Question about Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer AFFU1466D
Frigidaire Upright - Power Light On Freezer Not Running
Just purchased a used Frigidaire Model FFU14FC4AW1 in 'excellent' condition and gave our son our older freezer. The Frigidaire was working fine for a few days but today we had a power failure then brownouts. We unplugged the freezer immediately. When power came back the freezer did not work at all and was tripping the GFI it was plugged into. I put an ohm meter on the plug and the hot and neutral were shorted. I turned the little knob by the compressor and voila the short disappeared. Right now the Power Light is on but it's not running.
I don't have the manual from the previous owner and Frigidaire's site has the manual and wiring diagrams but it won't download. I have a freezer full of food that's slowly defrosting and any assistance or guidance would be most appreciated. Thanks, Doug
SOURCE: frigidaire freezer quits running
actionsnax please remove the freezer from the GFCI. What is happening on this old unit is that if the compressor shuts off then tries to come back on before the pressure in the system equalizes, the compressor can pull 12 amps. This is normally higher than the trip point of the GFCI. I had this happen years ago with a brand new Amana SXS refrig, in that case no one knew the unit was on a GFCI. The manufactures require that this units not be on a GFCI.
Hope this helps
Posted on Feb 03, 2008
refritech08
  • 149 Answers
SOURCE: Relay clicks, compressor doesn't start
try replacing the relay/ overload you can buy a supco replacement there's 2 of them one covers 1/15 - 1/6 and the other covers1/3 - 1/4 its really easy to wire up and cost effective. any questions don't hesitate to contact by e-mail hvac.tech@gmail.com
Posted on Jun 08, 2008
22yooper
  • 828 Answers
SOURCE: Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Posted on Jun 10, 2008
jumptrout51
  • 3361 Answers
SOURCE: Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Posted on Mar 12, 2009
  • 1218 Answers
SOURCE: I own a Frigidaire Upright Freezer/not freezing...
Good day,
If the unit is running but not cooling then check the following.
1. The fan motor behind the rear panel is not running, you will have to remove the panel, being careful not to damage the control thermostat, and inspect the motor, and replace if needed.
2. The defrost system has failed, icing the coil behind that same panel, and not circulating air. There are 3 parts to the defrost system, the main heater, a calrod unit mounted on the bottom of the cooling coil, a defrost control thermostat which is located on that same coil, but on the top. It is a small 1" round disk with 2 wires coming out of it.
Lastly, a timer which is located on the back of the machine and determines how often the unit defrosts.
If you have an ohm meter and know how to use it, you can test the heater and control thermostat for continuety if the coil is indeed iced up. If not iced up, the test will not work.
To test the timer, you take a screwdriver and with the machine on, turn the shaft clockwise until it shuts off. wait 35 minutes. If it turns the machine back on, it's O.K. If not, it needs replaced.
A tutorial on defrost systems is at the end of this post.
3. If none of the above work, then it is in the compressor/sealed system. This machine has had many issues in this area and is a serious problem unless...........
The unit is under 5 years of age, then warranty will cover the repair.
http://www.appliance411.com/faq/howdefrostworks.shtml
Thank you for using FixYa
Posted on Jan 14, 2010
My upright Frigidaire freezer stopped running. I have checked the outlet and it functions just fine. The light doesn't come on, no controls work makes no noises. Acts like there is no power to...
Hello Ed Greene, thank you for your inquiry!
I see that your Frigidaire freezer is not operating. You explained that the outlet is working and the lights or controls are non-operational. It sounds like a potential issue with the power cord or control panel within your freezer. It would be best to have a technician come out to the home to review the freezer to diagnosis the correct problem and replace parts as necessary. This will help avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Dec 12, 2014 | Frigidaire Freezers
My freezer high temp light is on and it isnt running It is 2 years old and it is a Frigidaire Upright Freezer with digital temp on the outside of the freezer. My son went out to the garage 8 hours ago and...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 14, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
Frigidaire MOdel LFFU1765DW9 This is a commercial self defrosting model freezer, upright, and water leaks out of the bottom right side every so often. Why and what should I look for to fix it.
I have a frifigidaire freezer LFFU1765DW9 . it is not cold at all the light in side is on the power is on but the fan no run and the compressor is not run.
Help please
Jun 21, 2009 | Frigidaire Freezer Refrigeration White...
Freezer not Freezing
If unit is running then it is not worth fixing. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 18, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Fridgidaire upright freezer alarm FFU2065FW
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one of these:
The compressor,The Thermostat,The overload, relay, or capacitor,The defrost timer,The condenser fan motor.
Try to troubleshoot each of these componet one after the other using eliminating method.
That may solve your problem.
Jul 23, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer Problem
Jun 10, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
The buzzer is loud
Frigidaire # LFFH2067DoW2 # WB52430831 upright freezer (frost free commercial)
Freezer is still freezing. The alarm sounded and I switched the switch off to turn off. The manual says that the temperature isn't at the right temperature and once it reaches the correct freezing temperature the light will come back on or the sound would go off after at least 4 hours. This was since last night about 6:00 and if i switch the switch the alarm is still sounding. The left side of the freezer is a little warmer than usual. Any suggestions
Mar 02, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Open Questions:
See all Frigidaire 13.7 cu. ft. / 388 liter Upright Questions
Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer AFFU1466D Logo
256 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
