Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Auto defrost cycle
All of a sudden, my refrigerator stopped working. How do I know if it is going through an auto defrost cycle. Can I reset it?
    Sergeant:
    Champion:
  • 324 Answers
You can tell if it is in a defrost by listening in the freezer for a sound similar to water dripping on a hot surface. this should only be for a short time.
Posted on Nov 04, 2008
How to replace a defrost heater on a ge side by side
The auto defrost cycle uses 4 components. A timer, a defrost heater, a defrost termination switch and a fusible link.
Any one of those could stop your fridge from defrosting.
The best thing to do is do a diagnostic on the defrost components to work out which component is actually faulty.
Mar 31, 2011 | Refrigerators
Freezer icing up then stops the fan
There is a problem with the refrigerators auto defrost cycle. The defrost heater may have fallen away from the evaporator coil or the heater has burnt out. You really need to do a full diagnostic on the defrost equipment to spot the real fault
I have an upright Whirlpool side by side fridge freezer, there is ice build up inside under the ice bin/water dispense, I emptied the ice and turned off the ice maker but it is still there and getting...
It sounds like the auto defrost cycle has stopped working.
Manually defrost the freezer.
If things work better then it is the defrost cycle which is faulty.
A technician can help you with that
Mar 30, 2011 | Whirlpool GAFZ21 Bottom Freezer...
It will not go into the auto defrost cycle
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 17, 2011 | Refrigerators
FRIG NOT COOLING - FREEZER IS FINE
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Jan 27, 2011 | Samsung Refrigerators
What is the difference between self defrost and cyclic defrost.
Hi, Self defrosting is auto defrost with out cycle. It work on controller leads. Cycle defrost timed defrost. It work after certain time The defrost work on evaporator
Jan 23, 2011 | Refrigerators
Check all circuts nothing is on (model #795.7834), does this refrig do a auto defrost and so do everything stop working even the water dispencer
is the light on on the inside of the machine if not then your machine is not getting power all fridges and freezers have an auto defrost cycle whether they be mechanicaly like the older ones or electronic like todays models defrost has nothing to do with you getting water to your door i dont actually think the power going to the unit is on if it is plz repost or send me a reply
thanks
Jul 13, 2010 | Kenmore Refrigerators
Ice maker has stopped working and auto defrost does;nt seem to be 100%
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
kjffkjk
May 20, 2010 | Samsung RS2630SH Side by Side Refrigerator
HOW TO BYPASS
If the refrigerator is not icing up it could be the defrost thermostat making the defrost cycle initiate every time the defrost timer makes defrost available. I do not recommend by-passing the defrost cycle, have the switch checked and replaced if needed.
May 26, 2009 | Frigidaire Freezers
Bosch Cooler is broken
im taking it that the cooler you refer to is actually a general fridge. if its not working, it is either your th/stat which has not reset or if not, assuming your fridge is an auto defrost, look behind the freezer and locate the timer. you should see a plastic knob plus/minus in the middle of the timer. turn the knob and listen if refrigerator comes on. if not call a tech.
Feb 20, 2007 | Bosch KIL24443 Top Freezer Refrigerator
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
249 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
