Question about Numark TTX1 Turntable
Numark TTX1 Turntable Problem-Platter stops
Hello, both ttx turntable when i hold the platter, stop and dosent turn alone i need to give it a slow push, plus on ocations, when i press stop and press again star dosent go ahead, need to push the platter, what can be the problem?
Thanks
Wilfred
will_dj91@HOTMAIL.COM
  • WILL_DJ91 Nov 04, 2008
    Hey all credit here gopes to DJCiscoElnino@aol.com for coming up with this mod/fix.
    ok here goes
    original asisphonics link: http://www.asisphonics.net/ubb/ultimateb...
    Text info:
    Cisco el Nino - "since numark fixed thier overheating problems by adding a vent under the platter, i think that what is happeing is that our DC MOTOR DRIVER IC (Toshiba TA7259P) has gone bad what i am going to do it order this, install it and let you know the deal. there only 5.80 a piece and shipping is like 8 dollars. ill get back to you. I am guessing it is sort of like computers CPU, like its got thermal gel/grease on it and all that fun stuff. It is on the Motor's board heres the image
    (IMG:http://img97.imageshack.us/img97/9139/tt...)
    after i install it too, i am also going to cut vents like this under my platter like the updated versions
    (IMG:http://img97.imageshack.us/img97/8523/tt...)
    also take your time when installing the chip.
    1. its sensitive to static.
    2.buy a low heat soldering iron.
    3.do each solder point at a time, wait a few seconds for the IC to cool off. then approach the next.
    also open your ttx and see what exact IC you need. Mine was a Toshiba TA7259P. Also when you order that, order small tube of thermal paste.
    http://www.audiolabga.com/ for parts ordering"
    Thank DJCiscoElNino@aol.com
    Mad props. This elongates the life of the Numark TT turntable series indefinitely, because they are good turntables, but they had this problem. Well, no longer.
  • kerrycoxy Nov 16, 2008
    my numark decks have stopped working
  • 515 Answers
This is a drive issue. Unfortunately the TTX direct drive system isn't the greatest. It's good, but it's no Technics 1200. The only way to 'fix' this issue is to have a professional look at main circuit board to see if there are any components which are burned, or damaged in any way.
Hope this helps some.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
Posted on Nov 04, 2008
  • TERMiNAL OPTiC
    TERMiNAL OPTiC Nov 05, 2008
    DJ Cisco El Nino was spot on with the repair. The IC he referenced is one that causes many problems, especially on older TTX units, and is usually the one we replace. This is part of the direct drive system of the TTX, and prone to issues. Of course, not many people are handy with a soldering iron, which is why I recomended you see a service technician - there are about 8 pins per side, and you have to be careful when taking off and putting on the new chip. Just follow the instructions El Nino gave, and you'll be fine.
    - OPTiC.
    www.djprolab.com
Numark ttx/ttx1 pitch fader wonky
Try spraying the slider with Servisol Video 40.
Mar 15, 2013 | Numark TTX1 Turntable
Turntable platter doesnt spin when you press start/stop
Is your turndable belt driven? If so replace the belt.
Jun 05, 2010 | Numark TTX Turntable
Start/stop button doesn't move platter
nakered switch then needs replacing
Aug 07, 2009 | Numark Pro TT-2 Turntable
Numark TTX-1 turntable starts slow but then is okay.
A drop or two of light oil at the center of the spindle will surely solve the problem.Remove the platter and check if its clean
Jul 06, 2009 | Numark TTX Turntable
How do I remove the Numark TTX platter
Nope, nothing to it. The platter is just held down by gravity. Take a mallet or a piece of 2x4 block, and give the spindle a little whack. Not too hard, just enough to break the hold.
- OPTiC
Numark Repair Videos
Numark DJ Repair
DJ Equipment Sales
Numark Parts
Jan 04, 2009 | Numark TTX1 Turntable
Numark ttx turntable
More than likely the drive IC (integrated circuit) has shorted, and needs to be replaced. Not an easy fix, and you'll have to take it to a service center for replacement.
This is a common problem on this turntable.
- OPTiC
Turntable Repair Expert
Nov 14, 2008 | Numark TTX1 Turntable
Ttx 1 numark
hiya fixya...well i just opted,,,to take the thing to the repairs.the conclution is that the"platter rotation sensor " had burned out.sent the deck off today.will let you know the outcome,to maybe pass on this info to other ttx 1 users for near future....thanks for your responce.quote 35 quid just to confirm problem...but deducted from final bill of??????.westend dj staff are very helpful indeed where i puchased them from in the begining.
Mar 31, 2008 | Numark TTX1 Turntable
Just so you know, there is no actual 'motor' driving the platter. It's a direct drive unit, so it's made up of various circuits driving the unit.
With that said, anyone of those circuits could have gone bad. The good thing, is that most of the circuits (resistors, IC's, capacitors, diodes, etc), are relatively cheap ($2-10), the bad thing is replacing them, and finding out which ones are faulty. You could usually tell which resistors are burnt or caps are blown, but it's harder to test the IC's without the proper equipment.
This is not a cheap turntable, unless you think $300 is cheap for a turntable. Repair wise, your probably looking at about $80-120 for parts and labor. It's a well build turntable, and I think worth investing in trying to get it repaired. Just make sure you get an estimate before any work is done.
- TWEAK AV LAB
Nov 26, 2007 | Numark TTX Turntable
Numark TTX1 Turntable Logo
2,276 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
