KitchenAid KERC507 Electric Kitchen Range Logo
Posted on Nov 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clock problem When Press CLOCK SET/START button, display shows time in blinking mode and after sometime a "start?" display shows up and after a little while whole Display goes blank?
Ron Coons
Level 3:
President:
  • KitchenAid Master 2,651 Answers
  • Posted on Nov 21, 2008
Ron Coons
KitchenAid Master
Level 3:
President:
Answers
2651
Questions
Helped
1547367
Points
7824
Try holding hte clock/set start button in for 3-5 secs, it sounds as if youve accidently turned of the clock display. .. a common issue especially after turning clocks back.. its a built in feature for people with too many clocks in kitchen, they allow you to turn off the display.
How do you fix the clock on a thomas collector edition radio model 512
  1. Locate the clock adjustment buttons: Look for the buttons or knobs on the radio that are specifically designated for clock adjustment. They may be labeled "Clock," "Time," or have symbols indicating clock functions such as hour and minute adjustments.
  2. Enter clock adjustment mode: Press and hold the clock adjustment button or buttons for a few seconds until the clock display starts blinking or enters a mode that allows you to adjust the time.
  3. Set the correct time: Use the clock adjustment buttons to adjust the hour and minute values. Typically, you can increase or decrease the values by pressing the respective buttons. Some radios may use a rotating knob instead. Adjust the time until it reflects the correct current time.
  4. Save the settings: Once you have set the correct time, press a button or wait for a few seconds to exit the clock adjustment mode and save the new settings. The clock display should stop blinking and show the updated time.
How do I set the time on a KADIO KD-3806 digital clock
Earlier FIXYA question:
sachin_arane
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
How do I change the time on a Timex T235 Alarm clock - can't find my book
To set the clock on the T235, make sure that the radio is off. If the radio is playing, press and hold the Power/Mode (the left-most button) until the display briefly shows Off and the time is displayed. Press and hold the Clock button (the center button), the display should start flashing. While the display is flashing, press the Tun + (Hour) button, next to the Power/Mode button, to advance the hour to the current hour. Then press the Tun - (Minute) button, between the Tun + and Clock buttons, to advance the time to the correct minutes. Then while the display is flashing, press Clock and hold to exit the time set mode. This will start the clock.
Timex has the manuals for many of their clock radios on the product page or their support page, https://timexaudio.com/support/ . For the T235, the direct link to the manual is https://timexaudio.com/media/uploads/product/files/T235_User_Manual.pdf . See page 6 to find the directions to set this model.
I hope this helps.
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
3helpful
Royal Time Master TC100 Time Clock - power went out How do I reset the date, day and time?
Program the Date & Time and Print Method using the 3 buttons: Mode, Select, Setting:
Date & Time: Press the Mode button. The Hour will start blinking. Press the Setting button
until the correct hour is displayed. Press Select to set the hour shown.
The Minutes will blink. Press Setting until the correct minutes are displayed. Press Select
to set the minutes shown.
The Seconds will blink. To set the seconds at 00, press the Setting button. Press Select.
The Year will blink. Press the Setting button until the desired year is shown. Press Select
to set the year shown.
The Month will blink. Press Setting until the correct month is shown. Press Select to set
the month hope this help : - )
Atomic travel alarm clock. Model number C17D2090 WIC#693047. (No brand name on clock.) I am living in outside US time zones and can't manually reset my clock to the correct time. (I lost the instructions.)...
Instructions to set the C17D2090 atomic clock
A. To manually set the clock
1. Use the CAL/ALM button to toggle the display until it shows the calendar
2. Press and hold SET until the screen flashes "12hr"
3. Use the UP (antenna) and DOWN (alarm) buttons to change the settings
4. Press SET to set the value
This mode will let you set the 12/24 hours clock, the time, date and year. You should be in the right time zone before you start.
B. To set the alarm1 time
1. Use the CAL/ALM button to toggle the display until it shows the AL1 alarm time
2. Press and hold SET until the alarm time flashes
C. To set the alarm2 time
1. Use the CAL/ALM button to toggle the display until it shows the AL2 alarm time
D. To turn on alarm1
2. Use the DOWN (alarm) button to toggle the alarm on and off (a bell appears on the screen)
E. To turn on alarm2
F. To have the atomic clock set automatically
1. Press and hold the UP (antenna) button until a little triangle flashes on the screen
2. Wait for clock to set
3. To give up waiting, press the UP (antenna) button again.
G. To change the time zone
1. Tap the ZONE button to toggle between the 4 time zones
3helpful
How do you program?
Hello!
This could help
How to set the time:
1. Plug in the unit. Wait until the hour on the LCD starts blinking
2. Press the CLOCK button to set the correct hour
3. Press the SET button to switch to minutes
4. Press the CLOCK button to set minutes
5. Press the SET button to accept the time
***there is no AM icon, only PM***
How to program delay brewing:
1. Press and hold SET until the hour begins to blink
2. Press PROGRAM until you see the tiny bell icon on the bottom of the screen
3. Press CLOCK until you get to the hour you want to start brewing
4. Press SET to switch to minutes
5. Press CLOCK to get to the minutes you want to start brewing
6. Press SET to finalize
Press PROGRAM to activate. When the little bell is flashing, the coffee pot is set to go on at the desired time. While the coffee pot is on or in warming mode, there are vertical lines on the top of the LCD screen that shows you it is on. If you press the ON/OFF button, you can turn it off before the two hour keep warm cycle is complete.
Please rate this answer. thanks
34helpful
2answers
I can't reset my Atomic Traveling Alarm Clock C17DD2090(WIC#6930
First, make sure you have new batteries in it. Then you have two choices:
Hold down the 3rd button -- the antenna button -- until the little antenna sign displayed on the right starts blinking and "broadcasting"...and then wait for the clock to set itself.
When that doesn't work (LOL), try this:
Hold down the "Set" button until each of the various fields start blinking. Then press the up button (3rd one) or the down button (4th one) to adjust each field to the desired number, etc. At least, that's what my office technician did to set mine. Good luck.
5helpful
RCA,RP9328A,Audio System
I did the following to set the clock:
1. Press the Timer/Clock button until "CLOCK" shows, blinking, on the display.
2. Press Set/Demo. The hour indicator on the clock should start blinking.
3. Use the "Track/Tuner Forward" and "Track/Tune Backward" keys to
set the hour.
4. Press Set/Demo. The minute indicator on the clock should start blinking.
5. Use the "Track/Tuner Forward" and "Track/Tune Backward" keys to
set the minute.
6. Press Set/Demo twice. (Pressing once moves to the timer set mode.)
5helpful
9answers
Clock
Turn the system on and press the "Clock/Timer" button (located above the eject button for Deck 1). The clock will appear. To change the time, simply hold down either the < or > buttons (the ones you use to change radio stations and begin CD/tape playback). Press "Clock/Timer" again to lock in the time.
Top KitchenAid Kitchen Ranges Experts
vince
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
