Question about Magellan Roadmate 760 GPS Receiver
Magellan 760 does not find satellites
I have the "factory installed" looking version of the Magellan 760 only for a year and it now will not lock onto any satellites. Any suggestions?
Thanks,
mhenderson@fbns.org
  • Anonymous Dec 30, 2008
    Magellan 760 does not fins satelites
  • emg0415 Mar 16, 2009
    Same problem...I have initialized the GPS from the config option, reset the GPS status and location and the unit still does not lock on to any satellites. Help...
I recently i had the same issue. Open the four screws from back. remove the back cover carefully (tahe care of the attached cables).
check the atena wire connection (gray thin wire). both the ends should be seated firmly.
in my case, soldering at one end was broken. had to resolder. its working now.
Posted on Mar 25, 2009
I have a magellan roadmate 760 with an external antenna that plugs into the back of the unit with about a 2-3 inch wire. the antenna model number is m812b. The whole unit is incased in a plastic surround...
hi dmdalyai,
if its stuck in one location and you can navigate through the unit (like enter addresses ect.) then its an antenna problem...make sure it has a good charge on it and verify its charging in the power options tap, then take it outside in clear view of the open sky and turn it on, then give it up to 30 minutes to lock on to the satellites....
let me know how you make out, if that didnt help, you might want to try another antenna...is there something wrong with the built in antenna (the one that flips up on the back of the 760 ?
bill
EX Expert Moderator
Standing Member of G.O.T.
Oct 11, 2010 | Magellan Roadmate 760 GPS Receiver
Magellan roadmap 760
The Magellan 760 has been around for a few years now, and unfortunately, isn't one of the fastest units around when it comes to synchronizing to a satellite. I find with mine that the time it takes to lock onto a signal depends on several factors:
1) Having the GPS mounted in a way that allows the antenna to have a clear view upward 2) Having my vehicle in the open, so that the signal isn't impaired by adjacent buildings, overhanging trees, etc. 3) Being stationary while the GPS attempts to get a lock. It has more problems locking while moving. 4) Ensuring that the GPS is used frequently, as it loses its memory of what satellites it's synchronized with if you happen to be in a different place when you turn it on than the place you were at when you last turned it off.
Those last two points have the most affect on my GPS's performance. I find that by turning on the GPS and just parking in my driveway or parking lot for a few minutes will allow the GPS to acquire a signal in a much shorter time than if I start to drive immediately. While this will waste a bit of time on the front end, it does help you get synchronized more quickly
May 27, 2009 | Magellan Roadmate 760 GPS Receiver
Stopped connecting to satellite
check battery condition also go into set up and see that the baud rate and port are set correctlyb in accordance with the manual.
Please rate my help++++Thanks for using FIXYA
May 20, 2009 | Magellan Roadmate 760 GPS Receiver
I'm trying to update a Magellan map update on my 760
plke1691
I think your problem is that you are using XP with SP 3, you cannot use anything more than XP SP2, so find yourself a friend that have an older operating system and update it. I bet you will not have any problem
Auto Nav 2000 aka GPS4ME
Apr 30, 2009 | Magellan GPS
The weakness of the 760 is the cradle. Is the power wire or the cradle loose or wiggles? You may need to buy a new cradle if that is the case. They are expensive. I soldered my power wire right into the cradle and it worked fine.
Aug 26, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan 760 no satellite signal
I got a Roadmate 760 from my employer to use. It won't pick up my current location and is not working right. Help!
Jun 14, 2008 | Magellan Roadmate 760 GPS Receiver
What software version is included with the Magellan 760
Magellan® RoadMateTM 700/760 Map and Software Update Version 6 is the latest updated version of this unit.
The version that would have been included with a purchased unit depends on when it was bought.
Regardless of the previous version number, Update Six can be purchased and installed for $79.99.
May 02, 2008 | GPS
Unit will not acquire the satellite signs
FYI ....My Roadmate 760 would not aquire a signal, I went to diagnostic screen and found it was detecting/tracking 0/0 satellites. Held the plugged in unit out the window and within 10 seconds was tracking 7 satellites! Turned out my 1999 Olds Silhouette Van has a anti-glare filter inside the factory windshield that blocks GPS signals.My wifes 2001 Chevy Impala also has same type filter. Check your windshield, filter is visible inside glass to within about three inches of edges of glass. Worth a look.
Dec 29, 2007 | Magellan Roadmate 760 GPS Receiver
RoadMate 700/760 Version 6 update maps are over a year old!!
THE CURE for this problem is NEVER BUY Magellan again!!
After paying over £800 for an early Roadmate 700 (which failed and was replaced by a failed/recon version) then to have problems with software.. now having waited a year to get map update and version 6 firmware I find it doesn't give me Magellan Tools which was promised by Magellan Support.
After several mail queries and important qustions remaining unanswered I am buying a Tomtom Go 720T which will do all the updates automatically via a cradle linked to my PV/Internet.
NEVER EVER AGAIN a damned Magellan - great when it works but it's easier to get blood from a stone than good support from Magellan.
Dec 28, 2007 | Magellan RoadMate 700 GPS Receiver
this is a known issue with the power dock on the back. It needs to be replaced.
Aug 14, 2007 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 GPS Receiver Logo
212 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
