Question about Garden
McCulloch Chain Saw Manual
Hello: I am trying to purchase a McCulloch Chain saw owners manual for my Eager Beaver chain saw. I keep getting the run around...Where can I buy a owners manual for my saw of do you have them...I need the manual in order to know how to use it propertly....Would appreciate any help you can give me...thanks.....econry@centurytel.net I have recently acquired a Mac 3516 and all the fuel lines were dry and broke from the carb and primer bulb and I tried to reroute new lines and cleaned the carb out and it will start but wont continue to run after I try to rev the motor for about five seconds. Any suggestions?
  • 2 more comments
  • rhopdo Dec 01, 2008
    I also cannot find a manual for my McCulloch Eager ****** 2.1ci chain saw. Maintenance is impossible or risky at best without knowing how to disassemble.
  • rice_3 Mar 25, 2009
    I need a manual for McCulloch 2.0 gas chainsaw.
    need manual for McCulloch 2.0 gas chainsaw.
  • John McKinney May 11, 2010
    If you give me your model and serial numbers I should be able to get you a copy of the manuals.
SOURCE: McCulloch Chain Saw Manual
Found all the mcculloch manuals you could ever want on mcculloch product information site. Its run by mcculloch an you put the product weather chainsaw or strimmer whatever an the type in the next collum an press download then print it off all very easy. My manual was in german so made up i found stumbled on this.
Posted on Nov 08, 2008
  • 11 Answers
SOURCE: need owners maual for mcculloch power mac 6 chain saw
try my answer to the post on McCulloch pro/mac 10-10 chainsaw owners manual... posted by denniswick on Oct 03, 2008
Posted on Feb 13, 2009
VtToolMan
  • 704 Answers
SOURCE: need owners manual for mccolloch electric chain saw
This is a tough one to find, but after some research I found the full blown tech manual (this saw is of the late 1980's vintage!)
Anyway, here's a free manual - I suggest you print and save a copy as a pdf for future use and reference, as once this gets pulled off the site, I doubt you'll be able to find it again.
http://mcculloch.motoruf.de/spell/get_file.php?filepath=/Mipl/ps100ser.pdf
You can also try calling 1-800-521-8559 and ask for the parts deparment and request a copy of the owners manual be emailed to you in a pdf format.
Hope you find this Very Helpful and best regards!
Posted on Aug 21, 2009
dontbother10
  • 2220 Answers
SOURCE: set the carb for a mcculloch 3516 chain saw
Carburetor Adjustment
There are no hard and fast settings.
A good initial starting point for the "H" and "L" needle valves are 1.5 turns CCW from lightly seated.
The "T" adjustment enters here (idle speed) and there is no initial setting without a tachometer, depending on age of your saw there may not be any initial "T" setting.
The "L" needle is primarily idle performance (not speed) and acceleration to full throttle.
The "H" is mostly performance at speed, but all are interconnected.
Start with a fresh mix of fuel. Put ALL of the old mix in any 4 cycle engine and start new. I suggest 50:1 regardless of what your manual says.
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; once marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
Now we adjust for performance. The best performance adjustment procedure I have found follows.
Madsens Shop & Supply, Inc. Carburetor adjustment (All saws homeowner and professional are the same)
http://www.madsens1.com/saw%20carb%20tune.htm Read step 4 (allow it warm before making adjustments).
There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
I am going to inject a little philosophy here. Undetected air leaks and defective fuel delivery systems account for most chainsaw failures. Constant adjustment of needle valves can easily camouflage more serious problems that result in burning up your saw. A sudden need for an adjustment is often indicative of a larger problem.
If push comes to shove a local saw shop (I prefer Stihl mechanics and do not own a Stihl) should be considered.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 09, 2010
SOURCE: I have a 3516 chain saw mod22-600035-18 Mcculloch the fuel lines
Okay I figured it out finally. One line from fuel tank with filter goes to bottom connection on carb, or right hand side furthest away from start er cord. The line on the other side of carberator goes to short nipple on primer bulb. then the center nipple on bulb goes to return line into tank, not good at typeing hope this helps took me 2 hours of trial and error to get it to run.
Posted on Nov 05, 2011
REQUIRE CHAIN SPROCKET-FOR EAGER ****** CHAIN SAW
I WENT TO SEARS WEB. AND IT LOOKED LIKE YOU COULD BUY JUST THE PART YOU NEED. HOPE THIS HELPED.
Sep 21, 2014 | McCulloch Eager Beaver 2.1 Parts List
My mcculloch eager beaver won`t start.
Take it to your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Sep 29, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Where to find the model number on the eager beaver chain saw
You'll need to contact your local authorized service center for assistance.
Contact us
User manuals
McCulloch Service
May 08, 2013 | McCulloch Eager Beaver 2.1 Parts List
McCullough Eager Beaver model#40010205 392 chain saw manual/parts
Contact us
User manuals
McCulloch Service
Nov 19, 2012 | McCulloch 14" Electric Chain Saw Mcc1514
Exploded parts view of mculloch 2014 eager beaver
Refer to your service manual.
Contact us
User manuals
McCulloch Service
Nov 07, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Spark plug gap for Mccullough 2.0 eager beaver chainsaw
Contact us
User manuals
McCulloch Service
Jun 02, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Fuel line diameter mcculloch trimmer eager beaver 2
According to Randy Duncan Ebay site(Randy's Engine Repair) the fuel line is 3/32" inner diameter and 3/16" outer diameter for the non-primer bulb side of things for a McCulloch chain saw. It is a common size, apparently, but is not listed in the User manual as such.
Apr 30, 2012 | Garden
Need owners manual for mccolloch electric chain saw
Aug 21, 2009 | Garden
Jan 14, 2008 | McCulloch MC1275 Steam Vacuum
Garden Logo
2,052 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
