Question about Pitney Bowes C180 Copier
My copier powers on without errors but doesn't copy
My copier powers on without any errors but does nothing after that. The screen displays "1" copy and none of the buttons do anything except for the "energy saver" button which works as it always has. Any ideas before I call Pitney Bowes? Is there any way to reset all the settings or something? Thanks!
  • 69 Answers
Hi im jules_09,turn it off first then turn it on for a 5 sec.try using a automatic voltage regulator
Posted on Oct 04, 2007
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 28, 2014 | Office Equipment & Supplies
Disable the Key counter on my Konica 7130
HI,
Please refer the manual by clicking on the below link.This will solve your problem.
http://help.nceas.ucsb.edu/images/2/2a/Konica.pdf
Oct 07, 2008 | Office Equipment & Supplies
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Feb 22, 2013 | Konica Minolta Copier Toner 7055/7065...
Erore code
You can try to clear it with " press the yellow clear botton, then the numbers 1 - 0 -7 , then press and hold the red clear stop botton, till the screen changes... Then turn the MAIN POWER switch OFF & then back ON. If that will not clear the code, then let us know what the error code is , that is displayed on the display screen.... Good Luck
May 24, 2012 | Ricoh Aficio 450 Copier
Hi, I've APC UPS ES 500 connected to my desktop computer. Have 1 year old battery but when checked without load displaying 12 V. Issues are: a. ups doesn't supply...
A battery showing 12V without a load attached means nothing. You probably have one or more weak cells and they simply cannot supply enough power. I would try a new battery before I try anything else.
Jul 21, 2011 | Office Equipment & Supplies
Error 1203
hi..
error 1203 means either or both cartridges have short circuited and needs replacement..
You will need to perform the following steps to find out which cartridge is defective:
1. With the printer turned ON, open the front cover and remove both cartridges from the printer.
2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer.
3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
1. Turn the power OFF.
2. Open the front cover.
3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover:
4. Reseat both cartridges in the printer and check for the error.
5. If the error still displays, then remove the color print cartridge.
6. Close the cover.
7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
9. Remove the black print cartridge and reinsert the color cartridge.
10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Apr 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Fix system error
Please click on the below link or copy the URL and paste it in your web browser. Follow the steps..
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:93:0:0&docid=ENUS547
OR
If you are getting any type of 'CLEAR SYSTEM ERROR' on the LCD screen of the printer, please follow these steps:
1) Remove the power cable for 2 minutes and the USB cable from behind the printer.
2) Press and hold down the stop clear button and reconnect the power cable back to printer.
3) The printer LCD screen should clear the memory error.
4) If the same error message persist on the LCD screen, please follow the instructions below.
5) Unplug the power cable for 2 minutes and USB cables from behind the printer and open the printer cover and remove both ink carts.
6) Repeat step 2 and Install both cartridges then the screen will display Cartridge's clean, press start.
Thank you........
Sep 28, 2008 | Lexmark X63 InkJet Printer
FAX
Where you able to scan and make copy without any problem...?
You can try a Partial reset which would reset the printer for any errors, Partial reset is: Unplug the power cord from the printers end with the power still on, and then press and hold the # and No 3 Keys in the All-In-One and insert the power cord without releasing the keys, it will display in the screen as partial reset
Aug 28, 2008 | HP PSC 2210 All-In-One InkJet Printer
Display
Yor LCD screen may need to be replaced.
Jul 24, 2007 | Brother MFC-5840CN All-In-One InkJet...
94 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
Marvin
Marvin
john h
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
