Question about GE Energy Star WCVH6260F Front Load Washer
Clothes soaking We just got this washer a couple of months ago. It worked great until about 1 week ago when the clothes started coming out soaking wet(Not just a little wet but soaking). Any ideas? Gregg
  • Anonymous Mar 17, 2008
    I just got a brand new gew i use it for a month a half and now is making a loud noise everytime on the washing mode, but if in the drain cycle theres is no noise i was wondering whats a problem, i try about to put in level cause that was the said on the manual about if the have a noise problem. And i have a question about, do you think went the deliver the washing machine has to be stand up not lying down? if you can aswer this question and aslo the problem the be nice. thank you. Now im gonna return it back cause its not right for a short time use i know the washing machine it last couple years for only a ordinary house hold use. i dont even used everyday. only 2-3 times a week.
I have the same problem and attempted the filter clean. Didn't work. I think the water pump is out. I tried running it on rinse and spin twice and it failed to drain. BUMMER!!
Posted on Nov 25, 2009
I've had to clean my filter out 4 times in 19 months (3/08). I also had a problem where the drain ate one of the kids sock. It's not a tough fix, just a pain in the ***. I'm thinking about going to the top loading and paying for the extra water it uses. This is not worth the trouble.
Posted on Mar 22, 2008
Emptying/cleaning the filter seems to solve this problem - but be prepared for A LOT of water. More than just a shallow pan full. If you have drawer bases under your washer - it would be wise to empty the stuff out of the bases and just use the drawer itself to catch all the water you will unleash. And, you'll probably find enough coins in the filter to buy a new box of laundry detergent!
Posted on Oct 08, 2007
    President:
  • 878 Answers
Gregg, remove the bottom panel. Right in front you will see the filter. Get a flat pan and remove the filter cover. Pull the filter strainer out and remove the lint and whatever else you find. You should be fine after that...Catriver..post back
Posted on Oct 02, 2006
SOURCE:
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
May 19, 2016 | Frigidaire Refrigerators
Washer not spinning properly
This should be belt driven? I would imagine jut adjusting the tensionwould work.
Dec 02, 2013 | Roper RAS8445KQ Top Load Washer
Karcher 300 runs great but no water coming through
hose is stopped up you have to plug the ends up when not in use mud dobbers and other bugs like to get inside had same problem before
Feb 03, 2012 | Karcher G3025OH Pressure Washer
Clothes smell after drying
I don't think the problem lies with the dryer, I would suspect the washer has mold, this is especially true on front load washer, they make products designed just for this problem, check with a large retailer, not sure who makes the mold and mildew remover, I think Home Depot or Lowes may have the product or know about it..
Jan 29, 2012 | GE Profile DPXH46EA Electric Dryer
The washer doesn't spin out the water. Clothes come out soaked?
if it washes ,,check your lid switch,,if it doesnt wash and spin check your motor coupling...onthejob
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
98 Ford Explorer wont move in reverse or overdrive
Probably low oil pressure in the transmission or worn clutches.
Mar 09, 2017 | 1998 Ford Explorer
E70 ERROR SIGN
Great news that worked!! I had other issues with my washer and had a repair man come and fix it, when he left I started washing and that's when the E70 showed up uhh he hooked the hoses up wrong.. Thanks a bunch
Mar 11, 2008 | Frigidaire GLTF2940ES Front Load Washer
Error soak and scour light comes on wont wash
press and hols start button until it resets then try again.
Feb 20, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
GE Energy Star WCVH6260F Front Load Washer Logo
272 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
