Question about Makita 12 Volt Cordless Drill/Driver Kit
Drill motor properties
We r doing a project which concerns the use of a drill motor to run our robot.i needed all da information regarding the properties of drill motor, its drawbak and why it is more efficient den other wud be a great help if u guys cud help us.thanx
  • 99 Answers
The main thing with cordless/battery (direct current) powered motors is that they have a static magnet instead of field windings. The main rotary part of the motor is still wound in segments but it uses dual magnets for the static outer part of the motor. These magnets have to be aligned properly for the motor to run at optimal performance. If they are too far out it won't runa t all. The magnets are also prone to cacking or breaking if subjected to heavy impacts (ie drill dropped from ladder). The other thing is the amount of time they operate at optimal performance but this is nly really affected by the battery capacity and amount of load the motor has to operate. Alternate current motors with wound field coils are alot more powerfull and abviousley have no time limit, but you would only then be able to operate your robot while it is plugged into a socket. The new lithium ion batteries are a lot longer lasting, and stay at peak performance for longer, but when they start running out they tend to just stop instead of slow down.
Posted on Nov 04, 2008
I have a Palmgren model 80320 drill press that will not run and i need some help.
Could not find a manual for this machine. Go to this website,, and request information.
Sep 19, 2014 | Drills
Disassembling a robot coupe mp450
First you drill out the plastic plugs to acess the torx screws holding the housing together. Remove 4 motor mounting screws to separate from shaft.
May 28, 2013 | Robot Coupe MP450 Handheld Blender
Cant get drill bit to stay
go bak to homie depot an git da guys in da contractor part to set da gun up for u! then have them giv u a show an tell. ifin da drill bit is in wrong nutin works right.?? so u gota go outa ur way to git-r-dun. show an tell wurks best!!
Jun 10, 2012 | Senco Corded Collated Screwdriver
Wall-e u comand robot, will not move forward he just turns, can i fix the right wheel?
On the in side of the body (cube) is a white gear the size of a 50cent coin. It is pressed on a drive shaft. The inter ring is cracked and slipping. It makes Wall E turn around and around. I'm looking for a replacement or some one with a makerbot to reproduce it. If any one finds one let me know at.
Apr 19, 2012 | Disney Wall-E U-Command Remote Control...
Dewalt 36v SDS 234 drill issue! Could someone please help? When I pull the trigger on the drill the motor runs but the drive only turns for about 1 second and stops even though the motor is still running....
DeWalt says:
Number of drilling modes
3 modes. Rotation only, hammering with rotation, or hammering only with rotation stop for light chiselling applications in tiles and plaster and impact stop mode for rotary drilling only in wood and steel.
Maybe yours is doing the second one?
Dec 02, 2017 | Dewalt Drills
When using my panasonic 12v ey6409 drill there are sparks and smoke coming out at the rear, should I be concerned.
the tool with the brake will throw some sparks when it creates the short to stop rotation, but the SMOKE is an indication of a burnt motor and yes you should be concerned. Do you smell a burning odor when running if so the motor will soon fail.
Jun 30, 2010 | Panasonic Drill/Driver Kit 12 Volt
My roomba discovery will not operate on the clean or max buttons, will do the spot clean and goes forward then circles. Turns itself off and plays a little da do da do do do do. I have emptied tray,...
If your Roomba goes "uh-oh", beep-beep-beep, that's a 3-beep error code, indicating that your vacuum motor is stalled. Remove the grill from the outside (back) of the dustbin and make sure that the impeller (looks like a fan) turns easily and is not clogged with dirt. Then try to run the robot with the bin ON but the grill OFF. You should be able to tell whether the vacuum impeller is spinning. If not, you'll need a new bin. You can confirm wth customer support by calling 1-877-855-8593.
Jul 16, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
Projection TV
Hi again,
it would seem that you posted multiple times. Please see your "Ask Me" post for a proposed solution to your concern.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 17, 2008 | Televison & Video
Projection TV
Hi again,
Hopethis be of initial help/idea. Pls post back how things turned up orshould you need additional information. Good luck and kind regards.Thank you for using FixYa.
Nov 17, 2008 | RCA HD50LPW175 50" HDTV
Makita 12 Volt Cordless Drill/Driver Kit Logo
147 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
