Question about GE JTP15 Electric Single Oven
GE JTP17 convecton oven will not turn on
All panel functions work but when the oven temperature is set, the oven starts then shuts off after 30sec. Oven door is completely closed, there is no child protection and the oven has never given any problems until this. I reset the circuit breaker after 30min. with the same result. I disconnected/reconnected all wire harnesses when the oven was off to see if there was a bad connection but the oven still does not work.
1beertap
  • 32 Answers
SOURCE: ge oven door locked
You oven is locked because it is self-cleaning. Some how the handle got moved and it initiated. You may need to let the oven finish self-cleaning. Usually, it can take about an hour to complete the process. Afterward, the oven will beep when done and your oven can be opened. Good luck.
Posted on May 31, 2007
Powerman
  • 68 Answers
SOURCE: Ge Electric Double oVen
This may be related to a problem I have helped others solve. The solution is available free at my website. I have at last count helped over 1000 oven owners with a similar problem. http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf Hope it works for you too.
Posted on Aug 09, 2007
SOURCE: "door lock" light stays on and oven won't work
This happened to me, had the appliance repairman come out to fix. He hit and held a combination of buttons on the oven controls and reset the panel somehow. But now I don't know what he hit to clear it. Do any of you?
Posted on Jan 16, 2008
vest6
  • 196 Answers
SOURCE: "Door Locked" flashing on GE Oven JTP15 - can't unlock
The problem may very well be in one of the micro switches on the self cleaning motor bracket. These switches control the electrical flow to the heating elements. In the owners manual there is/should be a chart that lists the unlock and safety combinations. This would be your best source of information.
Posted on Jan 26, 2008
voodoomox
  • 1689 Answers
SOURCE: Flashing locking door light
hi wega,
the door's locking mechanism is controlled by a switch when you shut the door down. much like the light switch on your refrigerator. when you initial closing the switch for locking the door will be triggered does locking the door.
there is a possibility that this switch on your oven is press / stuck that is why it keeps on saying "locking door" which will eventually never be completed.
Find the switch on your door panel, this is usually near the hinge of the door. it can also be safely located with in the hinge assembly, if this is true, there will be no buttons or holes visible.
if you can open the door panel up or remove the casing you will be able to locate the switch on the door hinge and its assembly.
hope this helps.
voodoo
Posted on May 16, 2009
My G.E. oven shuts off by itself
Sounds like an issue with the thermostat . If stove has electronics perform a reset to factory defaults. If that does not resolve the issue look at the thermostat being defective.
Sep 20, 2017 | Ovens
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    GE mod.JDS27G0P2BG Oven Wont start
    You have a bad electronic control board.
    No repair.
    It must be replaced.
    Feb 21, 2009 | GE Profile JTP18 Electric Single Oven
    GE Model JKP12G0P2BG Wall Oven Bake Element Not Working Properly
    The temperature sensor is bad. The broil element will work even if the temp sensor is bad but the bake element will not. If you measure the resistance across the contacts on the sensor, it should be around 20 ohms, if it is much higher (1000+), then it is bad and should be replaced. It is just as easy to replace as the elements and looks like a small pencil sized rod in the inside top of the oven. Let me know how this works out for you.
    Benjamin
    Nov 19, 2008 | GE JGRP17 Gas Single Oven
    GE JKP45 double wall oven shuts off
    This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
    Nov 07, 2008 | GE JKP45 Electric Double Oven
    What is the reset button for GE Profile JTP18?
    For me the solution was in the temperature sensor. The Locked light kept flashing and the door locking mechanism kept cycling when the door was shut or if I just held the oven light switch in the closed door position. After replacing the control panel I still had the same problem. Next I turned off the breaker and then took off the wire covers on the back of the oven and disconnected the temperature sensor. I then checked the continuity of the sensor which was fine. With the sensor still unplugged, I turned the breaker back on and the panel said locked but the locking mechanism was not cycling. With power still on to the oven I connected the temperature sensor. It worked. All I had to do was press the clear button on the touch panel and everything was fine. I turned the breaker back off and reassembled the oven. Hope this helps.
    Oct 12, 2008 | GE Profile JTP18 Electric Single Oven
    GE JTP15 Electric Single Oven Logo
    114 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Steve Allison
    Steve Allison
    Marvin
    Marvin
    Are you a GE Oven Expert? Answer questions, earn points and help others
