Question about Sony Handycam DCR-TRV460 Digital Camcorder
The screen that says reinsert the cassette.
The camera is fine when it's on. after you push record a message comes on the screen that says reinsert the cassette.
    New Friend:
  • 99 Answers
Tht means the recording protector tab of the tape is on, check the tape, most or f the time there will be a plastic piece tht can be broken off if u need to prevent any thing from recording on it, try covering the hole with a piece of adhesive tape and try recording
Posted on Nov 08, 2008
"Remove the cassette"
I only got the problem when the tape was bad. Usually the ribbon got folded, or was very wrinkly looking. Eventually I found out the drive was bad, and had to have it replaced.
May 08, 2010 | Canon XL1S Mini DV Digital Camcorder
Re-insert the cassette error message
SMACK THE CAMERA ON EITHER SIDE REAL HARD
? what does it mean plz?
can you explain for me plz?!!
Apr 12, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
Reinsert cassette - After inserting a cassette the on screen message reads as follows "reinsert cassette" a further message C:31:23
when ever to get this kind of message just try to fwd the tape mannualy, or just make sure tht when u are rew. the tape dont rewind tht completely....
Jan 04, 2010 | Sony DCR-TRV285E Digital-8 Digital...
Reinsert the cassette
I had the same problem and had to leave my camera in for service twice, although I am not using it that much. In the end, they told me they had to change the "head" which cost me about 100euros. If it happens again, I think I will throw the camera in the bin!
Nov 05, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
Reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
Feb 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Cassette loading error 31:23
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Nov 18, 2007 | Sony Handycam DCR-HC96 Mini DV Digital...
Error message 31:22 reinsert cassette tape
reel sensor is the problem of your camera it is a common problem to that model,maybe the pinch roller is loosen to the post cause of the lock of that is been broke..that roller is that one that pulling the tape...only a technician can put it back to the mechanism and replace that lock...in sony service they replace the whole assembly and cost a lots...i suggest find other service center for fixing it...hope that roller is not lost in your camera...
Aug 20, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Cassette load issue
reel table on the right ( take - up ) if has low tension ? will slow down or stop , giving reinsert error : stretching spring ( inside reel table ) will fix problem , as well as to order and replace reel table .
Aug 07, 2007 | Sony Hi8 CCD-TRV138 Camcorder
Sony Handycam DCR-TRV460 Digital Camcorder Logo
154 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
