Question about HP VP6121 Multimedia Projector
Powerpoint video problem
I have a powerpoint that has windows media audio/video file embedded in some slides. The video does not appear on the screen. Any fixes for this?
Thanks
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 73 Answers
Here is a list of video formats which PowerPoint supports: .swf, .asf, .avi, .mpg or .mpeg, .wmv.
Mare sure that the video you want to embed is in one format of these above.
If not. convert the videos with FREE Video Converter.
Posted on Feb 10, 2012
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 15 Answers
I would like recommend you try Video Share, it help you convert video to any other formats. http://www.asharer.com/
Posted on Feb 21, 2010
    Problem Solver:
  • 13 Answers
Does the videos play well in Windows Media Player? If not, it deciates that there are not proper codec installed on your computer.Try to download and install some new codec from official: http://www.microsoft.com/windows/windowsmedia/forpros/format/codecdownload.aspx. Go for codec references at: http://www.codecguide.com/
If the video plays well, please try the following methods:
Method 1.
1. Put video files and the PowerPoint presentation in a same folder.
2. Re-insert these files to PowerPoint presentation.
Method 2.
Insert -> Hyperlink, choose the video file you want to insert, and then click ok. After do this, you can click the hyperlink to view the video when present the slide show.
Method 3.
 1. Display the slide you want to insert video.
 2. Click the View menu in the menu bar, and then choose Toolbars in its child menu, later Control Toolbox to let Control Toolbox displayed. Choose More Controls which seems like hammer.
 3. In the succeeding dialog box, choose Shockwave Flash Object. Your cursor will change into a cross-hair - draw a rectangle anywhere on screen
4. Right click the inserted Shockwave Flash control, and then click Properties.
5. Click the Movie property > type the full drive path in the value column (the blank cell next to Movie), including the file name (e.g. C:a.swf) or URL (e.g. http://www.a.com/b.swf)
6. To make the Flash play automatically when the slide is displayed, set the Playing property to True;
7. Finally close the Properties window and save your presentation.
Method 4.
Convert your PowerPoint presentation to Flash use some third party presentation tools, PowerPoint to Flash converter, for instance.
BTW, the link: http://www.playsforcertain.com/tutorial.htm may help you.
Posted on Jan 07, 2009
Corrupt data behind Powerpoint 2003 graphs
1. If you run PowerPoint 2003, choose Help, About Microsoft PowerPoint from the main menu bar. If the About screen doesn't indicate that you have SP1 (Service Pack 1) or higher, you should update your copy of PowerPoint. Choose Help, Check For Updates. When the Office Downloads page opens in your browser, click "Check for Updates" and apply the recommended hotfixes and/or service packs.
2. If you run Windows XP and have installed SP1, see Files open as Read-Only after installing Windows XP SP1, Other file/path related problems
3. Open a blank presentation (You can apply the template used for the damaged file, if applicable. That might help cut down on reformatting.)
4. From the main menu, choose Insert, Slides from File (or if you use PowerPoint 2007, Home tab, New Slides (bottom of button), Reuse Slides.
5. Try to insert slides individually if you're not able to insert the whole thing
6. Use software for restoring corrupt .ppt and .pptx documents https://www.repairtoolbox.com/powerpointrepair.html PowerPoint Repair Toolbox
May 06, 2015 | Microsoft PowerPoint Computers & Internet
Tip
HD Video to PowerPoint-AVCHD MTS to Microsoft PowerPoint Format on Windows 7
Aunsoft PowerPoint Video Converter-HD Video Recordings to Powerpoint on Windows 7 <br />Best HD Video to PowerPoint Converter-Deinterlace AVCHD for PowerPoint <br /><br />Microsoft PowerPoint is the most commonly used program for creating slideshows on Windows. There are many formats listed as supported to be inserted to PowerPoint, e.g. WMV, ASF, DVR-MS, MPG, AVI, MP4, MOV. However, you need to install related codec or QuickTime to play MP4/MOV files or AVI movies. <br /><br />If you would like to <b><a href="http://www.aunsoft.com/final-mate/">Present HD videos on PPT</a></b>, such as the AVCHD recordings from your camcorders, you need to convert them to MS PowerPoint supported formats. Aunsoft Final Mate is the recommended <b>PowerPoint video converter</b> for you, as it does not transcode AVCHD MTS/M2TS clips on Windows 7, but also