Question about SanDisk Sansa c140 MP3 Player
Frozen screen my sansa scrren is frozen, no buttons work, to turn it off i have to pull out the battery. is there a way to reset or something?
  • dorag Dec 10, 2008
    wait up to 10 mins it will turn on then (change from the starting screen) you'll be able to listen to music but you won't be able to add or delete the songs on it. (you won't be able to record on it either)
I was skeptical that this could work, but it has worked for me. Hopefully you will have success with it too. On the internet, I searched for this issue and one person said to put the battery in backwards, press the power button, put the battery in right, and then turn on the c140. I still had to format the unit in MSC mode, but it appears to be working correctly now.
Posted on Jan 01, 2009
1. Download the newest firmware c100_1.0.005a_FirmwareUtility file and save it on the desktop.
(the player should not be attached to the computer at this point)
2. Double click the file to run it.
3. Accept the license agreement.
4. Remove the battery from the mp3 player.
5. Press and hold the center (select) button and connect it to the computer.
6. If the New Hardware Wizard appears, do the following: (if asked, choose not to connect to the internet for updates), then choose to install the device automatically, then follow the prompts to finish the installation.
7. When the wizard comes up, or when the Update button becomes active (whichever happens first), you may release the select button.
8. Click the Update button, and then click OK to the message that comes up.
9. Wait until the upgrade finishes, then unplug the device.
10. Put the battery back in, and turn on the player.
11. Hopefully the update will be performed, then choose your language prompted.
12. Check if the issue is resolved.
Posted on Jul 04, 2009
My samsung Tocco F480 touch screen has frozen.
If you haven't already tried this, turn off the unit, remove the battery for several minutes. This should reset the device and correct the issue. If it doesn't, then it will need service.
Mar 05, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
Screen frozen when powered on
turn it off, take out the battery, then replace it, turn it back on. see if this helps.
Mar 15, 2008 | SanDisk Sansa m240 MP3 Player
The screen is frozen and I cannot play music and i cannot find the reset button
If your Sansa Fuze MP3 player becomes frozen or unresponsive, you may need to reset the unit.
To do so, simply slide and hold the Power button on the side of the unit. Hold it for about 10 seconds and the player should reset.
If this does not work, I recommend plugging the device into a computer, or charger.
Jun 02, 2009 | SanDisk Sansa Fuze MP3 Player
Frozen solid
i have the same promblem i was listening to my music and it had full batteries and it just shut off this is so bull like i think i have to return it and buy something else!!
May 06, 2008 | Philips GOGEAR SA6045 MP3 Player
Sansa c200 frozen
Have you tried to reset the device by holding the power button?
Jan 05, 2008 | SanDisk Sansa c200 MP3 Player
Frozen on the loading screen
press the menu button on the bottommostlft side,,,and also anyone of the other buttons (say forward button) for quite sometime around 2 minutes (probably less than that)............
then the blue light would be turned off and sansa starts rocking again..
or as you thought u can let the sansa discharge all its power.
dont open at any cost ,because if its found opened then warranty may be cancelled.
Jan 01, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m250 MP#
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second and then reinstalling the battery without pushing any further buttons.
  2. Plug the Sansa into a computer4.gif, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC4.gif Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. This solution has worked for me.
I do not know if this will work on other Sansa m200 type .mp3 players.
Dec 30, 2007 | SanDisk Sansa m250 MP3 Player
Frozen screen
Hold down the power button for 20 or more seconds; when you release the power button, the Sansa Connect will restart on its own. If it doesn't restart, you did not hold down the power button long enough -- try again.
Make sure there's a battery in the player. This doesn't work when it is plugged into the USB port.
Oct 15, 2007 | SanDisk Sansa m240 MP3 Player
Refresh Database
This is happening alot aparently, Sandisk is telling everyone to just reset it but that aparently isnt really working. only suggestion is to set the USB mode to MTP and try it.
Aug 02, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa c140 MP3 Player Logo
296 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
