Question about Toshiba Satellite P15-S479 Notebook
Toshiba P15 S479 Laptop
My power cord doesnt make a good connection into the power supply do i need a new power cord or do i need a new power supply? If i wiggle it just right it shows connected to ac and charging of battery
  • Anonymous Jan 12, 2009
    Same problem! How do you re-solder this without destroying it?
I had the same problem. The AC adapter connections on the mother board had to be resoldered.
Posted on Dec 30, 2008
My cd/dvd drive is inoperable (Matshita UJ-811B) I understand historical problems with this drive. What will fit in my Satellite P-15 S479?
Posted on Dec 13, 2008
Hi my Toshiba satellite p15-s479 window media center edition crashed and i lost the CD for recovery or for re installation, please how can i access the operating system CD
If you know some one with the same computer and edition you can use theirs. If not you. can contact toshiba and they will send you one.
Oct 16, 2010 | Toshiba Satellite P15-S479 Notebook
Main Swicht TOSHIBA SALLETITE P15
Hi does your computer usually power on? can you use the computer?
Mar 26, 2010 | Toshiba Satellite P15-S479 Notebook
Power supply stops charging battery until battery is completely drained. Laptop doesn't run off power supply during this time. Power supply is working, I've checked it with volt meter.  Rebooting...
there is a micro switch inside of your laptop that sounds like it has gone. happens to alot of laptops your best bet is to check your garantee if its still indate id send it back because its nearly inposible to fix yourself unless your really good with a soldering iron.
Nov 29, 2009 | Toshiba Satellite P15-S479 Notebook
Changing the ram in my toshiba stellite a45 laptop
I don’t have a diagram for upgrading memory in this particular model, but it’s very easy. You can access both memory slots from the bottom of the laptop if you remove the memory cover. The cover is located in the middle, right beside the fans. All you have to do is remove 2 screws and remove the cover. I believe Satellite P15 memory is expandable to 2GB in both slots (Slot A + Slot B = 2GB) and you can use PC2100 DDR RAM, PC2700 memory should work too (it will run at PC2100 speed).
Check the laptop specifications before you buy new RAM module. I just discovered that different Satellite P15 models use different memory types. For example, according to Toshiba specifications Satellite P15-S409 uses PC2100 DDR memory, but Toshiba Satellite P15-S479 uses PC2700 DDR memory (I think it might be a typo, but not really sure).
Jul 31, 2009 | Toshiba A45-S121 Notebook
Hi can i upgrade may lap top cpu (toshiba.satellate p15-s479)
it wouldn't be worth your time because you would need a new system board also. replacing a system board in a laptop is dicey because they don't always fit inside the case of a laptop. it would be significantly easier to just purchase a new laptop.
Jul 11, 2009 | Toshiba Satellite P15-S479 Notebook
Password for setup laptop toshiba satellite p15-s479
somebody must have installed a password, but try this..
admin
Aug 08, 2008 | Toshiba Satellite P15-S479 Notebook
Toshiba Battery Power
It can be fixed but it means removing the original power socket and replacing it with a new one. The socket is usually soldered to the motherboard so the whole laptop has to be dismantled. Most people wouldnt even attempt to repair it and would probably change the motherboard. The socket is available here:
http://www.computercare.ca/product.php?productid=16269
If you can find someone to do the job.
Mar 08, 2008 | Toshiba Satellite P15-S479 Notebook
Replave DVDRAM drive
you have to open your laptop then you can change you rom
Oct 10, 2007 | Toshiba Satellite P15-S479 Notebook
Toshiba Satellite P15-S479 Notebook Logo
137 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
