Question about HP OfficeJet J4580 All-In-One Laser Printer
This error will not stop coming up on my computer
The error says "A required component was not found or was improperly installed. Reinstall the hp photosmart software that came with the device, and try scanning again. 8, [(6,0,-2147467262)]" I have uninstalled and reinstalled three times. This is driving me crazy. How do I fix?
  • goodnufco Nov 19, 2008
    me too, and I have tried to install HP all in one C5200
Navigate to C:\Program Files\HP\Digital Imaging\bin
or C:\Program Files\Hewlett-Packard\Digital Imaging\bin
Double Left Click on the executable file:
hpqdstcp.exe
You will NOT see anything happen but it will get your program destinations setup correctly and hopefully remove the error. This sometimes happens when you change printers and old stuff stays on your PC.
Hope this helps.
Posted on Aug 30, 2009
    President:
  • 2,692 Answers
Have you been to this page ,downloaded the latest software and drivers for your model printer?
Have you gone through al of the FAQ section?    If everything on the above websirte fails,their is always, HP total care.
No. I don't work for HP. Just a free answer from someone who has been their.
http://h10025.www1.hp.com/ewfrf/wc/product?product=3645100&lc=en&cc=us&dlc=en〈=en&cc=us
Posted on Dec 28, 2008
Hp l1906
Click Start > Run type dcomcnfg.exe
then in the Component Service window:
Component Services > Computers > Right click on My Computer > Properties > MSDTC tab > Security Configuration ... (Button) > check 'Network DTC Access' > select 'No Authentication Required' option > OK!
see below link to know more:
http://support.microsoft.com/kb/899191
Jul 18, 2013 | Computers & Internet
When i try to scan i get a message that reads " A required software component was not found or was improperly installed. Reinstall the HP Photosmart cd that came with the device". I don't have...
First of all unplug the printer from the computer and then use revouninstaller (use the free version!) to completely uninstall the support software - use medium and it should delete all file and folders.
Switch off the computer and restart still with no printer connected.
Run the software that you have downloaded but do not connect the printer until you are told to do so by the software.
http://www.revouninstaller.com/
Mar 02, 2011 | Office Equipment & Supplies
When I startup my computer I get the following message: hpmon06.exe. unable to locate component failed to start because hpzjrd01.dll was not found. What is required and how do I resolve this??
The hpzjrd01.dll file is associated with HP printers and is installed on your system with HP printers. i recommend you reinstall the Hp Printer drivers/ softwares
Dec 30, 2010 | HP Computers & Internet
Apple Application Support was not found. Apple Application Support is required to run iTunes. Please uninstall iTunes, then install iTunes again. Error...
How did you uninstall itunes? If you run into an error, or your computer while your itunes was installing, it could leave things behind messing up all the other installations as well. What you need to do is first of all make sure you don't have any instances of itunes open, or trying to be opened. Then you can go ahead and run the uninstaller on itunes.
Then you will need to go into explorer (windows+e, or right click on your My Computer icon and press "explore" from the menu), navigate to C:\Program Files\ and delete the itunes folder completely. If you get an error saying something to the effect of "This file/folder is being used by another program, please stop that program and try again." go ahead and restart your computer, and try to delete the folder again when your computer comes back up.
Then try and reinstall it, making sure that you are downloading the correct version of itunes for your operating system.
Dec 27, 2010 | Apple iTunes
Hp color laser jet printer is displaying error 59.co on the display pannel
Developing disengaging motor error
. Run the component test to verify that
the print developing disengaging
motor is working correctly.
. Reconnect the connectors J468 and
J1020 between the developing
disengaging motor and the DC
controller PCB.
. if motor is not rotating Replace the developing disengaging
motor.
or
problem due to cairtage leaver lock cairtages not engage properly i hv found max problem of this leaver it found damaged due to improper opening the doorpls follow above steps if problem not resolved then call hp engr for 4th step
May 14, 2010 | HP LaserJet 4700 Printer
Failed Error During Installation. MSI.dot4wrp...Error Code 2753' Message Displays on the Computer in Windows XP and Vista
This is an internal installation error. There can be 2 solutions:---- Solution 1:-- Find all of the hpqwrg files and delete them before installing the software:
  1. Click Start .
  2. Click Search ( Find for Windows 98).
  3. Click Files and Folders .
  4. In the Named entry box, type hpqwrg .
  5. Set the Look In entry box to C: .
  6. Click Search Now ( Find Now for Windows 98).
  7. Click Edit , and scroll to Select All .
  8. Delete all files pertaining to hpqwrg . There will be approximately five to six files.
  9. Be sure to empty the recycle bin of these files also.Solution 2:---- Completely uninstall the higher version of software and reinstall the lower version first, follow the steps below in order:
    1. Uninstall all of the HP Photo and Imaging software (for both of the products). (The uninstall program can be found in theControl Panel in Add/Remove Programs ).
    2. Re-install the lower version of the software.
    3. Re-install the higher version of the software. Thank you Sir.
Sep 27, 2009 | HP OfficeJet J4580 All-In-One Laser...
Scanner won't work
try removing the program first then remove the scanner from the computer then turn it off for 60 sec. thenafter 60 seconds turn it back on then connect the scanner again wait for a pop up on the lower right of the screen it will message you that found new hardware then click on it and try installing your software if there is no pop up your scanner might have a problem. hope i help
May 03, 2009 | Computers & Internet
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Scanner component stopped communicating
well, reinstall the software and see if it will work.
Aug 13, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP OfficeJet J4580 All-In-One Laser Printer Logo
2,425 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
