Question about Tascam DV-RA1000 DVD Recorder
Tascam DV-RA 1000hd read error -64
I use a Tascam DV-RA 1000HD in my studio as my two track for mixing. Today, after transferring some files from it to a computer, I got this odd error message that says "read error -64" and it won't go away. I can't do anything with the unit. I'm worried about messing with it, because I have dozens of mixes on the hard drive, and if it reformats, I'm screwed. What can I do?
Pete
4 Suggested Answers
SOURCE:
fossilruins
  • 114 Answers
SOURCE: tascam dp1x how do i get where i can mix it and master it on my computer
in the owner's manual on page 40 it talks about how to connect it your pc. here is the link for the manual if you need it as a reference:
http://www.tascam.com/i-741-232-128-0-847B06D6.pdf
Posted on Jun 19, 2008
  • 189 Answers
SOURCE: tascam 788
The 788 can be used to play music from a SCSI attached CD-RW drive, but the record (and all other mixing functions) are disabled so you are not able to record the CD output onto a track using the SCSI attached drive.
Your options are:
1.) Rip tracks files from the CD onto you PC as wav files. You'll have rip (or later convert) those files to mono 16 or 24 bit wav files at 44.1kHz, use the old dos 8.3 naming convention for the filenames, and them burn them onto a CD-R or CD-RW as data files which can then be taken and imported into the 788.
2.) Play the CD through with an external CD player or stereo and route the output into an input on the 788. Assign the input to a track and record. Be careful to use a line level output, like an aux out (or try the CD player's outputs directly into the 788) if you are using a stereo. Avoid using a speaker output as the signal from a speaker output will be too strong and can damage the 788.
Hope this helps.
Cheers.
bd.
Posted on Oct 23, 2008
  • 189 Answers
SOURCE: Making Midi Files for Importing to Tascam 2488
You should always work in wav format if possible because there is a loss of quality with mp3 which is a compression format in which bits are lost in order to compress the file size.
There are a number of wav editors available which will allow you to load a stereo wav and then save it as a mono wav. The free one I use is called Audacity.
When working with FL or Reason I will sometimes import files to the Tascam, or I will take the outputs from my PCs sound card and line them into the tacams inputs and record them live. I only tend to do this with programs (like synths) where I am using an external midi keyboard and can play live what I want to record.
With basic drum pattern tracks I'll usually create them on the PC, save as wav, convert to mono, and then import to a track on the Tascam.
hope this helps.
bd.
Posted on Jun 25, 2009
Can't figure out how to mix down tracks to stero master on 2488 mk 2
Your owners manual can be found at manualslib.com by searching your model number and choosing manualslib under the heading TASCAM 2488MKII OWNER'S MANUAL Pdf Download.
Tascam has a help line at 323-727-7617. If you haven't done your homework in deciphering the users manual, I would not call them. Their service is free, but their on phone time for help is limited and they can be quite surly.
Dec 16, 2017 | Tascam Audio Players & Recorders
I have a Tascam DP-02 8-track all-in-one digital recorder. I've successfully armed and recorded Ch's 1 and 2 to input A and saved the session. When I loaded the session the next day to resume the project,...
i had a look for u on the net only the small yellow ones light up but ill get back to you about the other question as soon as i find a ansew wont be long thanks from chris
Sep 14, 2008 | Tascam DP01 All-In-One Recording Package...
I have a DP2 Tascam 8 track recorder. Can I come out of my 16 channel mixer into my recorder and record my whole band?
The Tascam DP-02 can only record two tracks at a time.
You will have to mix "on-the-fly" and record the master out, or record each instrument seperately, and just record the drums as a stereo mix.
Feb 13, 2010 | Tascam Starter Pack for 4-Track Cassette...
Having trouble transfering my wav files from computer to tascam ( dp 02) even from cd to tascam . so i am unable to use .help? i have transfered my mp3 audio files to wav and tried to drag and drop from...
I had the same problem too but I figured it out. First you have to make sure your wav file is converted to (MONO) as opposed to Stereo, (which is the default channel setting). The best thing to do is to download a converter program, in my case I downloaded AVS Converter program which all I did was upload the wav file switch it to Mono 1.0 and that was that!! The Cons: for this program it costs money to download for your own keeping. I also suggest Audacity program my computer wont let me download it but a co-worker of mine has it and he said it's free to download.
Feb 02, 2010 | Tascam Dp-02cf Digital 8-track Recorder
hope this helps.
bd.
Jun 25, 2009 | Tascam 2488 Portastudio Multitrack...
Want to copy files from Tascam 788 to IMAC's Garage Band
The problem is thus. You have a multitrack recording saved in a format that your portastudio recognizes and you want to use it on your imac. If you can copy the file to the imac as a file, a translator, if one is available, will make it usable by the mac. You won't be able to play it and record on the imac because maintaining the recording as multitrack would require one output from the portastudio and one input on the imac for each recorded track.
Bummer dude. The kluge method would be to play/record 2 tracks at a time (or however many outputs and inputs are available) and hope for some semblance of time alignment, after which you can fine tune it and then start your editing.
Apr 09, 2009 | Tascam Electronics - Others
Tascam 788
Your options are:
Hope this helps.
Cheers.
bd.
Oct 20, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam dp1x how do i get where i can mix it and master it on my computer
Apr 29, 2008 | Tascam DP01 All-In-One Recording Package...
If anyone can help me out,please do!
Alternatively you could load your stereo instrumental track into a wav editor, then export each stereo track as a separate mono wav file which you can transfer via usb into you DP-01 and then on you DP-01 import those wav files into two separate tracks which you can pan hard left and hard right so they are in stereo.
Dec 28, 2007 | Tascam DP01 All-In-One Recording Package...
Software.
I don't believe any software comes with the DP-01.  After you record your tracks, you have to "export" them to your FAT drive.  Once they are on your FAT drive, you will be able to see them using Windows Explorer.  Your Tascam shows up as a removable disk.  Simply open the drive and you will see the available folders.  The WAV folder will contain your exported .WAV files and you can drag&drop from there.
If you don't have the manual, you can find it online.  It's free!
Oct 24, 2007 | Tascam DP01 All-In-One Recording Package...
Tascam DV-RA1000 DVD Recorder Logo
306 people viewed this question
Top Tascam Televison & Video Experts
Marvin
Marvin
Are you a Tascam Televison and Video Expert? Answer questions, earn points and help others
