Computer issues I have a laptop that the hard drive was changed becuase it was defective now the screen sometimes blurs out and freezes. What can I do.
  • caraballo4 Nov 04, 2008
    lets say that it exceeds what can I do to make it work? Can I do something to make it work?
Update the BIOS to the latest version available from the HP website.
HTH, David
Posted on Jan 05, 2009
  • 3 Answers
Does the hard drive fit in with ur computer's specifications, Maybe ur LCD is the problem or the hard drive exceeds ur laptops specifications. By the way laptops are supposed to be brand-specific. What brand is the hard drive and what brand is ur laptop?
Posted on Nov 04, 2008
When i turn it on the screen isnt on
Have you checked it using an external monitor? If it does not work with an external monitor, then it is not a screen problem. The second test: remove the hard drive and restart your laptop. Sometimes, a defective hard drive prevents the laptop to boot up.
Mar 01, 2014 | ASUS N550JV-DB71 15.6" Notebook Computer
Clicking noise
the 'clicking' sound might be a defective hard drive, which also explains some of those other issues.seems that perhaps a local computer tech can easily identify that, and then you may need to do a hard drive recovery exercise to recover hard data.
May 16, 2012 | Sony VAIO VGC-LS35E Desktop (2.0GHz Core 2...
Won't turn on
You may have hard drive issues or corrupted window files, remove hardware and reseat it back in position, sometimes this will correct the problem, next sub out the memory one at a time, causes a lot of strange symptoms. If none of these works, use the recovery disc "if you made one" The final option is a computer store to resolve the issues.
Mar 05, 2012 | Dell Inspiron 1545 Notebook
When i log off my laptop and turn on again my screen shown black (didnot show any thing on screen)?
Dear Friend,
This is a problem that typically requires to try several steps because there is no a direct solution for it but, follow this steps to might sure that one of this fix the issues, they are as follow:
1- Download and update current Anti-Virus and Malware software to keep your computer protected as well as running them to might sure that there is no bugs or virus that can cause the problem.
2- If you are running Windows Vista on you Laptop, I strongly suggest you to update.
3- There has been rumors around that involves AOL on Windows Vista that cause this logging issues. Removed them completely.
4- I will also suggest you to back up your data in case of disaster. After doing so, I recommend you to do a system repair or re-installed by going to your installation partition that comes loaded from the manufacture or simply upgrade to Windows 7.
5- I do not want to point this but, if none of this work, your laptop might have a bad or defective video car.
I hope that any of this help. I wish you good luck with this.
Thanks!
Nov 04, 2011 | Toshiba Satellite A300-0CF035 Notebook
Our new Gateway Laptop keeps freezing up for no apparent reason
pls consider changing RAM it is not VIRUS ISSUE and check ur hard disk condition with HDDLIFE for Notebooks check the strength of hard drive , i am serious about this RAM issue pls consider changing it ur issue will most likely resolve ,
Feb 25, 2009 | Gateway Computers & Internet
Lcd screen shows severe blurring when moved,keyboard is locked when used with PS2 port
Could be a number of things...motherboard,hard drive going bad or as simple as a virus/spyware problem. I would formatt & do a clean install of windows to illiminate any virus problems. Then if it still has this problem, look to the motherboard & hard drive.
Dec 28, 2008 | Compaq Presario 5000 PC Desktop
Gateway M6340U hard drive problem
It sound like memory problem. Change the memory and test if the problem is solved.
Dec 11, 2008 | Gateway M6307 Notebook
IBM T41 WILL NOT STARTS UP SOMETIMESTHEN WHEN IT DOES IT FREEZES
problems will be with:-
1:- installed memory ( not enough or damaged memory module ) RAM
2:- The Processor ( CPU ) Is Overheating.
3:- Hard-Drive. The unit may have bad or defective sectors.
4:- Computer Virus Or Similar.
Solution:- remove 1 memory module from the computer ( located on the underside computer ) boot the computer. see if this helps. try changing memory between the 2 allocated slots.
Check the CPU Fan, is not clocked with dust/debris. ( Can be accessed by removing 2 screws on the underside or the laptop ) Marked with >> or similar. remove the fan, 3 small screws and brush with a soft dry paint brush or similar, remove any dust from fan and check for blockages.
run a scandisk or hard-drive checking program, to test hard-disk unit et,c.
following these steps, should solve your problems.
Mike @ Compurepair. " Thankyou For Using Fixya "
Nov 22, 2008 | IBM ThinkPad T40 2373 Notebook
Intermittent POST issue.
how long does the post takes it to finish before it goes to boot? are there external device connected to your computer like a printer or external hard drive or flush drive? try updating your bios and motherboard chipset.
Jun 12, 2008 | ASUS A8V-MX Motherboard
Laptop boots up intermittently or screen freezes
basing on the information you have given here are the possible solutions:
remove any external device connected to your system (printer, external hard drive and others) if removing this does not work and still gets a blank screen with blinking cursor try to go to safe mode with networking. if successful try to download the driver for your video adapter.
when you try to start the computer , do get anything on the screen like a logo? when does the blank screen occurs, is it during the turning ON of the computer or during the windows xp logo appears on the screen?
a blank screen could be caused by the following: defective video adapter, corrupted video driver, defective memory, unknown device causing the issue like the hard drive, optical drive or other peripheral installed inside the computer.
try also using an external monitor
Sep 19, 2007 | Toshiba Satelite 5205-S505 Notebook
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
