Question about Samsung PCK5315RX TV
Double vision the t.v. is giving a blurry double vision. It was fine last night and now it appears the colors to be off. I can see the 3 different lights for the rear projection. i am a novice at this stuff.
  • Anonymous Mar 30, 2014
    The colors are askew giving the picture a double vision appearance. The red and blue in particular are not cohesive. I can see the same image side by side.
I thing you have bad convergence board (right side small board
silver heat metal that number start STK-?????) and check resistor maybe open
Posted on Feb 20, 2009
How come when I take pictures they are coming out blurry? Even when the subject is completely still and I let the camera focus before I click it still comes out blurry? Do I need to change a setting on my...
This kind of issue is usually caused by the night vision mode of the camera being switched on.
In some cases, the cause may be more than just the night vision being turned on but just to be sure, it is advised that you turn of any function that has to do with the night vision feature.
These features may range from the night vision mode itself and then to the night vision lighting.
Hope this was helpful?
Feb 22, 2011 | Nikon Coolpix L110 Digital Camera
My 50" Toshiba has a color problem!!!
Ur convergence is dead.Must replaced the 2 Convergence ICS and all it resistors.By replacing these 2 convergence ICS well solved these problems colors misalign, 3D double pictures,blurry pictures.The shop will cost U $300 for parts and labors.
Jan 23, 2010 | Toshiba 50H81 50" Rear Projection...
Different color shadows. Double or triple vision
replaced convergence IC.what is the model#?
Oct 04, 2009 | Televison & Video
Blurry screen double vision picture
The convergence circuit has failed. It is not a easy fix due to the tear down needed to get to the circuit area. I would call Mitsubishi at 18003322119 to get a Authorized Service Facility to check it out and give you a estimate of repair cost.
Jun 22, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Blurry vision on logitech quick cam
1. adjust your webcam lense upper scrolling
part
2. adjust the settings of webcam software to
make sharpen etc.,
3. hope this will help you out
thanks.
ehsan.. (md_ehsan_1@yahoo.co.in)
Jun 16, 2009 | Logitech QuickCam Communicate Deluxe...
Light worked fine for a while, then became intermittent
try holding it for 15~20 seconds or until the light goes out then try it again and that should give u 3 mode
Jan 08, 2009 | Inova MICROLIGHT
Sony rear projestion TV has blurry picture.
sounds as if your convergence needs to be set. either through the menu on the tv or remote you need to get to the convergence set screen and you need to line up the crosshairs. this usually happens when the tv is moved or bumped.
Dec 31, 2008 | Televison & Video
Double vision
Hello my name is willie. I see this problem alot on these units at the shop. And from what you describe. THis might be the very common problem with the fl231 fuse. this is a very fine fuse that blows due to bad solder connections. If u can solder and get this very special fuse then this is a very easy simple repair. But the first question you can answer to determine if this is true. is that when you go into customer menu then setup do you have a convergence option in the menu if you do not it is definatley this fuse. if you do then it will be something else like convergence power board. let me know if it is and i will see if i can talk you through the repair.
Aug 27, 2008 | RCA R52WH73 Projection Television
J.v.c. big screen tv 56-58 inch
my jvc big scrreen worked just fine last night and this am i turned it on and the color is greena and red with double vision can you help
May 25, 2008 | Televison & Video
Televison & Video Logo
97 people viewed this question
Jerry Greenberg
Jerry Greenberg
