Question about Nintendo DS Console
Nintendo DS unit will not power on. checked battery and shows proprer voltage. does not work either when pluged into AC or on battery. Possible solution
  • Lauren Brown
    Lauren Brown Nov 09, 2008
    Well my problem is the charger won't charge the ds...when you charge it the little orange light is supposed to stay on.Me and my mom tryed to fix it but the little piece inside the ds where you put the charger plug broke.How do I fix it?
Your DS is over Charged stop charging it for a day or 2 and your DS will be fine
Posted on Nov 09, 2008
DS Lite Will Not Power On
There is a possibility that your battery has developed a short circuit or is so bad that it pulls down the charge voltage on the charger. You are therefore left starved of a power and therefore no function.
If possible, disconnect the battery and run the DS on the charger power alone. If the DS starts to work, I suggest replacing the battery.
Sep 05, 2014 | Nintendo DS Lite
Nintendo ds
First remove the new case and see what you get - if it all works fine then the case must be pinching a cable or pressing on something it shouldn't. Check the unit with AC only or battery power only. The faint click is probably the power switch membrane clicking across - probably indicating that the switch itself is fine - but check at least visually and with a meter if you can. the most likely causes of the problem if removing the case again does not get it working are; Loose connector - probably where the screen hinge is, or where those cables connect to -check anything that you could have moved. Is it an official original case? some cheap copies may be badly fitting, although I found no info on any problem like this so far. If you have a card inserted, try with a different one or without one. check nothing got in the card slot and no pins are bent - especially if you just put a card back in after replacing the case. Especially could be problem if your DS was set in Auto start-up mode before. Possibly unconnected to the case change, the power supply or battery could have failed. Check through this link and see if it helps identify if that is the problem. Do you get any power or charging lights? http://www.nintendo.com/consumer/systems/ds/trouble_power.jsp nintendo do not recommend it, but it may be worth removing and reinstalling the battery in order to reset the unit. proceed with care. Here is the link to the manual if you need it; http://www.nintendo.com/consumer/downloads/ds_english.pdf Hope this helps - please post back with more details :)
Aug 15, 2007 | Nintendo DS Console
Ds lite charges fine, but won't turn on! both fuses ok!
Hi. Same thing happened to one of my friend's own. Also, when I shook it, I could hear a slight rattle inside as if a small piece had broken off. I took it apart and found that a small surface mount inductor had come off (it was right by the on/off switch I believe). I was able to get it soldered back on and added some glue for mechanical strength (since my solder wasn't as good as original). This worked a while but it came off again and I could never get it to stick and function again. Just shorting the terminals with wire didn't work, it needs at least some 'L' impedance. So, I tried making my own. I took a very small wire-wrap wire I had from my old college days, and wound it around a paperclip about 10times, solder the ends on, and then removed the clip. (think of tiny spool of wire with each end connected to solder pads). Believe or not, it worked and has been fine ever since. Apparently the tolerance for this circuit is pretty loose. FWIW.
Good luck. A fun project either way before giving up.
Take care
Jun 20, 2010 | Nintendo DS Lite
My ds is not turning on
How old is it? Test your adapter with mutimeter and make sure it has correct voltage or try a different one. Try your adapter on a different DS. Sounds like battery needs to be replaced.
Nov 20, 2009 | Nintendo DS Lite Console
My Nintendo DS doesnt charge
Double check that you have voltage comming from the charger with a volt meter if you have access to one. The correct voltage will be listed on the transformer that is plugged into the wall.
Sep 25, 2009 | Nintendo DS Console
DS will not power on
Remove The Battery For One Minute Then Update Me.
Jan 06, 2009 | Nintendo DS Lite Console
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
Vmx
looks like you need to replace the AC adaptor , test the AC adaptor with a multimeter to check Voltage , if there is Voltage reading?? then you need to replace the battery. hope this helps & please rate, AJ
Jul 02, 2008 | Nintendo DS Lite Console
Nintendo ds lite
Try opening the system up and cleaning it out.
Dec 20, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
