Question about Kenmore 15864/15862 Top Load Washer
Wont spin it fills washes and drains but wont spin. i am a single mom on a low income how can i fix this problem
    President:
  • 878 Answers
Terri, if it was the lid switch, you wouln't be able to drain. If it were the coupler, it wouldn't agitate. Sounds almost like you have something in between the basket and tub, or a nail or something in one of the basket holes stopping the spin. You will need to remove the cabinet and remove the top tub ring to check these things out. I will attach a couple of photos for you to see if this will help you out. If you have nothing holding the basket up then more than likley it's your basket drive which is a pretty hard job...Catriver..post back
Posted on Oct 02, 2006
  • Ron Marek
    Ron Marek Oct 02, 2006
    Have to pull the end caps off and remove two screws. Flip console up and remove snap springs. Unplug lid switch and cab lifts off.
SOURCE:
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Jan 13, 2014 | Bosch Washing Machines
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
May 31, 2009 | Frigidaire Washing Machines
Washing machine wont wash or spin, just fills and drains
THE MODEL NUMBER IS USUALLY FOUND SOMEWHERE AROUND THE OPENING OF THE TUB OR ON THE LID ITSELF
Apr 24, 2009 | Washing Machines
Kenmore 70 series barrel will not spin in spin cycle
A clutch is easy to replace on these models. check out this fab directions entitle:
CLUTCH REPLACEMENT
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 10, 2009 | Washing Machines
May tag washer spin cycle wont spin
check the pump ,,, if pump wont pump out the washer wont spin till it gets down so low / larryyb
Dec 05, 2008 | Maytag PAV2300 Top Load Washer
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Stupid washer
Check inside underneath from front. Disconnect the hose to the pump from the drum. You probably have something stopping the pump from running. Like a coin or toothpick. Put your finger in the hole a feel for something there. Remove any foreign objects and put it back together. Try to run a cycle. Hopefully the pump wont need to be replaced.
Jul 14, 2008 | Kenmore 43142 Front Load Washer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
46 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
