Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Corrupted data since a few days, my camera indicates corrupted data to some of my pictures. I tried to format my scandisk card 512k, but half of my pictures get corrupted. I heard that it is possible to fix this problem by removing and connecting again the internal battery. Is is a reliable fix? Is there anyone who knows where this internal battery is? Thanks Spinhole
  • 4 Answers
Canon S400 IXUS 400 ? The fix for ?memory card errors? The only tool you need is a small ?jewellers? cross head screwdriver. the procedure is not difficult but you need to proceed with care on a well-illuminated, flat, plain surface. Switch off then remove the rechargeable main battery and the memory card. Now remove all the small screws around the casing. These screws are of different lengths and it is important to lay them out in a logical manner so that later you can replace them correctly. If you use a teatowel to take it apart on the screws won?t roll away. Note Do not remove the main rechargeable battery release catch. It's a MAJOR job to put it back together. Carefully separate the halves of the casing. The lithium battery is at the front under the bottom right hand corner of the copper coloured flexible shield. The internal disk-shaped 3-volt lithium battery is about 6mm across. Be careful to disassemble the bare minimum necessary. If you see a spring popping up, you are disassembling too much. Remove this battery, taking care not to touch the side and bottom simultaneously with a metal implement. After about ten minutes, replace the 3-volt battery. Reassemble the metal case taking care that the sliding switch for the take/review function is correctly located. The 2 halves of the case fit perfectly, if you can see any gaps you need to just check the overlapping metal plates are fitting together properly, you don?t need to force anything. Be sure that the rubber jack socket cover - is seated properly whilst you reattach the rear part of the case. Replace the main rechargeable battery and the memory card. You will have to reset the time and date data as they are deleted when the 3-volt battery is removed. You may find the video replay system has to be reset If you don?t get the date/time screen after switching back on you have not left the lithium battery out long enough. You should find most user settings and, the last image file number are kept. Too scared to try this? You can leave the main battery out of the camera for at least a month and the small Lithium will run down and eventually reset itself. By the way Canon know about this fault and should fix it for free but the notice is well hidden on their site and if you don?t know about the issue they will bill you for the ?repair? Firefly With thanks to the people on dpreview.com forum who helped me solve this one.
Posted on Dec 06, 2006
SOURCE:
Formatted scandisk in casio camera
Unfortunately, yes. That is why we always advice to back up all data before proceeding with the format.
Jun 16, 2010 | SanDisk 1GB microSD Memory Card
Message Unable to use card.
I've seen quite a few problems regarding memory cards recently.
Most of the time it is the card at fault as it just does not store data anymore. I haven't yet determined if it's time/ use/ temperature or handling which is causing the faults.
Can you describe what happened prior to the card not working as it may help solve future problems?
Some older cameras cannot use the newer - larger cards (even though they fit), and some cards won't record panoramic data.
Try resetting the camera first. - Remove batteries and card for 10 minutes, then reload them.
If you normally use a PC to download the pictures, see if you can access the pictures from there.
If half have gone, or are corrupted, it's time for a new memory card. Films were 1 shot, now cards only last a few years, but still saves you £ / $ in the long term.
If the new card doesn't work either, you will need to re-install the camera software (or Driver). This should be on a CD or you can go to their website to download it free.
Thanks for using Fixya! If this solves the problem, please rate as such. Thanks.
Jul 03, 2008 | Konica Minolta DiMAGE X50 Digital Camera
"Unidentified Image"
you need some image recovery software that will fix the files that are corrupted
May 29, 2008 | Canon PowerShot S3 IS Digital Camera
Camera card not holding pics
Van D UK is right. It seems suspiciously like a memory card corruption problem - maybe caused by the combination of the red battery light coming on and the act of taking the picture.
If you remove the scandisk card (camera off) and use a card reader to view the contents on a computer, you maybe can see if the file structure on the scandisk makes sense.
Presumably you have the camera user manual. This might help.
There might be some info about how to set up a new scandisk card. You might be able to rescue all the photos you have already on the existing scandisk card. I suggest you rescue them as a priority if you can. I suggest too that, in future, you download as a matter of habit all your photos (regardless) onto a computer. Having rescued as much as you can you can either re-format the existing scandisk card using the camera (if you can) or buy yourself another scandisk card.
I have had similar problems with my Sony camera and card. Try and get the correct card for your camera. I got some cards simlar to a Sony card but in the end I could only use one of them in the camera. The other had to do duty as file storers/transferers.
Mar 17, 2008 | SanDisk Memory Media
Error 30
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Error 30
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Error 30
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
Error 30
The "E30" error code is displayed when reading/writing data on a CF card has failed. Especially, the error code "E30" may appears when you tried to remove a CF card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the CF card with your camera Try to format the CF card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting CF cards. Also, please note that formatting a CF card will erase all data on the card. Once the CF card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the CF card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the CF card.
Aug 29, 2005 | Canon PowerShot A310 Digital Camera
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
254 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
