Question about HP Photosmart 3210 Printer
Carriage Jam Error message carriage jam What door do I open to clear carriage jam?
    Novelist:
  • 180 Answers
Step one: Print a self-test report Follow the steps below:
  1. Press the Power button to turn on the product.
  2. Press Setup on the product control panel.
  3. Press the right arrow button until Print Report displays on the control panel display, and then press OK . The self-test report prints.
  4. Analyze the results:
    • If the product prints a self-test report, there is no need to follow the remaining steps, because the error message might be false. Try to print something from the computer.
    • If the product does not print a self-test report, proceed to the next step.
Step two: Clear the paper path Follow the steps below to clear the product of any jammed paper.
  1. Make sure the product is on, and then disconnect the power cord and the USB or Ethernet cable from the back of the product. Do not reconnect them until instructed to later. NOTE: Make sure the product is on before disconnecting the power cord. Failure to disconnect the power cord from the product can cause damage when removing jammed paper.
  2. Open the top access door by lifting from the front center of the product until the door locks into place. Figure 1: Opening the top access door Carriage Jam - c00786115.gif
  3. Note where the carriage is stuck and look for jammed paper. NOTE: The carriage is the device that contains the printhead and moves left to right during printing. A paper jam can cause the error message and the carriage stall. Paper might be jammed in different locations and might cause the carriage to be stuck in the middle of the product or on the right or left side.
  4. Remove any jammed paper. NOTE: Do not use any tools or other devices to remove jammed paper. Always use caution when removing jammed paper from inside the product. Follow these instructions if the carriage is stuck on the right side or the left side of the product:
    1. Check for and remove any paper or object that might be restricting the carriage.
    2. Manually move the carriage to the opposite side of the product.
    3. Check the paper path all the way to the side on which the carriage was initially stuck. Remove any paper along the path.
    Follow these instructions if the carriage is stuck in the middle of the product:
    2. Manually move the carriage all the way to the left side of the product.
    3. Check the paper path all the way to the right side and remove any paper along the path.
    4. Manually move the carriage all the way to the right side of the product.
    5. Check the paper path all the way to the left side and remove any paper along the path.
  5. Remove the rear access door or duplexer (if installed) from the back of the product. To remove, press in the tabs on the left and right side, and pull it away from the product.
  6. Check for and remove any paper still in the product.
  7. Replace the rear access door or duplexer, and then close the top access door.
  8. Reconnect only the power cord (do not connect the USB or Ethernet cables at this time). If the product does not automatically turn on, press the Power button. NOTE: The product might go through a warm-up period of up to two minutes. Lights might flash and the carriage might move. Wait until the warm-up period is complete before going to the next step.
  9. Check the power light.
    • If the power light is on, reconnect the USB or Ethernet cable to the product, and then print a self-test report as done in Step one.
    • If the power light is blinking or not on and the carriage is still stuck, reconnect the USB or Ethernet cable to the product, and then proceed to Step three.
Step three: Plug the All-in-One directly into a wall outlet Use these steps to make sure the product is properly connected to a suitable power source.
  1. Make sure the computer and the product have a three-prong power plug.
  2. Remove the product power cord from any power strips or surge suppressors, and then plug it directly into a grounded wall outlet.
  3. Try the print job again to see if this step resolved the issue. NOTE: If the product prints when plugged directly into a wall outlet while disconnected from any power strips or surge suppressors, the power strip or surge suppressor might not be allowing sufficient voltage to reach the product. If this did not resolve the issue, proceed to the next step.
Step four: Service the All-in-One If you have completed all the steps listed above and are still experiencing a problem, service the product.
Posted on Nov 04, 2008
Carriage jam
Hi
The carriage door is the cartridges access door.Access the cartridges and make sure they're properly installed.To open:
  • Turn the machine on.
  • Open the cartridges door by lifting from the front center of the device until the door locks into place on its own.
Feb 27, 2012 | HP C6250 InkJet Printer
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
I get a message carriage jam and told to clear jam. However there is no paper jam. It tells me door open and it is not open. It seem the door does not go all the way up. I keep getting the message that...
It seems you mistook Carriage Jam as Paper Jam, but they are different issues. Carriage jam means the carriage that carries the cartridges is jammed which needs to be moved or be cleared manually after opening the door.
Please follow the instructions mentioned here (Click Here) [source HP Support].
Good Luck.
Let me know if you need further help.
Thanks for using FixYa.
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Clear carriage jam
The carriage assembly is what the ink cartridges moves on. The silver bar that runs through the cartridge holder must be oiled. Put two or three drops of thin oil oun iether sides of the cartridge holder. This should clear the "carriage error"
Good Luck
Apr 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
Jun 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
HP Photosmart 3210 Printer Logo
229 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