join and cut recordings into a single file. <br /><br />Follow the simple guide for you to get your <b>HD Video Recordings to Powerpoint</b>, and present your PPT with flexible activities. <br /><br />Step 1. Import AVCHD MTS/M2TS files to Aunsoft Final Mate. <br />Run Aunsoft Final Mate as the <b><a href="http://sony-mts-converter.com/2011/06/powerpoint-video-converter-hd-video-recordings-to-powerpoint/">best HD video to PowerPoint converter</a></b> on Windows 7. You can import files directly from camcorder or from hard drive. For videos from camcorder, just connect it to PC via USB cable and follow the wizard. For video on hard drive, just go to the Resource tab, click the Add Path button to browse the folder with AVCHD files. <br /><br />Step 2. <b>Join and cut AVCHD clips</b>. <br />Select the files from the Resource or Camcorder tab, drag and drop to the Movies tab to create a single movie. To get another file as output, just click the drop-down button of the Create New Movie button and choose For Conversion, then drag and drop other clips to the new movie ID. The files are joined/merged automatically. <br /><br />Step 3. Deinterlace 1080i to 1080p. (optional) <br />If your camcorder provides 1080i recordings, you can tick the checkbox for deinterlacing to remove the lines and make video as progressive mode. <br /><br />Step 4. <b>Convert AVCHD to WMV PowerPoint format</b>. <br />Click the Export button, and go to the last tab. Choose Common Video &gt; WMV3 (WMV9)(*.wmv) as output format. Then click the OK button, and the MS <b><a href="http://canon-videoconverter.com/2011/06/best-hd-video-to-powerpoint-converter-deinterlace-avchd-for-powerpoint/">PowerPoint video converter</a></b> will <b>convert AVCHD recordings to WMV for PowerPoint on Windows 7</b>. <br /><br />Wait for a while, and you can <b><a href="http://www.aunsoft.com/final-mate/">Insert/Import the output file to Microsoft PowerPoint</a></b> to create colorful slideshow, and enhance your PPT. <br /><br /><b>Tips:</b> <br />For Mac users with PowerPoint on Mac OS X like Leopard or Snow Leopard, you can try Aunsoft <b>Final Mate for Mac</b> as slideshow presentation helper on Mac.
on Jun 10, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
VIdeo files to be used in a powerpoint presentation seem to need conversion to a windows format. How do I do that?
Which version of Microsoft PowerPoint do you use?
Check the formats of embedded videos, and if they are not in the list above, convert them.
Feb 21, 2013 | Kodak EasyShare P850 Digital Camera
My ppt file got damaged i cant open it.while i try to open tat its asking for repair option.after selecting repair option it not opening,anybody tell me the ways to open tat file
If the file is damaged you could be out of luck.
There are how ever some things you could try.
http://office.microsoft.com/en-us/powerpoint-help/recover-a-corrupt-powerpoint-file-HA001116878.aspx
There are also 3. party software made.
Try searching powerpoint recovery tool etc.
How successfull any of these sollutions are depends on the actuall error,
Dec 23, 2010 | Microsoft Office Professional 2007 Full...
It's me again! i hade a problem: I would like to make a slide show for a dvd with pictures,and that repeats itself.what program,and how should i use(i have windows xp)!and after i would like put the disc...
Versatile and easy PowerPoint Converter
This PowerPoint Converter is a great Microsoft PowerPoint presentation tool that can convert PowerPoint to video and audio file in almost any formats. All the original elements in PowerPoint can be perfectly retained in this PowerPoint to video conversion, including animation, sounds, movie clips, transitions, internal links, and so on. PowerPoint 2007 is supported.
PowerPoint Converter can convert PowerPoint file to AVI, 3GP, 3G2, MP4, WMV, MOV, FLV, VOB, MPG, MPEG1, MPEG2, DV video and MP3, AAC, M4A, WAV, WMA, AC3, MP2 audio files for you to upload PowerPoint to YouTube, watch PowerPoint on iPod, iPhone, Zune, PSP, Apple TV, Blackberry, Creative Zen, PS3, Xbox, and more MP4, MP3 players.
The PowerPoint to Flash Converter can help you convert PowerPoint slide in to Flash video. You can input ppt, pptx, pptm files and get FLV or SWF videos. Then you can upload these video to YouTube, your Blog, your Space, and other websites to share with others.
Now, with the powerful PowerPoint Flash Converter, your files documents can be shown on the Web not only as a standalone document in a separate window but also can be embedded in a web page and shown inside it altogether with other web page content.
