Question about KitchenAid 24 in. KUDS25 Built-in Dishwasher
KitchenAid Dishwasher Leaking from under Door
My KitchenAid dishwasher is about 8 years old (came with the house). It is an upper-end model KUDR25SH Whisper Quiet Plus.
After the washer recently leaked a bunch of water, I took off the bottom metal service panel, and loaded up the washer (2 weeks after the first incident).
The first 5 minutes ran fine with no leaks. Then I heard the washer switch to the next cycle (whatever that is), and that is when water started dripping from under the door.
I'm guessing the problem is the door gasket/seal, since there was no water under the motor or under the unit hose connection (which I had tightened up previously).
The door gasket feels fine, it is flexible and not brittle or cracked, but does have water staining on it and could use a good clean.
I would like to know if a dirty gasket is sufficient enough to cause a significant water leak like this. Before I order a new gasket, should I bother going thru the effort of cleaning the gasket to see if that will fix it?
  • emcozic Nov 04, 2008
    I use the little Cascade soap blocks that you tear the plastic off of, so it not a matter of too much soap.
  • Anonymous Nov 17, 2008
    Not all the time, but my door seems to leak at the door rubber seal. Is there a problem with the seal or something else?
I had a similar problem with a KUDM25SHWH1 dishwasher. Rubber seal looked fine. I found an incredible tip on another fixi it site. One possible problem iss the pump cover screws may have worked loose and is squirting water directly on the door seal. Man that was it! I saw a couple of looses screws and a small portion of the pump cover gasket showing. I loosened the pump top, reset the gasket tightened it all down...no leaks! The pump I refer to is located directly below the spray arm inside the washer. Easy to get to. Another tip was to look for a split sspray arrm that may spray water directly into the door seal.
Posted on Mar 30, 2009
  • John Smith
    John Smith Nov 23, 2013
    That was it!. Took me less than 5 minutes to fix. Thanks for you help. My wife wanted to just replace the dishwasher.
Open door and check if Gasket is worn especially around bottom corners.
Clean casket and bottom around door.
Use 3M 5200 and place a small amount around effected area.
Use a small piece of wax paper and place between door and gasket.
Close door and allow to cure fro at lease 24 hours.
This will form a new gasket and the wax paper should prevent sticking to the outside door.
Caution use only a mall amount of 5200 and don't get any on you.
Posted on Jan 10, 2009
    Sergeant:
    Champion:
  • 324 Answers
Sometimes the dishwasher will leak when you use to much soap,or you get dish soap in the machine.the suds will leak out.try putting it in a wash with no soap the when you hear the water slosshing around then open the door and see how much suds are in it.
Posted on Nov 04, 2008
KitchenAid Whisper Quiet Plus dishwasher Location of serial number
Usually, the sticker is located on the inside edge of the door on either the left or right side--you have to open the door to see it.
Aug 19, 2015 | KitchenAid Dishwashers
My dishwasher drawer is not draining the water well after the dishes are washed and then is smells. How can unclog the drain so that it will drain? the filter is clean.
The pump may be worn so it doesn't pull all the water out.
Or a bad check valve so it allows water back into the washer after it was sucked out
Jun 18, 2015 | KitchenAid Double-Drawer Dishwasher System...
Kitchenaid whisper quiet plus dishwasher
It is likely the thermal fuse is cut off and will need to be reset or replaced depending on the model number of your dishwasher. Please provide actual model number in the comments.
Apr 25, 2014 | KitchenAid Dishwashers
Child lock blinking on a Kitchenaid ultima diswasher.
Try holding the E.S. button down for 30 seconds. Does not work, you need an Electronic control assembly which can be ordered online from Repair clinic .com for $146 for your model plus shipping. This is apparently a common problem with Kitchenaid dishwashers. Just repaired one the other day. Tried everything, but as soon as the new Electronic control assembly was installed, everything was Okay. This is an easy repair for anyone who is handy at all. Please shut off power to the dishwasher by switching the breaker off or removing the fuse.
Feb 04, 2010 | KitchenAid KUDR25 Dishwasher
My dishwasher runs fine but has become very noisy. is that a problem? it used to be "whisper quiet" & now it sounds like a drone
usuallly a pump motor asssembly is required.. most had a five year parts warranty and if out of warranty most assembly are 100-300 dollars for the part.
Feb 03, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Broken part, need model number
I found a website called Partselect.com and they have very good pictures of exactly the part I need. I ordered it from there.
Jan 01, 2010 | KitchenAid KUDP01DLBL Split-Control...
Kitchenaid Whisper Quiet + dishwasher making loud humming noise
Very likely pump motor shaft seal leaks water into bearing casing buildup of rust and consequently noise. I just replaced $112 worth of pump assy and it's back to normal. I would also buy repair manual for $10 on-line to be sure how to disassemble the sump to get to the pump.
Jul 14, 2009 | KitchenAid Dishwashers
Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Apr 14, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Water leaking from botom of Door
see if float cup is free on bottom of machine so it is not overfilling. take old toothbrush and clear any accumulated soap buildup from bottom of door and gaskets.
Feb 16, 2009 | KitchenAid Dishwashers
Dishwashers Logo
6,758 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
