Question about Orion FTDV2004 20 in. TV/VCR/DVD Combo
TV Won't work
My TV hasn't had any problems and was working earlier today but it turned off by itself and will not come back on. I tried unplugging it and that didn't work. It is also making this ticking noise. I thought that somehow it had gone into sleep mode but I do not know how to get it out. I tried touching every button on the remote and nothing is working.
    Sergeant:
  • 337 Answers
If you were watching the set and it went off bt itself is not likely is in any sleep mode,you have already tried unplugin the unit that did not work,The set needs service to diagnose what happened,I am sure is nothing you could have prevented,it just failed by itself.Is lees expensive if take the set to a servicer for an estimate.
Posted on Oct 02, 2006
Sound not working, Was working earlier today and after shutting off the tv, when we turned it back on, sound wasen't working
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD.
Apr 03, 2012 | Vizio 42 in. LCD TV
I went to turn on my Samsung a little bit ago, which was working earlier today, and now it won't turn on and is making a clicking noise. The noise does not stop until 10 seconds after I unplug it...
The tv power supply board it got short and already dead some how,tv have clicking noises mean ur tv power supply board are not stable and not regulating high voltages to the rest of the tv other boards.The tv power supply board that the board where the a/c power cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
19 inch slyvania tv/dvd combo turn on play button stays on and the the tv goes to red green yellow and blue screen and won't do anything else
I have been having just about the same problem with mine, i can watch the tv for about 20 min and then the dvd player comes on by itself then it goes to red, green, yellow, and black and white, i've tried resetting the dvd player to default but it hasn't helped mine.When i try to turn it off it automaticly comes back on so i have to unplug it.If i find a way to make mine work right i will send you a message to let you know so you can try it on yours. I've had mine just over a year and i don't have a warrenty anymore.
Aug 08, 2011 | Sylvania LD195SSX 19 in. LCD TV
My panasonic th-50px60u television turned itself off last night and won't turn on makes clicking noise when unplugged and plugged back in but then nothing red light flashes
Tries tv unplug,replug it back like about an hour later for the tv to do it resetting itself back to the factory setting,tv might work again.If not still same problems.The tv 90-95% it is the board that call the tv power supply board is having a problems.That the board where the tv power a/c cord plug into it.U have all tools and know basic electronic and also can do basic soldering works too?Yes,take the tv aparts,check the tv power supply board carefully for dying and soon to be dead capacitors components parts.These capacitors components parts are alway bulges up or puffing up onto it tops.These dying and soon to be dead capacitors components parts are bulges or puffing ups on to it tops must have to be replaced will solved ur tv power unstable and flashing red light.Or try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Jul 29, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
My plasma TV is not getting a signal from the hdmi cables. They worked earlier today and I have not changed them. The game system is the only component functioning now.
Tries tv unplug,replug it back like about hour later.For the tv do a resetting itself,take out the tv HDMI cable out the old HDMI hub port try plug it into another tv HDMI hub port.Should work now,still have same problems,probally needed a new HDMI cable replacement,the old HDMI cable is worn out or shorted out.
May 08, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
Sanyo dp3247 was working earlier today but when I turned it back on this evening I can hear it click on ..but No picture or sound. Help please?! I'm 86 yrs old and this is my source of entertainment. Is...
Tries tv unplug,replug it back like about an hour later.Most of the time tv will work again.Sometime is only a temp fix or the same problems will accur as the original problems.Than the tv have problems,with it power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jan 17, 2011 | Sanyo DP32647 32 in. LCD TV
40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Sep 30, 2009 | Sony Televison & Video
Mitsubishi WS-65313 65 in. TV will no longer power up.
You should call a good TV Tech. This problem cannot be solved by a consumer. The one thing you might try is to unplug it from the wall for a few minutes and then try it again.
Aug 03, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Orion FTDV2004 20 in. TV/VCR/DVD Combo Logo
150 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
