mode screen, find the option for switching from split screen to full screen, and switch it back to full.
I hope that helps. Give us your results!
Adios
Mar 11, 2011 | Texas Instruments TI-84 Plus Silver...
Why have i only got half a screen
The calculator can be split in two. This is done by selecting certain MODE options as shown on the line that starts with FULL
In the Full option the screen is complete (regular screen configuration)
If you highlight HORIZ and press ENTER the screen will be split HORIZontally as
The upper part is for any graph and the lower part for the main calculator screen
Similarly, if you highlight G-T and press Enter, the left part of the screen displays the Graph screen and the right part the Table screen.
These are the normal instance where the screen of a Ti8*Plus is split in two.
Do you recognize any of these?. If you do just select Option Full in MODE screen to restore the full screen. If you do not, then I have no idea why you only have half a screen.
Aug 01, 2010 | Texas Instruments TI-84 Plus Silver...
JVC GD-V425PZW no Picture
motherboard needs replaced, to test take a flashlight TV on and shine on screen from above at an angle, do you see a faint image, replace MB
Oct 30, 2017 | JVC GD-V425PZW Television
Samsung LCD television screen fault
My new TV LCD Samsung LC32C530 Series 5 has one half darker and with less contrast than the other.This is noticeable now always. There is a distinct and clear division down exactly half the display which separates the dark and light sides.. Any ideas?Thank you.
Jul 08, 2008 | Televison & Video
Screen
Problem with motherboard display unit.you need to repair the unit.
May 28, 2008 | Computers & Internet
Display shows a set of black bars
tape guides are out of adjustment, need to have brought in for service.
Jan 29, 2008 | JVC GR-D270 Mini DV Digital Camcorder
GD-V425PZW powering off
Hi Boris,
I cleaned out the fans on top of the unit - all seemed OK
basically overheating i think
Jun 13, 2007 | JVC GD-V425PZW Television
JVC DVD player stuck in Split screen
the player is set to progressive scan mode.use relevant button on remote to reset to interlace mode. Duane,S/Africa
Mar 11, 2007 | JVC XV-N320 DVD Player
Grey line horizontally across screen
yOU ARE HAVING A PROBLEM IN HORIZONTAL CIRCUIT OR IN YOUR POWER SUPPLY kindlyu take your T.V tO A QUALIFIED TECH to repair it.ypur problem could be a faulty capacitor ,flyback or horizontal output transistor.
Feb 16, 2007 | Sony WEGA KLV-26HG2 26 in. HD-Ready LCD...
Televison & Video Logo
70 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
