Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Misaligned Convergence All images are Blurred( ghosting) how do you repair a misaligned convergence? I knwo it is not anything external( since it does it even when just looking at the menu)I Unplugged if for two hours but it still does it.
    Genius:
  • 1,694 Answers
LCD rear prjection TV's do not have convergence amps.......
Problem is rightly called ghosting....Your Hitachi- experienced
service tech will check the ghost adjust at I2C menu pg.57 in
service manual. Or research ghosting at HitachiServiceUSA.com
Hope that helps.....T.
Posted on Nov 07, 2007
    Sergeant:
  • 337 Answers
Is anenvolved job to repair a convergence problem,the way to go about it is to locate the convergence amplifier IC's,one for each color(red green,blue)check for loose conections at the ic's legs,after resoldering all the legs see if an improvement is present if it gets better you will be able to adjust from the custumer controls,but if no improvement the Ic's will have to be replaced.Some units have a separete board were you can adjust convergence after replacing the Ic's and other units you have to access the service menu to be able to do the adjustments but just doing this adjustments can be very challeging even for a train technician,I would suggest you seek assistance from a servicer and get an estimate.
Posted on Oct 02, 2006
Ghosting or a 3D image. A yellow and blue ghosting or shadowing image. Looks much like the top picture in the "picture ghosting image" entry. Is this a convergence problem?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 09, 2011 | Toshiba 50HX70 50" Rear Projection...
How to find convergence menu
Is your convergence misaligned. Customer convergence is located in the main menu under setup. Now if you do not have this you most likely have the common and easly and inexpensivly repaired. If you cannot find the convergence options. read this to see if it might be your problem
http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in
Mar 04, 2011 | RCA HD61W66 61" Projection HDTV
I have a Sony projection TV KP-53HS10. From one
It is most likely the convergence board. Rear projection TVs use three lights to display the image. The image is aligned via the convergence circuit. After many many hours of use the capacitors and resistors on the board lose their tolerances. It is very expensive to repair if you take into account the price for a new TV and the quality of the image you will be getting if you do have it repaired.
Mar 01, 2011 | Sony KP-53HS10 TV
I have a jvc projection the top of the screen is misaligned (drooping)convergence dosent help whats wrong
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Televison & Video
RCA R52WH74 PIC IS DISTORTED LIKE HOUR GLASS FROM LEFT TO RIGHT AND COLORS ARE MISALIGNED SO YOU GET 3 IMAGES OFFSET FROM EACH OTHER IN DIFF COLORS
The ITC222 convergence option missing repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the parts and the CD with instructions.
Nov 14, 2009 | RCA R52WH73 Projection Television
Double image, green and yellow ghosts, blurred image - Flash Focus does nto do anything, convergence adjustment does not work at all
That means convergence out ICs are not working, requires replacement.
If you want to replace convergence out ICs, let me know to provide you technical info.
Thanks.
Aug 17, 2009 | Sony KP-51WS510 51" Rear Projection...
Color video rear projector...........color red is misaligned
convergence amplifier ICS !!! replace them and associated pico fuses ICS # start with STK
Dec 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
218 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
