Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Amana sx25sw - side by side - fridge not cooling
We have a side by side, 1994 amana sx25sw, and the left side (freezer) portion is full of ice on the back. I believe the ice buildup is preventing cool air from flowing into the right side (fridge) portion. Any ideas how best to fix this problem and can I do it myself or should I call a technician to fix it. Better yet, is it worth it for 1994 fridge?
Much appreciated
Justin
    President:
  • Whirlpool Master
  • 2,651 Answers
Might be as simple as bad defrost timer( 10530703 $50)and/ or defrost thermostat(R0161088 $35), replace em both for under a hundred bucks. the timer is found behind the kickplate lower right hand side and the derfost thermo is wired in behind the rear panel atop the evaporator, and yea your right its preventing flow cause you "self-defrost" isnot functioning.Great frig though Id fix it
Posted on Nov 04, 2008
Freezer not cold enough fridge fine
The issue is the defrost timer.
Jul 10, 2013 | Amana Refrigerators
Fridge portion of my bottom freezer refridgerator is not getting cool air through the damper from the freezer section
I had this problem once and it ended up being the passage having a chunk of ice in it blocking the airflow or the damper vanes could be stuck due to ice check the movement of the vanes or the thermostat that controls the vanes may be defective---- hope this helps
Apr 09, 2012 | Amana Refrigerators
Hi there.I have an Amana Side by Side Refridgerator.We are having a problem with the fridge side not cooling enough.The Freezer side is working well.Have you any tips on how to fix it myself ?Cheers.
Check fan which blows cool to fridge compartment is working. Check fridge is defrosted automatically. If not do it manually and check, there will be cooling in fridge compartment. Over frosting will cover up the fan throw behind the freezer. If not auto defrost works, switch off and restart after 5 minutes. Still auto defrost problem, do it manually or replace board.
Jan 27, 2011 | Amana 22.6 cu. ft. Side-By-Side...
The top portion of both the freezer and fridge are warm but bottom half are freezing.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 27, 2010 | Amana ARSE66MB Side by Side Refrigerator
Fridge/Freezer both only cool and not cold/freezing
have you checked the rear wall of the freezer?if its frosted over,remove the rear panel to check the evaporator coil,if its iced-up it cannot cool the unit properly,if so de-ice with a hair dryer,then check the defrost heater under the coil that is suppose to keep the coil ice free,if its open it cant heat to defrost,if it has continuity and is good,then check the defrost control be it timed or adaptive for proper operation
Jul 18, 2010 | Amana ABB1927DE Bottom Freezer...
AMANA FRIDGE ARB190RCW FREEZER AT THE BOTOM. FRIDGE IS RUNNING BUT NOT COOLING. FREEZER BACK WALL FULL OF FROST
Switch off unit for 12 hours and do a proper defrost. once all ice is gone, switch back on and take note if evaporator fan is working.
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not getting lower than -20deg
Three things bad defrost time bad defrost termination switch or bad heaters. You need aservice tech to check this out. Russ
Jul 19, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
I have an Amanda side by side, the fridge temp
Look in the freezer side for a ice buildup on the back wall.
Ice= defrost parts issue.
Check the fan in the freezer. Is it running?
Not running? Could be a defrost thermostat issue or a bad fan motor.
Mar 03, 2009 | Amana ASB 2623 Side by Side Refrigerator
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
353 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
