Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Lamp replacement I received the lamp but no instructions to complete the replacement. I have a SONY 55" Grand WEGA
  • Any Guy
    Any Guy May 11, 2010
    Could you provide the model number? Then I can give you the correct instructions
    Novelist:
  • 135 Answers
Without giving specifics, I'll cover most configurations.
Look for a thumb screw on the lower right "side" of the TV as you face the screen. If it exists, unscrew it and take the door off. Reach inside the cavity and lift the "D" ring and pull out the lamp. Insert the new lamp by tilting the lamp up on the left side (high voltage connector should be on the bottom), the "D" ring will raise and lower on its own when it seats. Reattach the door and it's done. If your set blinks the power light 3 times, you didn't get the door on correctly or the lamp isn't fully seated.
The other models require popping a facia panel off the front of the TV. To do this look for thumb screws on the rear of the set just below the corners of the screen. Loosen them until they are free from their threads, they will not come out completely as they are captive. Pull the plastic facia panel off the front of the TV. Find another thumb screw at the lamp door and loosen it, sliding the latch over to release the door. Use the long allen tool to loosen the bulb mounting screw and pull the bulb out. Reverse the sequence to reassemble.
Posted on Nov 09, 2008
Sony wega 55" 3LCD turns
Have you changed the lamp? If not the lamps life is around every two to three years. The lamp is easy to change out. Most local repair shops carry the lamps. Hope this helps.
May 29, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
We have a 55" Sony
marybeth_all,
That is why you should always have a professional repair your TV.
Take the lamp door off again and remove the lamp. Check for anything in the tracks that should not be there. If the track and the module look OK, and I can't tell you if they do, and you are not a professional, reinsert the lamp module and make very sure that it is installed completely and correctly.
If this was the problem your unit should work OK.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 30, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv stays on for a few minutes and then goes off;after 30 seconds,blue light flashes,and tv goes on again;
If it is Sony Grand WEGA KDF-55XS955 tv then it needs lamp replacement as existing lamp in tv has reached at end of its working hours life and causing this problem.
If lamp in tv has not been replaced in last 2-3 years then it is time to replace it. Lamp replacement procedure is easy and written in user manual.
Required lamp part number for tv is as follows:
A1085447A .... LAMP BLOCK ASSY XL2200U
Available in Sony Accessories Store for $200
Please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Nov 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
How do you replace the projection lammp?
I will forward a link to a page where you can find the instructions on replacing the lamp of the TV.
http://www.docs.sony.com/release/KDF42-46-50-55E2000.pdf
Jul 23, 2010 | Sony Grand WEGA KDF55E2000 55" Projection...
How come the lamp does not have a good life span
Just by nature of the type of lamp it is; its not desgined for long life.
Feb 04, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
May 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Screen automatically goes black after a few minutes
Lamp in TV got weak and TV needs new lamp.
Lamp replacement procedure is written in instruction manual and buy should buy Sony original lamp from Sony Accessories Store for your Sony TV.
Apr 30, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Sony Wega 55 inch, won't turn on and displays shows lamp problem? How do I resolve this? Thanks
Please replace lamp in TV and lamp replacement procedure is written in user manual of TV.
Please buy Sony original lamp for your TV and avoid aftermarket / cheap lamps.
Need further info, let me know with model number of Sony TV.
Apr 26, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
No Picture but sound
Your lamp has probably failed. It is a Sony XL2200 lamp
Oct 06, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
97 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
