Question about RCA HD52W59 HDTV Projection Television
Screen flickers on Mits 62825
I have a 62825 Mitsubishi Diamond Series TV. We replaced the bulb about
6 weeks ago and all of a sudden the screen flickers. The screen will jump or flicker every couple seconds. This happens on all HD and local channels, and also while playing video games. Please help!
I can be reached via email at nancy.leo@JQH.com.
Thank you.
  • 2 more comments
  • greenz3 Nov 04, 2008
    Thank you.
    There is not an odd sound at all coming from the TV, the screen just jumps. It powers on and off fine. We do have it hooked up to a HD Tivo and Onkyo receiver. The color seems fine, but the picture does not seem as crisp as it use to be.
  • greenz3 Nov 06, 2008
  • snipeorod Jan 20, 2009
    I have a similar problem that first appeared after replacing the lamp assembly. There are light red horizontal lines across the screen and the picture doesn't really flicker but seems to be a bit wavy at times and not as clear as it used to be. I notice the same thing when viewing DVDs that was never there before. I have no unsusual sounds or vibrations. This started after I powered on the set after replacing the lamp. Would a bad housing assembly cause this? I ordered a 'rebuilt' housing to have a spare.
    Genius:
  • 1,030 Answers
Question one.. is there and audible whine like a bad motor.. THIS could be a color wheel. this mechanical wheel provide the color for the set. This is the first possiblity for the symptoms you describe
Posted on Nov 04, 2008
Sound no picture
Like stated before--May be another bad blub, especially if you used a generic or Neolux one. A phillips bulb WILL work right. Mits sets do NOT like generic bulbs !!
Apr 05, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
I changed my bulb to weeks ago and now it wont fire have sound and no picture i have a wd 73c-10
Did you use a generic bulb or a "Neolux" lamp--Mits does NOT like those. Use a Phillips bulb or an original NON neoloux one.
Apr 01, 2014 | Mitsubishi Televison & Video
My TV will not turn on. I just replaced the tv lamp 2 weeks ago. Help!!
did you use original Mits Lamp or a generic?? most mits DLP tvs wont run long or at all with generic lamps
Sep 30, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
My mitsubishi diamond series wd-62825 picture is too dark
There is something I remember and it may be the model you have---Mitsubishi can tell you or you can look for yourself----a few models made at about the time this set was made had 2 mirrors----one a tiny one that faces up and reflects the picture into the large rear mirror.
Dumb idea--the little mirror gets coated with dust and brightness drops up to 70%---
The safe and correct way to know is to remove the entire front screen with its frame---both mirrors (if yours has 2) will be easy to see.
The large mirror hangs at a angle and down so it never gets dirty--don't even think of touching it or using glass cleaner on it--any mark on it will show in the picture.
let me know if you want to remove screen unit to see if one mirror or two---a call to mitsubishi would answer that.
May 15, 2012 | Mitsubishi WD-62825 62" Rear Projection...
Starlike flickers in picture of 57" DLP 1080p HDTV
The problem is the dlp chip on your light motor, you can order a new one at www.tvlampsforless.com.
Jul 06, 2010 | Mitsubishi WD-57733 57" HDTV
Mitsubishi wd-62825 dlp
If the green front panel LED blinks continuously and the TV never comes on, its an issue with the "DM" board. When these TVs are first plugged in, the green LED should blink for 30 sec. to a minute or so. This is the TV booting up, reading its software. Mitsubishi has been having problems with this circuit for several years. In may cases the only permanent solution is to have the chassis rebuilt by Mitsubishi at considerable cost and inconvience. The chassis may have to be sent back to Mits for this rebuild. Call Mits and ask for help.
michtech
Feb 13, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Dec 18, 2008 | Mitsubishi WD-62825 62" Rear Projection...
HDTV Mitsubishi WS-55819 55 Inch Diamond Shield
You will need to contact a Mitsubishi Authorized repair facility. The entire electronics package must be removed and sent back in to Mitsubishi. The problem is the Formatter circuit board which is no longer available as a replacement part. The repair cost is very expensive and must be quoted by the facility you contact not me. Expect 4-6 weeks turnaround.
Nov 28, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mits TV blue Screen
I fortuneatly bought a 4 yr warranty from Best Buy on my Mits. same thing happened with the blue screen fuzzy white diamond. The geek squad techie showed me the 2 capacitors that go bad on the power board and he ordered them and once they were replaced the TV worked perfect again. I have 2 weeks left on the warranty, so i'm calling them today to get my last free bulb(screen is kinda darkening, kinda) hopefully i can convince the technician. This was one warranty that bad for itself.
if you have any electronic skills you can replace these capacitors yourself, once you get into the guts of your unit.
Good Luck
Oct 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
289 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
