Question about Kenwood KDC-1028 CD Player
Will not read cd's and it doesnt want to eject
I had this cd player for 1 day and everything worked fine the first day it was installed. then the next day i go to put in a cd and it wont read it. i get an E-04. i tried about 15 different cds. then i go to eject the cd and it comes out partially but i have to put another cd on top of the cd thats in the player and let the cd slide under it to get it out. what might be the problem. thanks
SOURCE: Kenwood KDC-2025 won't play CDs
hey it does not play mp3 discs. u need a regular disc. mathews
Posted on Apr 04, 2008
shaggyrat
  • 1224 Answers
SOURCE: CD won't eject....
you need cleaning and maintenance on your radio if you want to eject the disk theres a little tiny button on the face you will need a pin push it in and this should eject your disk
Posted on May 07, 2008
  • 323 Answers
SOURCE: CD player wont come on was doing weird things
You have your accessory wire (red wire) and remote ran together and the yellow (constant wire ran separately in the dash?
You need the red wire to so you can use accessory and to turn off your cd player when your vehicle turns off.
You need the yellow wire to keep all your settings stored. base/treble/time clock
Just a little clarification. Your amp turns on with the remote wire (blue) wire, if that is not hooked up you will get no power to the amp.
Here's the in-dash diagram to your vehicle at the bottom of this pdf.
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
You want to focus on N,O, and P
Do you happen to have an after market wiring harness? These can be bought from walmart for your vehicle. You just take the male end connect the colors together and plug end that goes to your cd player into the female end. Very easy to do.
Windshield wiper issue: http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32492d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock01.pdf Check C1002, 1003, and 1004 under your hood.
You could also have one of these fuses out under your hood, that might cause you to lose power to everything.
http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32493d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock02.pdf
Let me know if you need more assistance =)
Posted on Feb 10, 2009
kenw392
  • 2226 Answers
SOURCE: ERROR CODE E4 WON'T LET ANY CD'S PLAY ON MY EUROVOX CD PLAYER.
you may have a dirty laser lens. if you know how to remove the deck, you can clean the lens with rubbing alcohol and a qtip. you need to be very gentle cleaning the lens.
Posted on Jul 15, 2009
SOURCE: i hooked up my kenwood kdc 128 cd player and nothing works
i had the same problem as you, i own a 98 ford escort, and i couldnt find a wiring diagram that matched the ones in my car . i managed to connect the constant (red) and switched (yellow) to the wires in the car but i had made a mistake with the ground (black) . so i re connected it to where its suppose to go so now the head unit actually lights up and turns on.
now i have another problem because my head unit doesnt stay on for any longer than 1 mintute
Posted on Aug 27, 2009
Cd gets stuck in recorder makes clicking sound..
I would just guess that the belt that is in the eject mechanism is now stretched- That is if there is a belt. That is very common in all CD player units.
Feb 12, 2015 | Tascam Dp-02cf Digital 8-track Recorder
Half an hour ago the player was still working fine. Now it's impossible to eject cd's and the player itself gets confused cause the cue goes on and off by itself and playback skips. HELP
The CD drive in your CDJ is hunting for the disc, i.e it has become difficult for the player to read the disc. Keep your ears next to the loading slot after inserting a CD, you will hear a motor spin up then slow down then spin up again and if this continues the system will lock out the eject function. Or else the disc will come flying out!!. Either you need lens cleaning ( try a cleaning kit ) or replacement ( If the player has crossed over 500 hours of use )
Mar 09, 2011 | Pioneer CDJ-100S CD Player
CDJ-200 keeps ejecting disk without reading it. Tried to clean with a disk, and with compressed air, but it's still ejecting any CD that I put into it. It was working fine while I was mixing, and then just...
hii there,
Please also let me know if u get any error msg too. If dont get any
error msg. Please try to clean compartment of ur CDJ. But you have to open ur CDJ than clean it. If it does not work again. Then ur
CDJ need adjustment or alignment.
thx,
djajay
Aug 09, 2010 | Pioneer CDJ-200 CD Player
Have a jensen vm9021ts that wont feed in cd's, play them or eject
good day just look for a qualified technician to repair the mechanical problem in your car video player.
Jun 21, 2010 | Car Audio & Video
I cant eject my cd
There is a indent in the front of the face of the radio. Try to push it with a sharp pencil or pen. It might reset the cd part and eject button might work again. If not you may have a cd stuck in it then you can try get tweezers and pull it out or a credit card and try to straighten it out. Those were some of the techniques I used when I was an installer for 12 yrs.
Apr 07, 2010 | Sony CDX-M630 CD Player
My pioneer cdj1000 mk3 will not read any cd, it doesnt even sound like it's reading it. it just ejects & i just finished using it last night and there was no problems with it.
The IC protector is burnt out u need to take it to a tecnician to find it and replace it the par is about 1 or 2 dollars but the total cost would be aroun 130 or 170 u need to find a pionner service center in your area!
Jan 04, 2010 | Pioneer CDJ-1000 CD Player
IMac disk drive ejects audio cds
1) Restart the computer and try again. If that fails, 2) Gently blow canned air into your CD drive slot. If that fails, 3) Bring the unit in for a drive replacement.
Aug 25, 2009 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
Audio/CD Player
dear friend- the error code means the lazer is not reading your cd,if it is a pirate cd it might be the problem,or the lens must be cleaned.
Apr 17, 2009 | Hyundai Motor 2004 Sonata
CD player doesn't work...
most cd players have a reset button underneath the faceplate. try hitting that and see what happens.
Mar 30, 2009 | 2003 Toyota RAV4
Cd stuck in player
I realize this post is a little old , but for anyone looking for a solution try disconnecting your negative battery terminal for a minute or so then reconnect. Next try to eject your cd. Worked for me ^^
2001 taurus
Feb 13, 2008 | Car Audio & Video
Kenwood KDC-1028 CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
