Laptop shutting down
My laptop shuts down while watching internet videos. It used to be just on mozilla so I would always watch on IE. Now it occurs on IE also. Now I can watch DVD's for hours and it never shuts down. Why would this occur just by watching internet videos? It now happens within seconds of the video starting so how can this be an overheating problem? It sounds more like a software problem, but then again if I knew the correct answer I wouldn't be here!
Thanks for the help.
  • johndoe202 Nov 04, 2008
    I don't know how to edit my post. Last night someone suggested I download an updated version of Flash player. I did that and have not had a problem since! I knew that it couldn't be an overheating problem which is what most suggested because I can watch DVD's for hours with the temp going to 100 degrees. CHECK FOR SOFTWARE PROBLEMS FIRST BEFORE YOU GO TEARING APART YOUR LAPTOP.
    Thank you manjunath for your interest.
  • manjunath n May 11, 2010
    can i know which model of laptop you are using...
    Sergeant:
  • 177 Answers
I think you need to disable the power saving options which you will find in Control Panel -> Power Option. Make sure that every thing is set to never under When Computer is Plugged in.
I hope that this will solve your problem
Posted on Nov 26, 2008
I can't see my Netflix movie on my laptop I can hear it but I can't see it
Shut down other applications when watching Netflix on your computer.
If you are watching Netflix on a Windows computer, it uses a program called Silverlight to play the video. If your processor goes above 80% usage, Silverlight will shut down the video and play audio only.
Mar 16, 2015 | Computers & Internet
When I've been watching videos on the Internet for a long time or when i keep switching to different videos the window becomes unresponsive . Some times it occurs while I'm watching something . At first...
update the IE or switch over to Firefox.......you may also want to look into more ram for laptop....(and this may occur because others are on the same web site at the same time as you)
Aug 28, 2010 | Computers & Internet
I was watching a video online when my laptop just shut down and turned off without warning. When I attempted to turn my laptop back on, it began making a high pitched noise! I turned off my laptop and...
To avoid this when watching a movie or lots of video's prop up your laptop with pencil or something else small and slender under the back. Just so the laptop isn't flush with the table or desk. You want airflow under the laptop. It shut down because of overheating to protect itself. Watch videos/movies can be very cpu/video card intensive driving up the temperature. Best of luck, Ravi Shanghavi
Aug 18, 2010 | Acer Aspire 6920 Notebook PC
Laptop gets warm near touchpad , shuts down
Sounds like it is overheating and then shutting down. Is the laptop on a hard surface or a lap or blanket? You need to have air circulation.
Mar 13, 2010 | Medion MD 96340 Laptop
1st: can't open gmail w ie; 2nd ie keeps shutting down
Hi, It seems that you might have installed some addons for IE and now you are in the situation. All you need to do it open Internet Options from Control Panel. Then in Advanced tab, click on Reset. Resetting Internet Explorer resets all settings to manufactures' default and in the process you will lose all saved passwords on Internet Explorer and you will have to re-enter them again upon use. Once done, fire-up IE and click on Tools menu > Internet Options and reset IE from Advanced tab once again from here as well. It means you will reset IE two times, first from Control Panel and then from IE window itself. Once done try to use IE and see the result.
However there are few addons available with Mozilla Firefox that resembles IE inside and opens all webpages that requires IE only. Download Coral IE Tab from: https://addons.mozilla.org/en-US/firefox/addon/10909
Installed the addons and switch the view to IE to open all webpages that supports IE only.
Cheers!
Mar 02, 2010 | Computers & Internet
Suddenly shutdown my laptop what is a problem i
Hello my friend,usually laptops when are overheating because of the processor or graphic card they start restarting or shutting down.Was your laptop warm when shut down or you was watching video or playing a game?
Feb 06, 2010 | Compaq Computers & Internet
Dell Inspiron Mini 10 abruptly shuts down every time I watch video
A few things may cause this (1) your Network (2) your Network Strength (3) your Anti-Virus. Cheek all this to make sure there are ok and if there are and the problem persist, Troubleshoot, and if it continuous give it to a technician near you. Cheers
Dec 06, 2009 | Dell Inspiron Mini 10 Notebook
Videos wont play
Was the direct lan still through the Belkin router? Plug straight in to your cable, dsl, satellite modem and see how the video is. Next try pcpitstop.com and run a full test. Might just need to wipe temporary internet files or whatever that full test says. N/M their defrag if you have at least 1/2 of your harddrive empty..they always say that.
Aug 30, 2008 | Computers & Internet
Power failure
your laptop may become overheated and that is why it shuts down, make sure the laptop is on a hard service so that the fan can get air. hot weather can cause problems as well.
May 28, 2008 | Toshiba Qosmio G25-AV513 Notebook
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
