Question about Maytag LAT3600A Top Load Washer
MAYTAG LAT9235AAE TOP LOAD WASHER WILL NOT WORK
My Maytag clothes washer fills with water but will not run after that. The timer moves thru it cycles and nothing happens. I have check the water level switch by hitting it with a screw driver and also blowing in it to see it will start...it will not. I have continuity in the lid switch, motor and timer thru its functions...What am I missing. Some tell me it is the load switch and other say the motor....anyother suggestions....I do not just want to buy another one if this is such a quick fix!!!.. Please help!
  • phil smith Oct 08, 2006
    It was the timer! It was my original guess but was looking for the cheaper solution. An entire contactor arm was burnt up and gone. Cost anywhere from $70 to $100.
    President:
  • 878 Answers
Pt, Should be a yellow wire from the water level switch according to the diagram I have. See if it has 120V to motor when full. Just take it to ground. Same with the lid switch in closed position, it shows here as yellow, but could be grey, these diagrams are not always accurate. I think you have a level switch or lid switch problem. Check for voltage to the motor when it should be agitating. Catriver..post back.
Posted on Oct 02, 2006
Maytag top load washer model LAT9235AAe will only run when dial turned to final rinse position.
HI. this is a fairly simply fix here. the timer mechanism is damaged. The timer motor is not providing proper rotation, that is required for forward advancement of the cycle selected. It should be replace asap, if possible.
Sep 06, 2009 | Maytag Washing Machines
Maytag washer will not cycle.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MAV6000AWW washer will not run thru cycles consistently
yes it would be the timer but they also stop if it gets off balance if its just off balance u should be able to lift the lid rearrange then start it again if that doesnt work it is the timer
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Mar 13, 2009 | Washing Machines
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
LAV3600AAW Maytag Top Loading Washer
check your house drain make sure it is above water line in tub
Nov 30, 2007 | Maytag SAV5710 Top Load Washer
Maytag LAT9235AAE fills with water....
Pt, as long as you verified the lid switch is good, do this simple test. Get a piece of hose the same size as the one going to the pressure switch, connect it and blow into it. See if it starts agitating. If it does, there's your problem..Catriver post back.
Sep 27, 2006 | Maytag 22 Cycles Topload washer, SAV365Z
Maytag LAT3600A Top Load Washer Logo
231 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
