Question about Kenmore 47783 Electric Single Oven
Kenmore door locked
My kenmore door is locked and wont release
can one release the catch = two day old chicken stuck in there - not a rat fan!
  • rezial Jan 29, 2009
    Thanks !! It never occured to me to throw the breaker. I have been pulling the oven out and unplugging it. I will try the tapping the door next time. For now I have fixed it by wedging a small nail in the latch so it wont close. And you are right, it sometimes shows the cleaning light on so I think it is registering as cleaning and locking shut.
  • 979 Answers
Try pushing and holding the door shut. Then moderately tap on the door where the latch is and it may come loose. Usually it is mechanical and not electrical here. Could also be if you have a self cleaner on it, that it is reading that you are cleaning the oven. If the first thing does not work, then turn off your breaker for about 15 seconds and then back on. Sometimes it may reset itself and put it back in working order.
Posted on Jan 29, 2009
Opening door catches
pull down the door hinges there is a slot turn it and it will lock the hinge put the door back on turn the slots back
Dec 01, 2012 | Neff B1421 Electric Single Oven
I meant to set the pre-heat on my 26 year old Kenmore oven but turned the dial to the clean by mistake. Now the door is locked. What can I do to release the lock?
Set selector knob it to clean, push in and turn the Stop time ahead. Wait for the motor to complete latching the door. turn selector to "Off" and wait for motor to unlatch door. If it's stuck you can either manually unlatch it from above or rear or use a coathanger wire made into a hook to catch and release the door "hook"
Sep 21, 2010 | Ovens
I have an older model double oven by Kenmore - probably 15-18 years old. I was baking bread in foil three days ago and the oven set on bake 325 degrees. (I had been cooking a roast in it for several hours...
the oven may have locked in consequence of the self cleaning cycle.
After unplugging, allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Kenmore at the number listed on the owners manual.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I cant't get the lock to turn off
Try cutting the power to the oven for about 20 minutes and see if it will reset and release the door lock. Hope this helps.
Nov 18, 2009 | GE Ovens
Hotpoint self-cleaning oven will not release door latch and open.
no you will have to replace the catch if its more than 20 years old maybe you should think about buying a new oven
Sep 27, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Older oven stuck on Clean and door is locked.
does your oven have a lift up top if does. lift up burns and silver box open box and you can unlatch the lock. hope workds
Apr 23, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven locked
Hello dktshopping,
I know you probable don't want to hear this but in you circumstance, I think you would be better off to contact a repair professional. Those oven door locks are meant to keep the door from opening during the oven's self-cleaning cycle. They are both mechanically and temperature controlled so that the door can not be opened when the oven is 950 degrees. It sounds to me as though something is not releasing to allowing the locking mechanisim to disengage from the door even though the lever is in the unlock position. The unit will probably have to be taken apaprt to remedy the problem. Good luck.
Nov 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore double oven f4 fault code - door locked.
We had the F4 problem and called Sears repa. They sent someone out. The guy opened the panel above the bottom oven (we have a double oven) and hit a reset button - then charged us $75. This has worked on several occasions (my husband did it after that). But then that didn't work and Sear's told us it was the electronic panel which they replaced twice. Now it's (F4) happened again on the top oven only on a brand new electronic panel. So I guess it's the heat sensor this time.
Dec 31, 2007 | Ovens
Ge wall oven blinking door locked for days
The switch inside the door lock mechanism is stuck down making the unit think it is still locked.  the switched is located next to the hook that locks your door.
Oct 29, 2007 | GE Profile JTP56 Electric Double Oven
Kenmore 47783 Electric Single Oven Logo
156 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
