Question about Audiovox GB Electrical GBT-502A Household Battery Tester
Light bulb blowing frequently
There one socket that a lightbulb keeps bowing. Is that a sign of an electrical problem? If this is not the correct sight, can somebody direct me?
Thanks in advance.
  • Eric Wissenbach
    Eric Wissenbach May 11, 2010
    You wrote, There is one sockec that lightbulbs keep blowing in.... Correct?
    What type of light are we talking about? If it is a regular run of the mill porcelain lampholder there is not much to go wrong with the light itself. If on the other hand it is a Compact Flourenscent (CFL) there are a few components to it that can go wrong.
    CAREFULLY visually inspect the inside of the socket if it is not a CFL and make sure there is no foreign material in it. Please write back with the type of light it is.
    Problem Solver:
  • 8 Answers
Bulbs can blow if there is a poor electrical connection/ terminal etc.
Be CAREFUL
Posted on Nov 04, 2008
How much electricity does a home led light bulb use, compared to a cfl lightbulb?
About half of the CFL consumption. The other way they win is that they don't have to be replaced as frequently.
Feb 05, 2015 | Microwave Ovens
2003 Olds Alero keeps blowing fuse For dash and tail lights
Likely there's a wire loose that's shorting to the chassis. The way I troubleshoot these is to put a lightbulb in the fuse socket, and then go under the dash, and move stuff around while somebody watches the light. When it goes on, you're close to the problem. Yeah, it's a royal pain, but that's the best way I know.
Jan 31, 2015 | 2003 Oldsmobile Alero
Replaceing bulb on ceiling fan
Turn off the fan before you climbing the ladder to remove the dead bulbs
  • Note whether a screw secures the shade or if the lightbulb holds the shade in place.Unscrew the lightbulb counterclockwise. If the bulb is securing the shade, grasp the shade with one hand while removing the bulb.Install the new lightbulb by turning clockwise into the socket. If the bulb holds the shade in place, keep the shade in position with one had while screwing in the bulb with the other.
  • ceiling light
  • May 15, 2012 | Hampton Bay 24002 Ceiling Fan
    1996 Honda CBR 600 F(3)T headlight keeps burning out
    Hi, Anonymous if your headlight is not working, intermittent, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
    1. Faulty ground or power supply wire to headlight bulb socket.
    2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
    3. Worn, chafed, or broken wires in the light circuit.
    4. Corroded, broken, or loose pins/sockets in wire connectors.
    5. Faulty hi/low beam switch.
    6. Faulty ignition switch.
    7. Fuse is good but no continuity on both sides.
    8. Faulty headlight relay.
    9. Faulty wiring between battery positive and headlight bulb socket.
    10. Weak charging alternator/generator/lighting coil
    11. Faulty voltage regulator/rectifier ground or overcharging.
    For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
    Blowing out lightbulbs anything should check CBR Forum Enthusiast forums...
    http://www.fireblades.org/forums/electronics/80142-headlight-keeps-burning-out.html
    Honda CBR600F4I 2001 Service Manual
    https://www.partsfish.com/page/oem-parts-for-honda
    Honda CBR600F Owner Manual
    Feb 03, 2012 | 1996 Honda CBR 600 F(3)T
    My lightbulb in my fridge won't go on
    Check the tab in the center of he bulb socket. Unplug the frig first and gently pull it up a little. You should be using a 40 watt appliance bulb not a 60. If the tab is not the problem you may need a new switch.
    Eric
    Apr 29, 2010 | Refrigerators
    Lightbulb on ceiling of oven went out. How do I
    Hello :
    1:Unplug the microwave oven from the outlet. Wait 20 minutes for the capacitor that is inside the microwave to discharge.
    2:Unscrew all the screws around the casing by turning them counterclockwise.
    3:Remove the cover by lifting off.
    4:Locate the light bulb in the microwave. This will be located on either the right or left side.
    5:Unscrew the light bulb by unscrewing counterclockwise. Some light bulbs are held into the socket by two notches; for these you will need to gently push on the bulb and turn counterclockwise to unsecure the bulb, then pull out of the socket.
    6: Place your new bulb in the empty socket and secure by turning clockwise until tight, or if the bulb is one with notches on both sides, then guide the notches into the slot on the socket, push gently and turn clockwise until clicked into position.
    7: Replace the cover and screw back on. You are now done and may plug back in the microwave.
    Warning : Unplug the microwave before starting and wait 20 minutes for any residual electricity to be bled off from the capacitor.
    Things you will need : Phillips screwdriver
    good luck .
    please rate !
    Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    I just bought the Flashpoint Bright Beam 300 watt continuous output and it came with a 300 watt DRA bulb. The bulb is really tiny and it doesn't seem to fit directly into the actual light. Is there another...
    no, i have the same light...i just inserted the 2 pronged lightbulb in the middle of the metal plate where there should be a small socket with 2 holes...you have to be carefull with these kinda bulbs...they are easily damaged, prongs being broke from being put in and out...too frequently and ect.
    Feb 02, 2010 | Flashpoint Bright Beam 300 Watt Continuous...
    Reverse light fuse blows when put into reverse
    Unfortunately, many possibilities. If you have time, start by removing both reverse lamp sockets from light assembly(and keep from touching any metal), remove bulbs from sockets, CAREFULLY INSPECT sockets and wires. New fuse of correct rating. Turn key on and try again in reverse.
    Fuse still blows: Next place to look is transmission reverse electrical switch and wiring as far as you can trace looking for burned/stripped wires near transmission and wires by sockets
    Fuse doesn't blow: Turn key off and install one lamp in socket at a time. DO NOT install sockets into fixture at this time. Test. Remove first lamp to check second. If still O.K., each socket back into fixture(one at a time same as before)and test. Most common problems: Sockets contaminated, wires shorting at sockets, bulbs installed incorrectly shorting to ground.
    Sep 25, 2009 | 1996 Ford Explorer
    Electrical problem Cadillac
    If there is no power to the sockets, changing the bulb wont correct the problem. Check all fuses. Check for current to the tailight. Check for ground to the tailight. Repair as nesessary.
    Check cigarette lighter filament. It may be faulty. Check inside cigarette lighter socket. It may have a foreign material in it causing the short.
    Jul 23, 2009 | 2000 Jaguar S-Type
    Audiovox GB Electrical GBT-502A Household Battery Tester Logo
    178 people viewed this question
    Top Audiovox Measuring Tools & Sensors Experts
    Vuk B
    Tom Chichester
    Are you an Audiovox Measuring Tool and Sensor Expert? Answer questions, earn points and help others
