Question about Epson Stylus Photo R1800 InkJet Printer
Printer has problem grabbing certain papers
My R1800 is two years old with moderate amount of printing done. It is having problems grabbing certain paper textures - the most difficult, nearly impossible, are any smooth, linen type paper or envelopes. To me, it appears the semicircular feeders on have lost their grip. There are no printing issues but more this mechanical problem. Is this common? Can this one part be replaced? I don't want to buy a new printer for this reason.
Thanks....
I have an r1800 as well and i solved this very easily.
usually most epson papers come with a sheet feed cleaning page- a thick piece of paper, same size as the rest, with an adhesive strip in one area. ya peel off the protective coating and put this sheet in and it rubs against the wheel and grabs off lint and stuff. I have done this and it sorta works, but mostly, i think its rather inadequate. plus, not all papers come with this sheet.
so what i did was, when the printer tries to grab a page and doesnt load one and its in the error mode, remove all the paper, and get a cloth wet with isopropyl alcohol. reach in there and set it lightly against the wheel and press the paper button. the printer will try to load another sheet and it will make all of it's usual noise, and the wheel will spin, be sure it's getting wiped with the alcohol. do this three times. then let it dry. reload the paper, and voila!
Posted on Nov 15, 2008
    Scholar:
  • 121 Answers
Ya your is the pick up roller...its worn out as you said....I don't think you will be able to get the roller itself as new probably you will be able to get a second hand......
But i suggest you open the printer and do a few tricks to fix if you have bit of technical mind...and screw drivers....
keep me posted if you ready to open the printer!
Cheers!
Posted on Nov 13, 2008
Trying to print on a #10 envelope from iMac 27 with Os 10.5.1 using iWork. Printer will not load paper
I am on an iMac using OSX 10.5.8 and printing on an Epson R1800. With iWork, word processing module I set up the envelope to print and under the File menu, select page setup and choose #10 Envelope with Portrait orientation. I feed the envelope into the printer in the normal horizontal, top first, print surface up. In the File menu I select Print and hit Return. Most of the time this works. Sometimes the envelope feeds through without printing, and occasionally the envelope won't feed but the printer goes through the printing cycle. The R1800 is not the ideal envelope printer. It is made to print photos on photographic paper. I use an old fashioned typewriter to address envelopes.
Jul 11, 2010 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800: printing 13x19" velvet paper. hand feeding into rear of printer. keeps saying eror, or paper jam or ... then finally just spits the paper through and out.
why print velvet paper? the problem is the velvet would be too thick and it would jam the print heads because when they run over the paper it would pull the velvet and it would get jammed i don`t think you should print velvet
May 16, 2010 | Epson Stylus Photo R1800 InkJet Printer
My epson R1800 printer sometimes ejects the paper to soon
I solved this problem by wedging a piece of cardboard in the slot next to the on-off switch. This stop the printer from cycling during the printing due to vibrations.
Feb 17, 2010 | Epson Stylus Photo R1800 InkJet Printer
I have an Epson R1800 and when I load Roll 13X19 matte media and try to print I either get a "jammed media" message or the printer trys to print without feeding the media.
I had a similar problem trying to print epson pro canvas. I finally learned the "trick". First I generally cut an appropriately sized pice of canvas from the roll. Then I attach a HEADER. This is dome by cutting a piece of 13" wide photo paper in a three inch length (so you have a piece 13" x 3") . Draw a line at 1.5 inches and place some sort of adhesive (I use a double sided tape gun) on one side of the line. Line up the canvas/paper with the line and make sure it sticks to the header.
Now you should be able to manually feed the header/paper into the printer - once the header passes the correcct point the printer will "grab" it a position it correctly for printing.
Hope this helps
nickerjo,
leaningpalmstudio.com
Oct 26, 2009 | Epson Stylus Photo R1800 InkJet Printer
When I press print on the computer, the Epson R1800 just sends the paper through the printer without printing on the paper.
It may have taken care of itself. Problem occurred when I was using letter sized sheets. Switched to 11x17 sheets and after running a couple of these through the printer, it started to print again.
Sep 08, 2009 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800 prints. How 'lightfast' are they?
Not easy to tell. Epson claims a 100 years for some ink types under certain conditions. Nobody would be able to live for such a long time. Some researchers SIMULATE to get the aging process faster but I guess we have to leave Epson's claim a few generations after us to deliver the verdict. For now the jury just must wait. I have some prints done 8 years and counting.
Mayor
May 08, 2009 | Epson Stylus Photo R1800 InkJet Printer
R1800 wheel marks on print
you can try to load your paper by the back of the printer. This problem problably arrived wen you taste a new heavy paper (too heavy?)
Jan 23, 2009 | Epson Stylus Photo R1800 InkJet Printer
R1800 printer problem
I fixed the problem, the PW and Ink Mark sensors needed cleaning. I was able to access and remove both sensors after removing the printer housing, and moving the print head to the far left. There's enough space to unscrew the cover for the sensors, and unplug them with needle nose pliers and a couple fingers, clean them both, dry them, re-install, etc.. all is well now after some re-alignment procedures with the epson factory service program.
Oct 22, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800 refuses fine art papers
Hi Fruitless, Last night I was tearing my hair out trying to get my R1800 to accept some Hahnemuhle Satin 310, and it was just passing through and passing through. About once in 20 trys it would finally print. I was in the middle of making up my own paper profiles for this lovely paper. Anyway, I gave up at about 1:30 am, and went to bed. Today I resumed my attack, and guess what fella, there is a solution. Pass this on to everyone. You did not say what version of Photo Shop you were using. I just got my CS3 a week ago, and if you are using it, you can open a photo for printing. Go to Printing Preferences Dialog Box, > click on Maintenance Tab, and then click on the Bottom button that is labeled as Printer & Options Information. The Printer and Options Dialog Box opens, and there at the bottom is a box that says Thick Paper right beside it. Select or check this box and enjoy yourself thereafter. I did not see this in the User's Guide, but knew there had to be an answer to this problem somewhere. No problems ever since. Best of luck.
Sep 12, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
147 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