Here, the PowerPoint to PDF Converter can help you create PDF file from documents including ppt, pptx, pptm. It is easy-to-use software which can translate different doucment formats to pdf in batches once with ease.
To convert PowerPoint to PDF is easier than ever with this powerful converter. And only several clicks are needed to finish all the conversions with high converting speed and super good output quality.
The original style of PowerPoint files can be perfectly retained, and both beginners and pro users will find this PowerPoint to PDFconverter tool quite easy to use.
PowerPoint to DVD Converter mentioned in this part is an excellent converter from PowerPoint to DVD tool, that can convert PowerPoint to DVD video and burn PowerPoint to DVD, with rich DVD settings, supporting all sorts of DVD discs. Then you can watch PowerPoint on any DVD player.
PowerPoint to DVD Converter can perfectly retain the original music, animation, movie clips, and slide transitions of the original PPT files. And it allows you to insert background music, or record voice as the narrations and instructions for the PPT files.
You can also use PowerPoint to DVD Tool to create delicate DVD menus. It is the best tool to create a DVD from PowerPoint for playback on home DVD players. PowerPoint 2007 is supported.
Moreover, this versatile PowerPoint to DVD Converter also helps convert PowerPoint to all popular video formats like AVI, MP4, FLV, MPEG, 3GP, MOV, WMV, MPEG1, MPEG2, MP3, AAC, etc. Then you can watch PowerPoint on iPod, iPhone, PSP, Apple TV, Zune, Creative Zen Player, Black Berry, etc.
PowerPoint to JPEG Converter can convert PowerPoint to JPEG image file and convert PowerPoint slide to JPG picture file. It is the best PowerPoint JPEG converter and PowerPoint JPG converter, which is both powerful and easy to use.
Microsoft PowerPoint 2007 are supported by this PowerPoint converter, it can convert .ppt, .pptx, and .pptm files to all popular image formats with fast speed and excellent image quality.
PowerPoint Slide Show Converter,
PowerPoint to SWF Converter,
PowerPoint to AVI Converter,
PowerPoint to MPEG Converter,
PowerPoint to WMV Converter,
PowerPoint to MP4 Converter,
PowerPoint to FLV Converter,
PowerPoint to iPAQ Converter,
PowerPoint to iPod Converter
Aug 11, 2010 | Computers & Internet
Video in GoTo
This is actually quite common when using powerpoint files with online tools. From the guide:
"A current constraint of collaborative software (including
GoToMeeting) and the bandwidth connectivity to sites is that digital video-clips are NOT
transmitted satisfactorily. The sampling frame rate is not adequate for high quality motion.
To overcome this and provide the clips in their original quality to the virtual participants, the
transfer the powerpoint files and the associated video clips is undertaken as a routine
practice. They are then manually played at each site on adequate pausing and cueing from
you the speaker. It is advisable to confirm that they have viewed the clip before proceeding.
Given notorious incompatibility problems with wide variety of video standards, file formats,
proprietary codecs (for compression/decompression) and the main players (Windows Media,
QuickTime & Real), it is essential to have a technical pre-check of the clips completed in
advance at each site. This is scheduled for the inclusion in the technical testing on the
Wednesday immediately prior to your seminar.
NO audio track should be included with the video clips. This avoids the potential problems of
audioinstabilityor‘howl-around’totheconferenceandallowsyoutoprovidethesingle
commentary."
Sorry that formatting is a little sloppy. Hope this helps, and I'm not sure about the last part of what you said, in regard to media player being choppy. Were you saying that you played the source video locally in media player and it was choppy? Cause that would be another issue ;)
Feb 19, 2008 | Citrix GoToMeeting
Adding music to a powerpoint presentation
Does the music file play when you click on it? (Drag the sound icon someplace visible on your slide and preview it.)
If it does play when you click on it, you just need to animate the music. The sound file has to be a part of your slide animation--that's what tells it when to start/stop playing. When you insert a sound file, PPT may ask you whether you want it to start automatically or wait to be clicked.
Or, you can right-click an existing sound file and go CUSTOM ANIMATION. Depending on your version of PPT, what happens next will be different. But you should be able to set the sound file to play when the slide displays without being clicked.
Dec 03, 2007 | Computers & Internet
HP VP6121 Multimedia Projector Logo
2,192 people viewed this question
Seeker5211
Seeker5211
