Question about Dell 924 All-in-One InkJet Printer
Plastic strips protruding from above ejector tray
"Clear the carrier jam and then press > to continue". This is what is read on the printer when I press power. above the tray where the prints come out and from right near what appears to be below the cartridges are three strips of plastic with small metallic lines at the end. From what I have read thus far on this site I believe they may be timing strips but then again I am no expert and could be way off. Anyhow, this printer is fairly new and has hardly been used at all since its purchase from dell a year ago. (it is a dell all in one photo inkjet 924). I am thinking the strips somehow connect back in somehow but at the risk of messing things up further I am hesistant to attempt fixing it on my own. Any help appreciated.
A long narrow filmlike strip came off my printer while i was changing the ink. i don't know where it came out from. printer message reads 'clear the carrier jam and then press > to continue'.
can anyone help?
Posted on Feb 16, 2009
I had the same problem in the same printer model. After taking the printer apart I found the culprit to be a light sensor covered with paper dust. The solution was also rather simple: Spray generous amounts of air from a compressed air can (obtainable at any office suply store, STAPLES, OFFICE DEPOT) on the electronics located in the back part of the printer. To be able to reach that part of the printer, you'll have to remove the paper holder and guides. This is done by simply pressing on the sides of the holder, where it pivots, and the stubs should get out of the holes. The sensor is located to the left of center. Pushing the air can long-slim tube in that area and spraying as much air as possible should be enough to dislodge the paper dust covering the sensor. I hope this help. It helped me! :)
Posted on Apr 07, 2007
SOURCE:
It says clear the carrier jam and press arrow to continue. There is nothing to clear. It makes a loud noise when you press start? It it worth taking it somewhere to be fixed?
No, might as well buy a new one rather than have it fixed. You can try cleaning the encoder strip. It's a clear plastic strip that runs though the printer cartridges. I clean mine with a light alcohol on an old T-shirt (or other soft cloth). clean one side then move it to the other and clean that side. But be easy, the encoder strip is a pain to put back on if you pull it off (and it does come off easy).
Dec 03, 2010 | Dell 924 All-in-One InkJet Printer
Narrow strip came out from my printer (dell all-in-one photo 924
It goes through the ink cartrige holders and hooks onto the frame. It's called an encoder strip.
Feb 16, 2009 | Dell 924 All-in-One InkJet Printer
Carrier Jam
This is what my printer did when it kicked of the 14" plastic strip inside the printer(see posts referring to strip). Look inside for a loose, quarter inch wide and 14" long plastic strip with slots on the end. Let me know if you solve this.
Dec 15, 2008 | Dell 926 All-In-One InkJet Printer
Paper Jam wont clear and there is no paper in it
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} When printer does not have visible paper jam and printer is showing error paper jam
Check if the Encoder Strip is Broken or Missing
1.Power down the printer and unplug the power.
2.Slide the cartridge carrier inside the printer a couple of inches to the left.
3.Locate the encoder strip (Figure 1) on the right-side of the cartridge carrier encoder strip
Note:
The encoder strip is a plastic strip with small markings over its entire length. The strip may appear to be translucent.
Reposition the Encoder Strip
1. Remove the power cord from the printer.
2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
3. Gently slide the ink cartridge carrier to the middle of the printer.
4. Gently move the top part of the printer belt to the right.
5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the scanner lid.
9. Re-connect the power cord to the printer.
Ensure the Paper Tray is Not Overfilled
Each printer tray has a maximum capacity rating, and this rating is based on a specific paper weight and or thickness. Consequently, situations might arise in which the tray will not be able to accommodate the maximum number of sheets listed in the printer specifications. Verify that the paper is not packed too tightly in the paper tray.
Aug 17, 2008 | Dell 924 All-in-One InkJet Printer
Clear paper jam message but no paper jam
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check if the Encoder Strip is Broken or Missing
Note:
Adjust the Printer Paper Guides
Adjust the paper guides to fit the size paper being used .The guides should be close (1/16" or less) to the paper without touching, so that the paper stays properly aligned without continually rubbing the guides.
Locate and Remove Any Obstructions Inside the Printer and Input Tray
1. Open the front cover and make sure the kickstand (if there is one) is engaged.
2. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects.
3. Close the cover.
4. Remove all paper from the input tray.
5. Inspect the input tray for any obstructions.\
6. Remove any visible obstructions.
7. Reinsert the paper.
Clean the paper feed roller on the printer.
1. Power down the printer and disconnect the power cord.
2. Remove all paper from the input tray.
3. Wipe the roller gently with a damp cloth.
Aug 13, 2008 | Dell 924 All-in-One InkJet Printer
Dell 922 printer jam
Note:
Reseat the Dell Printer Power Adapter.
If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends.
Check with manufacturer if printer is still covered under warranty...
If yes then get it replaced.....or else get a new printer
Jul 31, 2008 | Dell 922 All-In-One InkJet Printer
Photo 924 printer paper jame
Note:
3. Close the cover.
Apr 20, 2008 | Dell 924 All-in-One InkJet Printer
Carrier Jam
I loaded to new cartridges into the printer1.gif, switched it on, cartrigde went from one side to the other with a bang, error on printer reads, clear the carrier jam, cn you help?
ed
Jan 11, 2008 | Lexmark OfficeCenter X3350 All-in-One...
Plastic Strip is out
must get the strip threw the sensor slot on print head.
hard to explain, see different model lexmark but same problem
http://www.fixya.com/support/t114418-error_0502
Dec 15, 2007 | Lexmark X3470 All-In-One InkJet Printer
Printing problem
Note:
3. Close the cover.
Nov 22, 2007 | Dell 922 All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
433 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
